path: root/cpu/ixp
2009-04-28Replace __asm references with __asm__Peter Tyser
__asm__ follows gcc's documented syntax and is generally more common than __asm. This change is only asthetic and should not affect functionality. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-05arm: unify reset commandJean-Christophe PLAGNIOL-VILLARD
2009-04-05arm: clean cache managementJean-Christophe PLAGNIOL-VILLARD
unify arm cache management except for non standard cache as ARM7TDMI Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-05arm: update co-processor 15 accessJean-Christophe PLAGNIOL-VILLARD
import system.h from linux Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-20npe: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The resulting code can also be simplified even further. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Stefan Roese <sr@denx.de> CC: Ben Warren <biggerbadderben@gmail.com>
2009-01-31ixp: move serial to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-01-31ixp: move pci init in arm/board instead of cpuJean-Christophe PLAGNIOL-VILLARD
2009-01-31ixp: move pci drivers to drivers/pciJean-Christophe PLAGNIOL-VILLARD
2009-01-31ixp: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2009-01-31ixp: add missing os defineJean-Christophe PLAGNIOL-VILLARD
need by arm-elf toolchains and no impact on the arm-linux one Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-31ixp: remove the option to include the MicrocodeJean-Christophe PLAGNIOL-VILLARD
instead the board will have to load it from flash or ram which will be specified by npe_ucode env var Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-30ixp/npe: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-11-09Moved initialization of IXP4XX_NPE Ethernet controller to cpu_eth_init()Ben Warren
Also, removed the driver initialization from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-02Consolidate MAX/MIN definitionsAndy Fleming
There were several, now there is one (two if you count the lower-case versions). Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-07-13Fix some more printf() format issues.Wolfgang Denk
2008-02-14ARM: cleanup duplicated exception handlingcodeAndreas Engel
Move duplicated exception handling code into lib_arm. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-01-18IXP: enable RTSMichael Schwingen
enables the RTS signal with CONFIG_SERIAL_RTS_ACTIVE. No handshaking is done, but the active RTS signal allows to connect to the target using a PC which is using RTS/CTS handshake, and does no harm if the PC is set to ignore RTS. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2008-01-18IXP: add dynamic microcode addrJean-Christophe PLAGNIOL-VILLARD
allow to load the microde from flash or ram by download it through the serial or other. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Stefan Roese <sr@denx.de>
2008-01-18load ixp42x NPE firmware from separate flash block, remove dead codeMichael Schwingen
Hi, the following patch adds support to move the IXP42X NPE firmware to a separate flash block, whose start address is defined in CONFIG_IXP4XX_NPE_EXT_UCODE_BASE. Using that, it is possible to build NPE-enabled u-boot without copyright problems due to the NPE firmware. I hope the patch applies, I get whitespace-related differences in the NPE files due to trailing whitespace in the original versions. Signed-off-by: Michael Schwingen <michael@schwingen.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2008-01-09Coding Style clenaup; update CHANGELOGWolfgang Denk
2008-01-09IXP: Add full baud-rate support for ixp42x, ixp45x and ixp46xJean-Christophe PLAGNIOL-VILLARD
2007-07-09cpu/[7a-ln-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04cpu/ non-mpc*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-23Remove BOARDLIBS usage completelyStefan Roese
2006-06-14Fix IxEthDB.h to compile againStefan Roese
Patch by Stefan Roese, 14 Jun 2006
2006-05-30Minor cleanup.Wolfgang Denk
2006-05-30* Update Intel IXP4xx supportWolfgang Denk
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.]
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
2005-09-25Fix warnings for PCI code on ixpWolfgang Denk
Patch by Joe <lgxue@yahoo.com>, 13 Jan 2005
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-03Patch by Steven Scholz, 25 Oct 2004:wdenk
Declare reset_cpu() in include/common.h instead locally
2005-01-12* Some Cleanup.wdenk
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets)
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-06-09Patch by Markus Pietrek, 04 May 2004:wdenk
Fix clear_bss code for ARM systems (all except s3c44b0 which doesn't clear BSS at all?)
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
