According to the PPC reference implementation the udelay() function is
responsible for resetting the watchdog timer as frequently as needed.
Most other architectures do not meet that requirement, so long-running
operations might result in a watchdog reset.
This patch adds a generic udelay() function which takes care of
resetting the watchdog before calling an architecture-specific
__udelay().
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Remove volatiles and memory mapped structure accesses and replace with
readl and writel macro usage.
Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
Fix ARM based DaVinci DM644x timer overflow handling and cleanup timer code.
Changes:
- Remove *_masked() functions as noted by Wolfgang
- Adapt register naming to recent TI spec (sprue26, March 2007)
- Fix reset_timer() handling
- As reported by Pieter [1] the overflow fix introduced a delay of factor 16 (e.g 2 seconds became 32). While the overflow fix is basically okay, it missed to divide udelay by 16, too. Fix this.
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/38179
- Remove software division of timer count value (DIV(x) macro) and do it in hardware (TIM_CLK_DIV).
Many thanks to Troy Kisky <troy.kisky@boundarydevices.com> and Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl> for the hints & testing!
Patch is compile tested with davinci_dvevm & sonata & schmoogie configuration and tested by Pieter on DaVinci EVM hardware.
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl>
Reverting became necessary after it turned out that the patches in
the u-boot-arm repo were modified, and in some cases corrupted.
This reverts the following commits:
066bebd6353e33af3adefc3404560871699e9961
7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6
c88ae20580b2b01487b4cdcc8b2a113f551aee36
a147e56f03871bba4f05058d5e04ce7deb010b04
d6674e0e2a6a1f033945f78838566210d3f28c95
8c8463cce44d849e37744749b32d38e1dfb12e50
c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d
8bf69d81782619187933a605f1a95ee1d069478d
8c16cb0d3b971f46fbe77c072664c0f2dcd4471d
a574a73852a527779234e73e17e7597fd8128882
1377b5583a48021d983e1fd565f7d40c89e84d63
1704dc20917b4f71e373e2c888497ee666d40380
16, too. Fix this.
Add support for the following DaVinci boards:
- DV_EVM
- SCHMOOGIE
- SONATA
Changes:
- Split into separate board directories
- Removed changes to MTD_DEBUG (or whatever it's called)
- New CONFIG_CMD party line followed
- Some cosmetic fixes, cleanup etc.
- Patches against the latest U-Boot tree as of now.
- Fixed CONFIG_CMD_NET in net files.
- Fixed CONFIG_CMD_EEPROM for schmoogie.
- Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and
DV_EVM. Can't check if it works on SONATA, don't have a board any more,
but it at least compiles.
Here is an excerpt from session log on SCHMOOGIE...
U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17)
DRAM: 128 MB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
ARM Clock : 297MHz
DDR Clock : 162MHz
ETH PHY : DP83848 @ 0x01
U-Boot > iprobe
Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F
U-Boot > ping 192.168.253.10
host 192.168.253.10 is alive
U-Boot >
Signed-off-by: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Dirk Behme <dirk.behme@gmail.com>
Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com>
