path: root/cpu/arm920t
2009-10-13Clean-up of cpu_arm920t and cpu_arm920t_s3c24x0 codekevin.morfitt@fearnside-systems.co.uk
This patch re-formats the code in cpu/arm920t and cpu/arm920t/23c24x0 in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boardskevin.morfitt@fearnside-systems.co.uk
This sets CONFIG_SYS_HZ to 1000 for all boards that use the s3c2400 and s3c2410 cpu's which fixes various problems such as the timeouts in tftp being too short. Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, ran MAKEALL for all ARM9 targets and no new warnings or errors were found. It was originally submitted on 21/06/2009 but didn't get into the 2009.08 release, and Jean-Pierre made one comment on the original patch (see http://lists.denx.de/pipermail/u-boot/2009-July/055470.html). I've made two changes to the original patch: - it's been re-based to the current release - I've re-named get_timer_raw() to get_ticks() in response to Jean-Pierre's comment This affects the sbc2410, smdk2400, smdk2410 and trab boards. I've copied it directly to the maintainers of all except the sbc2410 which doesn't have an entry in MAINTAINERS. Signed-off-by: Kevin Morfitt <kmorfitt@aselaptop-1.localdomain> Tested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13Add support for Eukrea CPUAT91 SBCTom Rix
CPUAT91 is built around Atmel's AT91RM9200 and has up to 16MB of NOR flash, up to 128MB of SDRAM, and includes a Micrel KS8721 PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-09-04arm: Remove -fno-strict-aliasingKumar Gala
-fno-strict-aliasing is hidding warnings. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-21ARM: compiler options cleanup - improve tool chain supportWolfgang Denk
For some time there have been repeated reports about build problems with some ARM (cross) tool chains. Especially issues about (in)compatibility with the tool chain provided runtime support library libgcc.a caused to add and support a private implementation of such runtime support code in U-Boot. A closer look at the code indicated that some of these issues are actually home-made. This patch attempts to clean up some of the most obvious problems and make building of U-Boot with different tool chains easier: - Even though all ARM systems basicy used the same compiler options to select a specific ABI from the tool chain, the code for this was distributed over all cpu/*/config.mk files. We move this one level up into lib_arm/config.mk instead. - So far, we only checked if "-mapcs-32" was supported by the tool chain; if yes, this was used, if not, "-mabi=apcs-gnu" was selected, no matter if the tool chain actually understood this option. There was no support for EABI conformant tool chains. This patch implements the following logic: 1) If the tool chain supports "-mabi=aapcs-linux -mno-thumb-interwork" we use these options (EABI conformant tool chain). 2) Otherwise, we check first if "-mapcs-32" is supported, and then check for "-mabi=apcs-gnu" If one test succeeds, we use the first found option. 3) In case 2), we also test if "-mno-thumb-interwork", and use this if the test succeeds. [For "-mabi=aapcs-linux" we set "-mno-thumb-interwork" mandatorily.] This way we use a similar logic for the compile options as the Linux kernel does. - Some EABI conformant tool chains cause external references to utility functions like raise(); such functions are provided in the new file lib_arm/eabi_compat.c Note that lib_arm/config.mk gets parsed several times, so we must make sure to add eabi_compat.o only once to the linker list. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Dirk Behme <dirk.behme@googlemail.com> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Sergey Kubushyn <ksi@koi8.net> Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Tested-by: Andrzej Wolski <awolski@poczta.fm> Tested-by: Gaye Abdoulaye Walsimou <walsimou@walsimou.com> Tested-by: Tom Rix <Tom.Rix@windriver.com> Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-08-03rm9200 lowevel_init: don't touch reserved/readonly registersDavid Brownell
For some reason the AT91rm9200 lowlevel init writes to a bunch of reserved or read-only addresses. All the boards seem to define the value-to-be-written values as zero ... but they shouldn't actually be writing *anything* there. No documented erratum justifies these accesses. It looks like maybe some pre-release BDI-2000 setup code has been carried along by cargo cult programming since at least late 2004 (per GIT history). Here's a patch disabling what seems to be bogosity. Tested on a csb337; there were no behavioral changes. Signed-off-by: David Brownell <david-b@pacbell.net> on RM9200ek Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-27cpu/arm920t/start.S: include <common.h> to have ROUND() definedWolfgang Denk
Commit fcd3c87e made include/common.h usable by assembler code but failed to update cpu/arm920t/start.S Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-22rm9200 ethernet driver: board-specific quirk (csb337)David Brownell
CSB337 boards originally shipped with MicroMonitor, not U-Boot; and with a version using a different convention for recording Ethernet addresses than anyone else. To avoid breaking Linux when it uses U-Boot, have it use the same convention on that hardware. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-06S3C24x0: extract interrupts from timerJean-Christophe PLAGNIOL-VILLARD
2009-07-06arm920t/interrupts: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm: remove cpu_initJean-Christophe PLAGNIOL-VILLARD
move s3c44b0 to arch_cpu_init and as noone use cpu_init remove it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: unify interrupt initJean-Christophe PLAGNIOL-VILLARD
all arm init the IRQ stack the same way so unify it in lib_arm/interrupts.c and then call arch specific interrupt init Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm920/926/926: remove non needed headerJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12at91rm9200: move reset code to reset.cJean-Christophe PLAGNIOL-VILLARD
2009-06-12i2c: Create common default i2c_[set|get]_bus_speed() functionsPeter Tyser
New default, weak i2c_get_bus_speed() and i2c_set_bus_speed() functions replace a number of architecture-specific implementations. Also, providing default functions will allow all boards to enable CONFIG_I2C_CMD_TREE. This was previously not possible since the tree-form of the i2c command provides the ability to display and modify the i2c bus speed which requires i2c_[set|get]_bus_speed() to be present. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-28Replace __attribute references with __attribute__Peter Tyser
__attribute__ follows gcc's documented syntax and is generally more common than __attribute. This change is only asthetic and should not affect functionality. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-05arm: unify reset commandJean-Christophe PLAGNIOL-VILLARD
2009-04-05arm: clean cache managementJean-Christophe PLAGNIOL-VILLARD
unify arm cache management except for non standard cache as ARM7TDMI Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-05arm: update co-processor 15 accessJean-Christophe PLAGNIOL-VILLARD
import system.h from linux Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91rm9200: Reset updateJean-Christophe PLAGNIOL-VILLARD
Update the rm9200 reset sequence to try executing a board-specific reset function and move specific board reset to board. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91rm9200: move serial shutdown code to serial driversJean-Christophe PLAGNIOL-VILLARD
introduce serial_exit for this purpose. Use it only when the rm9200 serial driver is active Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04at91rm9200: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_AT91RM9200_USART to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04Add support for the AT91RM9200EK Board.Ulf Samuelsson
The AT91RM9200-EK Evaluation Board supports the AT91RM9200 ARM9-based 32-bit RISC microcontroller and enables real-time code development and evaluation. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3507 with - NOR (cfi driver) - DataFlash - USB OHCI - Net - I2C (hard) Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-30s3c2410: move nand driver to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-30s3c24x0: move i2c driver to drivers/i2cJean-Christophe PLAGNIOL-VILLARD
2009-03-30s3c24x0: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-30imx: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-29ks8695: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_KS8695_SERIAL to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-20cpu/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cpus that get converted here: at91rm9200 mpc512x mpc5xxx mpc8260 mpc8xx ppc4xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: John Rigby <jrigby@freescale.com> CC: Stefan Roese <sr@denx.de>
2009-01-28usb.h: use standard __LITTLE_ENDIAN from Linux headersMike Frysinger
Rather than forcing people to define a custom "LITTLEENDIAN", just use the __LITTLE_ENDIAN one from the Linux byteorder headers that every arch is already setting up. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-01-06at91rm9200: move define from lowlevel_init to headerJean-Christophe PLAGNIOL-VILLARD
2009-01-06at91rm9200: rename lowlevel init value to CONFIG_SYS_Jean-Christophe PLAGNIOL-VILLARD
2008-12-15i2c: merge all i2c_reg_read() and i2c_reg_write() into inline functionsTimur Tabi
All implementations of the functions i2c_reg_read() and i2c_reg_write() are identical. We can save space and simplify the code by converting these functions into inlines and putting them in i2c.h. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-By: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-13Remove compiler warning: target CPU does not support interworkingSergei Poselenov
This warning is issued by modern ARM-EABI GCC on non-thumb targets. Signed-off-by: Vladimir Panfilov <pvr@emcraft.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2008-12-02AT91: remove non supported board AT91RM9200DF macroJean-Christophe PLAGNIOL-VILLARD
2008-11-24AT91RM9200DK: fix broken boot from NOR flashWolfgang Denk
2008-11-24at91rm9200: fix broken boot from nor flashJens Scharsig
This patch fix the broken boot from NOR Flash on AT91RM9200 boards, if CONFIG_AT91RM9200 is defined and nor preloader is used. Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2008-10-21Merge git://git.denx.de/u-boot into x1Markus Klotzbuecher
Conflicts: drivers/usb/usb_ohci.c
2008-10-14The PIPE_INTERRUPT flag is used wrongRemy Bohmer
At a lot of places in the code the PIPE_INTERRUPT flags and friends are used wrong. The wrong bits are compared to this flag resulting in wrong conditions. Also there are macros that should be used for PIPE_* flags. This patch tries to fix them all, however, I was not able to test the changes, because I do not have any of these boards. Review required! Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-09-12at91rm9200: fix errors with CONFIG_CMD_I2C_TREEJens Scharsig
This patch prevents linker error on AT91RM9200 boards, if CONFIG_CMD_I2_TREE is set. It implements i2c_set_bus_speed and i2c_get_bus_speed as a dummy function. Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
2008-09-12i.mx change get_timer(base) to return time since baseAndrew Dyer
This patch changes get_timer() for i.MX to return the time since 'base' instead of the time since the counter was at zero. Symptom seen is flash timeout errors when erasing or programming a sector using the common cfi flash code. Signed-off-by: Andrew Dyer <adyer@righthandtech.com>
2008-09-12i.MX use u-boot baud rate and don't assume UART master clockAndrew Dyer
1) Change the i.MX serial driver to use the baud rate set in the u-boot environment 2) don't assume a 16MHz value for PERCLK1 in baud rate calculations 3) don't write a 1 to the RDR bit in the USR2 reg. (bit is not "write one to clear" like other status bits in the reg.) Signed-off-by: Andrew Dyer <adyer@righthandtech.com>
2008-09-12arm920t fix constant error in start.SAndrew Dyer
Code in cpu/arm920t/start.S will die with a compilation error if CONFIG_STACKSIZE + CFG_MALLOC_LEN works out to an invalid constant for the ARM sub instruction. Change the code so that each is subtracted independently to avoid the error. Signed-off-by: Andrew Dyer <adyer@righthandtech.com>
2008-08-14Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-08-13s3c24x0: Update NAND driver to new API.Scott Wood
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
