move s3c44b0 to arch_cpu_init and as noone use cpu_init remove it
all arm init the IRQ stack the same way
so unify it in lib_arm/interrupts.c and then call arch specific interrupt init
unify arm cache management except for non standard cache as ARM7TDMI
import system.h from linux
Also, removed the driver initialization from net/eth.c
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
Declare reset_cpu() in include/common.h instead locally
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
