- Separate the portmux configuration functionality from the GPIO pin
control API.
- Separate the controller-specific code from the chip-specific code.
- Allow "ganged" port configuration (multiple pins at once).
- Add more flexibility to the "canned" peripheral select functions:
- Allow using more than 23 address bits, more chip selects, as
well as NAND- and CF-specific pins.
- Make the MACB SPEED pin optional, and choose between MII/RMII
using a parameter instead of an #ifdef.
- Make it possible to use other MMC slots than slot 0, and support
different MMC/SDCard data bus widths.
- Use more reasonable pull-up defaults; floating pins may consume a
lot of power.
- Get rid of some custom portmux code from the mimc200 board code. The
old gpio/portmux API couldn't really handle its requirements, but
the new one can.
- Add documentation.
The end result is slightly smaller code for all boards. Which isn't
really the point, but at least it isn't any larger.
This has been verified on ATSTK1002 and ATNGW100. I'd appreciate if
the board maintainers could help me test this on their boards. In
particular, the mimc200 port has lost a lot of code, so I'm hoping Mark
can help me out.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Mark Jackson <mpfj@mimc.co.uk>
Cc: Alex Raimondi <alex.raimondi@miromico.ch>
Cc: Julien May <julien.may@miromico.ch>
Changes since v1:
* Enable pullup on NWAIT
* Add missing include to portmux-pio.h
* Rename CONFIG_PIO2 -> CONFIG_PORTMUX_PIO to match docs
Use the new GPIO manipulation functions to set up the chip select lines,
and make sure both busses use GPIO for chip select control.
This adds a driver for the SPI controller found on most AT91 and AVR32
chips, implementing the new SPI API.
Changed in v4:
- Update to new API
- Handle zero-length transfers appropriately. The user may send a
zero-length SPI transfer with SPI_XFER_END set in order to
deactivate the chip select after a series of transfers with chip
select active. This is useful e.g. when polling the status
register of DataFlash.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
As reported by Gerhard Berghofer:
in "gpio_enable_usart3" the correct pins for USART 3 are PB17 and PB18
instead of PB18 and PB19.
which is obviously correct. There's currently no code that uses
USART3, but custom boards may run into problems.
Add a chip-features file providing definitions of the form
AT32AP700x_CHIP_HAS_<peripheral>
to indicate the availability of the given peripheral on the currently
selected chip.
The SoC-specific code for all the AT32AP700x CPUs is practically
identical; the only difference is that some chips have less features
than others. By doing this rename, we can add support for the AP7000
derivatives simply by making some features conditional.
