path: root/cpu/arm_cortexa8/omap3
2009-08-21ARM: compiler options cleanup - improve tool chain supportWolfgang Denk
For some time there have been repeated reports about build problems with some ARM (cross) tool chains. Especially issues about (in)compatibility with the tool chain provided runtime support library libgcc.a caused to add and support a private implementation of such runtime support code in U-Boot. A closer look at the code indicated that some of these issues are actually home-made. This patch attempts to clean up some of the most obvious problems and make building of U-Boot with different tool chains easier: - Even though all ARM systems basicy used the same compiler options to select a specific ABI from the tool chain, the code for this was distributed over all cpu/*/config.mk files. We move this one level up into lib_arm/config.mk instead. - So far, we only checked if "-mapcs-32" was supported by the tool chain; if yes, this was used, if not, "-mabi=apcs-gnu" was selected, no matter if the tool chain actually understood this option. There was no support for EABI conformant tool chains. This patch implements the following logic: 1) If the tool chain supports "-mabi=aapcs-linux -mno-thumb-interwork" we use these options (EABI conformant tool chain). 2) Otherwise, we check first if "-mapcs-32" is supported, and then check for "-mabi=apcs-gnu" If one test succeeds, we use the first found option. 3) In case 2), we also test if "-mno-thumb-interwork", and use this if the test succeeds. [For "-mabi=aapcs-linux" we set "-mno-thumb-interwork" mandatorily.] This way we use a similar logic for the compile options as the Linux kernel does. - Some EABI conformant tool chains cause external references to utility functions like raise(); such functions are provided in the new file lib_arm/eabi_compat.c Note that lib_arm/config.mk gets parsed several times, so we must make sure to add eabi_compat.o only once to the linker list. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Dirk Behme <dirk.behme@googlemail.com> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Sergey Kubushyn <ksi@koi8.net> Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Tested-by: Andrzej Wolski <awolski@poczta.fm> Tested-by: Gaye Abdoulaye Walsimou <walsimou@walsimou.com> Tested-by: Tom Rix <Tom.Rix@windriver.com> Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-08-10ARM Cortex A8: Remove bogus config.mk entriesDirk Behme
Remove bogus config.mk entry, fix newline and remove redundant omap3/config.mk Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-08omap3: bug fix for NOR boot supportPenda Naveen Kumar
This patch provides bug fix, when omap3 uses nor boot. Signed-off-by: Penda Naveen Kumar<pnaveen@ti.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-08omap3: replace all instances of gpmc config struct by one globalDirk Behme
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-08omap3: remove typedefs for configuration structsDirk Behme
2009-08-07omap3: embedd gpmc_cs into gpmc config structMatthias Ludwig
Embedd chip select configuration into struct for gpmc config instead of having it completely separated as suggested by Wolfgang Denk on http://lists.denx.de/pipermail/u-boot/2009-May/052247.html Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
2009-07-22ARM Cortex A8: Move OMAP3 specific reset handlerMinkyu Kang
Because of the reset_cpu is soc specific, should be move to soc Cc: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-07-06move L2 cache enable/disable function to cache.c in the omap3 SoC directoryKim, Heung Jun
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> CC: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12OMAP3 Turn on the GPIO bank clocksTom Rix
The function and interface clocks for each GPIO bank, except the first, must be explicitly turned on. These are controlled by the config level defines CONFIG_OMAP3_GPIO_n where n is from 2 to 6. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12OMAP3 Port kernel omap gpio interface.Tom Rix
Port version 2.6.27 of the linux kernel's omap gpio interface to u-boot. The orignal source is in linux/arch/arm/plat-omap/gpio.c See doc/README.omap3 for instructions on use. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12OMAP Consolidate common u-boot.lds to cpu layer.Tom Rix
The u-boot.lds file is common for all omap boards. Move a cleaned up version to the cpu layer and add makefile logic to use it. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12OMAP3: Reorganize Makefile styleJean-Christophe PLAGNIOL-VILLARD
Reformat COBJS handling. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-06-12OMAP3: Remove dublicated interrupt codeJean-Christophe PLAGNIOL-VILLARD
Remove duplicated interrupt code. Original, identical code can be found in lib_arm/interrupts.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-30OMAP3: Fix timer handling to 1ms and CONFIG_SYS_HZ to 1000Manikandan Pillai
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
2009-04-29OMAP3: Print correct silicon revisionSanjeev Premi
The function display_board_info() displays incorrect silicon revision - based on the return value from function get_cpu_rev(). This patch fixes the problem. Signed-off-by: Sanjeev Premi <premi@ti.com>
2009-04-29OMAP3: Remove unused board-typesSanjeev Premi
The board-types defined in struct omap3_sysinfo seem to be unused. The function display_board_info() is passed board type as an argument; which is ignored. This patch removes all uses of board-type, related definitions and functions. Signed-off-by: Sanjeev Premi <premi@ti.com>
2009-04-29OMAP3: Use functions print_cpuinfo() and checkboard()Sanjeev Premi
Use the functions print_cpuinfo() and checkboard() to display the cpu and board specific information. These functions reuse content from the existing function display_board_info() - which has been removed. Also, updated the existig OMAP3 configurations to define: - CONFIG_DISPLAY_CPUINFO - CONFIG_DISPLAY_BOARDINFO Signed-off-by: Sanjeev Premi <premi@ti.com>
2009-04-05OMAP: Fix compile issueSanjeev Premi
Fixes this compile error: board.c: In function 'do_switch_ecc': board.c:339: error: 'cmd_tbl_t' has no member named 'help' make[1]: *** [board.o] Error 1 make[1]: Leaving directory `/db/psp_git/users/a0756819/u-boot/cpu/arm_cortexa8/omap3' make: *** [cpu/arm_cortexa8/omap3/libomap3.a] Error 2 This is due to the fact that current command uses long help for the usage print even if the CONFIG_SYS_LONGHELP is not enabled. (Thanks Jean-Christophe for explanation). Signed-off-by: Sanjeev Premi <premi@ti.com>
2009-03-30OMAP: rename timer divisorLadislav Michl
Divisor field is called PTV not PVT. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-13OMAP3: Add support for OMAP3 die IDDirk Behme
Read and store OMAP3 die ID in U-Boot environment. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-22OMAP3: Add OMAP3 auto detectionDirk Behme
This patch adds OMAP3 cpu type auto detection based on OMAP3 register and removes hardcoded values. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-01-24OMAP3: Add common board, interrupt and system infoDirk Behme
Add common board, interrupt and system info code. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-01-24OMAP3: Add common clock, memory and low level codeDirk Behme
Add common clock, memory and low level code Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-01-24OMAP3: Add common cpu and start codeDirk Behme
Add common cpu and start code. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
