Signed-off-by: Detlev Zundel <dzu@denx.de>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Use lowlevel_init() instead of platformsetup() [rename].
Patch by Peter Pearse, 06 Oct 2005
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards
- introduce two new configuration options instead:
CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
Fix clear_bss code for ARM systems (all except s3c44b0 which
doesn't clear BSS at all?)
ARM memory layout fixes: the abort-stack is now set up in the
correct RAM area, and the BSS is zeroed out as it should be.
Furthermore, the magic variables 'armboot_end' and 'armboot_end_data'
of the linker scripts are replaced by '__bss_start' and '_end',
resp., which is a further step to eliminate unnecessary differences
between the implementation of the CPU architectures.
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
Minor cleanup of comments
Add support for LynuxWorks Kernel Downloadable Images (KDIs).
Both LynxOS and BlueCat linux KDIs are supported.
* Patch by Richard Woodruff, 25 Jul 2003:
use more reliable reset for OMAP/925T
* Patch by Nye Liu, 25 Jul 2003:
fix typo in mpc8xx.h
* Patch by Richard Woodruff, 24 Jul 2003:
Fixes for cmd_nand.c:
- Fixed null dereferece which could result in incorrect ECC values.
- Added support for devices with no Ready/Busy signal hooked up.
- Added OMAP1510 read/write protect handling.
- Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock
for non-JFFS2.
- Switched default ECC to be JFFS2.
- added support for arm925t cpu core
- added support for TI OMAP 1510 Innovator Board
