path: root/cpu/ixp/config.mk
2006-05-30* Update Intel IXP4xx supportWolfgang Denk
- Add IXP4xx NPE ethernet MAC support - Add support for Intel IXDPG425 board - Add support for Prodrive PDNB3 board - Add IRQ support Patch by Stefan Roese, 23 May 2006 [This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still sufferes from licensing issues. Blame Intel.]
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
