path: root/cpu/i386
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-03-20Add basic relocation to i386 portGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-03-20Implement SC520 timersGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Factor out SC520 sub-featuresGraeme Russ
Moved sub-features of the SC520 code which is currently selectively compiled using #ifdef out of sc520.c into individual files selectively compiled via the makefile Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Rewrite i386 interrupt handlingGraeme Russ
Rewrite interrupt handling functionality for the i386 port. Separated functionality into separate CPU and Architecture components. It appears as if the i386 interrupt handler functionality was intended to allow multiple handlers to be installed for a given interrupt. Unfortunately, this functionality was not fully implemented and also had the problem that irq_free_handler() does not allow the passing of the handler function pointer and therefore could never be used to free specific handlers that had been installed for a given IRQ. There were also various issues with array bounds not being fully tested. I had two objectives in mind for the new implementation: 1) Keep the implementation as similar as possible to existing implementations. To that end, I have used the leon2/3 implementations as the reference 2) Seperate CPU and Architecture specific elements. All specific i386 interrupt functionality is now in cpu/i386/ with the high level API and architecture specific code in lib_i386. Functionality specific to the PC/AT architecture (i.e. cascaded i8259 PICs) has been further split out into an individual file to allow for the implementation of the PIC architecture of the SC520 CPU (supports more IRQs) Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Rename SC520 Configuration OptionsGraeme Russ
Options are now all uniformly CONFIG_SYS_SC520_<option> Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-02-25Moved SC520 Files (fix commit 407976185e0dda2c90e89027121a1071b9c77bfb)Graeme Russ
Fixes commit 407976185e0dda2c90e89027121a1071b9c77bfb Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-24Remove #ifdef CONFIG_SC520 in source codeGraeme Russ
CONFIG_SC520 is now used for conditional compile Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Added MMCR reset functionalityGraeme Russ
Reset function specific to AMD SC520 microcontroller - Is more of a 'hard reset' that the triple fault. Requires CONFIG_SYS_RESET_SC520 to be defined in config I would have liked to add this to a new file (cpu/i386/sc520/reset.c) but ld requires that a object file in a library arhive MUST contain at least one function which does not override a weak function (and is called from outside the object file) in order for that object file to be extracted from the archive. This would be the only function on the new file, and hence, will never get linked in. Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Moved generic (triple fault) reset codeGraeme Russ
Moved from interrupts.c to cpu.c and made into a weak function to allow vendor specific override Vendor specific CPU reset (like the AMD SC520 MMCR reset) can now be added to the vendor specific code without the need to remember to #undef usage of the generic method and if you forget to include your custom reset method, you will always get the default. Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Moved definition of set_vector() to new header fileGraeme Russ
This allows for future tidy ups and functionality that will require set_vector () Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Renamed cpu/i386/reset.S to resetvec.SGraeme Russ
Brings i386 in line with other CPUs with a reset vector and frees up reset.c for CPU reset functions Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-12-10Fixed path to sc520 SSI include fileGraeme Russ
Signed Off By: Graeme Russ <graeme.russ@gmail.com>
2008-10-28i386: Renamed show_boot_progress in assembler codeGraeme Russ
Renamed show_boot_progress in assembler init phase to show_boot_progress_asm to avoid link conflicts with C version Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-07-14cpu/i386/serial.c: Fix syntax errorsWolfgang Denk
2008-05-19i386: Fix multiple definitions of __show_boot_progressJean-Christophe PLAGNIOL-VILLARD
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09cpu/[7a-ln-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04cpu/ non-mpc*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-05-15Fixes bug clearing the bss section for i386mushtaq khan
Hi, There is a bug in the code of clearing the bss section for processor i386.(File: cpu/i386/start.S) In the code, bss_start addr (starting addr of bss section) is put into the register %eax, but the code which clears the bss section refers to the addr pointed by %edi. This patch fixes this bug by putting bss_start into %edi register. Signed-off-by: Mushtaq Khan <mushtaq_k@procsys.com>
2006-10-09Coding style cleanupWolfgang Denk
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-08-27Code cleanupWolfgang Denk
2006-08-14Update for SC520 board.Wolfgang Denk
Patch by David Updegraff, 02 Dec 2005
2005-04-03Patch by Steven Scholz, 25 Oct 2004:wdenk
Declare reset_cpu() in include/common.h instead locally
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
