path: root/cpu/arm926ejs
2008-09-13Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-09-12ARM DaVinci: Remove duplicate code in cpu/arm926ejs/davinci/dp83848.cHugo Villeneuve
ARM DaVinci: Remove duplicate code in cpu/arm926ejs/davinci/dp83848.c Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-09-10ARM DaVinci: Fix broken HW ECC for large page NAND.Hugo Villeneuve
Based on original patch by Bernard Blackham <bernard@largestprime.net> U-boot's HW ECC support for large page NAND on Davinci is completely broken. Some kernels, such as the 2.6.10 one supported by MontaVista for DaVinci, rely upon this broken behaviour as they share the same code for ECCs. In the existing scheme, error detection *might* work on large page, but error correction definitely does not. Small page ECC correction works, but the format is not compatible with the mainline git kernel. This patch adds ECC code that matches what is currently in the Davinci git repository (since NAND support was added in 2.6.24). This makes the ECC and OOB layout written by u-boot compatible with Linux for both small page and large page devices and fixes ECC correction for large page devices. The old behaviour can be restored by defining the macro CFG_DAVINCI_BROKEN_ECC, which is undefined by default. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Acked-by: Sergey Kubushyn <ksi@koi8.net> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-02Moved initialization of Ethernet controllers on Atmel AT91 to board_eth_init()Ben Warren
Removed at91sam9_eth_initialize() from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-31ARM DaVinci: Changing function names for EMAC driverSandeep Paulraj
DM644x is just one of a series of DaVinci chips that use the EMAC driver. By replacing all the function names that start with dm644x_* to davinci_* we make these function more portable. I have tested this change on my EVM. DM6467 is another DaVinci SOC which uses the EMAC driver and i will be sending patches that add DaVinci DM6467 support to the list soon. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2008-08-25Correct ARM Versatile Timer InitializationGururaja Hebbar K R
- According to ARM Dual-Timer Module (SP804) TRM (ARM DDI0271), -- Timer Value Register @ TIMER Base + 4 is Read-only. -- Prescale Value (Bits 3-2 of TIMER Control register) can only be one of 00,01,10. 11 is undefined. -- CFG_HZ for Versatile board is set to #define CFG_HZ (1000000 / 256) So Prescale bits is set to indicate - 8 Stages of Prescale, Clock divided by 256 - The Timer Control Register has one Undefined/Shouldn't Use Bit So we should do read/modify/write Operation Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-08-25ARM DaVinci: Removed redundant NAND initialization code.Hugo Villeneuve
ARM DaVinci: Removed redundant NAND initialization code. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-08-25ARM DaVinci: Fix compilation error with new MTD code.Hugo Villeneuve
ARM DaVinci: Fix compilation error with new MTD code. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-08-12at91: move arch-at91sam9 to arch-at91Jean-Christophe PLAGNIOL-VILLARD
2008-08-12NAND: Davinci driver updatesSergey Kubushyn
Here comes a trivial patch to cpu/arm926ejs/davinci/nand.c. Unfortunately I don't have hardware handy so I can not test it at the moment but changes are rather trivial so it should work. It would be nice if somebody with a hardware checked it anyways. Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-14ARM DaVinci: Remove extern phy_t declaration by moving code to proper placeHugo Villeneuve
ARM DaVinci: Remove extern phy_t declaration by moving code to proper place. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-13ARM: Fix for broken compilation when defining CONFIG_CMD_ELFHugo Villeneuve
caused by missing dcache status/enable/disable functions. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-07-10Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2008-07-09NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution.Scott Wood
This is particularly problematic now that non-NAND-specific code is including <nand.h>, and thus all debugging code is being compiled regardless of whether it was requested, as reported by Scott McNutt <smcnutt@psyent.com>. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-06Remove duplicate code in cpu/arm926ejs/davinci/lxt972.c.Hugo Villeneuve
Remove duplicate code in cpu/arm926ejs/davinci/lxt972.c. Remove duplicate code in a if/else block in cpu/arm926ejs/davinci/lxt972.c. Fixed style issues. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-06Remove duplicate definitions in include/lxt971a.h.Hugo Villeneuve
Remove duplicate definitions in include/lxt971a.h. Remove duplicate registers and bits definitions in include/lxt971a.h for standard MII registers, and use values in include/miiphy.h instead. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9261EK supportStelian Pop
This patch adds support for the AT91SAM9261 chip and the AT91SAM9261EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Use a common u-boot.lds file across all AT91CAP9/AT91SAM9 platformsStelian Pop
All the AT91CAP9/AT91SAM9 boards have the same linker script. The patch below avoids the duplication of u-boot.lds by putting the file in the cpu directory instead of the board one. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net>
2008-05-08Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-22ARM: Davinci: Fix DM644x timer overflow handling and cleanupDirk Behme
Fix ARM based DaVinci DM644x timer overflow handling and cleanup timer code. Changes: - Remove *_masked() functions as noted by Wolfgang - Adapt register naming to recent TI spec (sprue26, March 2007) - Fix reset_timer() handling - As reported by Pieter [1] the overflow fix introduced a delay of factor 16 (e.g 2 seconds became 32). While the overflow fix is basically okay, it missed to divide udelay by 16, too. Fix this. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/38179 - Remove software division of timer count value (DIV(x) macro) and do it in hardware (TIM_CLK_DIV). Many thanks to Troy Kisky <troy.kisky@boundarydevices.com> and Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl> for the hints & testing! Patch is compile tested with davinci_dvevm & sonata & schmoogie configuration and tested by Pieter on DaVinci EVM hardware. Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl>
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-01AT91SAM9: Move CONFIG_HAS_DATAFLASH to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-04-01Port AT91CAP9 to the new headersStelian Pop
Adapt the existing AT91CAP9 code to the new headers and APIs. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Move at91cap9 specific files to at91sam9 directoryStelian Pop
AT91CAP9 and AT91SAM9 SoCs are very close hardware wise, so a common infrastructure can be used. Let this infrastructure be named after the AT91SAM9 family, and move the existing AT91CAP9 files to the new place. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Use timer_init() instead of board supplied interrupt_init()Stelian Pop
The timer on AT91CAP9/AT91SAM9 is supplied by the SoC, and not by the board, so use timer_init() instead of interrupt_init(). Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-30Removes all board specific code from the arch. part for DM644x (DaVinci) boardsPieter Voorthuijsen
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
2008-03-30- Remove *_masked() functions as noted by WolfgangDirk Behme
- Adapt register naming to recent TI spec (sprue26, March 2007) - Fix reset_timer() handling - As reported by Pieter [1] the overflow fix introduced a delay of factor 16 (e.g 2 seconds became 32). While the overflow fix is basically okay, it missed to divide udelay by 16, too. Fix this. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/38179 - Remove software division of timer count value (DIV(x) macro) and do it in hardware (TIM_CLK_DIV). Many thanks to Troy Kisky <troy.kisky@boundarydevices.com> and Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl> for the hints & testing! Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl>
2008-02-24Coding style cleanup. Prepare v1.3.2-rc2 release candidatev1.3.2-rc2Wolfgang Denk
2008-02-15Merge branch '080208_dupint' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '080116_at91cap9' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-14ARM: cleanup duplicated exception handlingcodeAndreas Engel
Move duplicated exception handling code into lib_arm. Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2008-02-14AT91CAP9 support : cpu/ filesStelian Pop
Signed-off-by: Stelian Pop <stelian <at> popies.net>
2008-02-14Fix arm926ejs compile when SKIP_LOWLEVEL_INIT is onStelian Pop
Fix arm926ejs compile when SKIP_LOWLEVEL_INIT is on. cpu/arm926ejs/start.o: In function `cpu_init_crit': .../cpu/arm926ejs/start.S:227: undefined reference to `lowlevel_init' Signed-off-by: Stelian Pop <stelian@popies.net>
2008-02-14Fix timer overflow in DaVinciPeter Pearse
2008-02-14Remove duplicate defines for ARRAY_SIZEKumar Gala
2007-08-12Clean up some remaining CFG_CMD_ -> CONFIG_CMD_ issues.Wolfgang Denk
2007-08-10Conding style cleanupStefan Roese
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2006-05-10Minor cleanup.LABEL_2006_05_10_1800Wolfgang Denk
