path: root/cpu/arm920t
2006-07-21Add support for friendly-arm SBC-2410X boardWolfgang Denk
Patch by JinHua Luo, 01 Sep 2005
2006-06-16Bugfix in I2C initialisation on S3C2400.Wolfgang Denk
If the bus is blocked because of a previously interrupted transfer, up to eleven clocks are generated on the I2CSCL line to complete the transfer and to free the bus. With this fix pin I2CSCL (PG6) is really configured as GPIO so the clock pulses are really generated. Patch by Martin Krause, 04 Apr 2006
2006-04-03Fix CONFIG_SKIP_LOWLEVEL_INIT dependency in cpu/arm920t/start.SWolfgang Denk
Patch by Peter Menzebach, 13 Oct 2005 [DNX#2006040142000473]
2006-03-11More GCC 4.x woesWolfgang Denk
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-13Support passing of OF flat trees to the kernel.Wolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-10-09Eliminate hard-coded address of Ethernet transfer buffer on at91rm9200Wolfgang Denk
Patch by Anders Larsen, 07 Oct 2005 The Atmel errata #11 states that the transfer buffer descriptor table must be aligned on a 16-word boundary. As it turned out, this is insufficient - it seems the table must be aligned on a boundary at least as large as the table itself (in Linux this is not an issue - the table is aligned on a PAGE_SIZE (4096) boundary).
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-10-06Complete support for the KwikByte KB920x boardsWolfgang Denk
Patch by Anders Larsen, 05 Oct 2005
2005-10-05Set the AT91RM9200 clock to asynchronous modeWolfgang Denk
Patch by Anders Larsen, 03 May 2005
2005-10-05Set the AT91RM9200 clock to synchronous modeWolfgang Denk
Patch by Anders Larsen, 29 Apr 2005
2005-10-05Add support for Cogent csb637Wolfgang Denk
2005-10-05Fix dm9161.c initializationWolfgang Denk
2005-10-05* Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
2005-09-26Add support for AT91RM9200 OHCI Controller.Wolfgang Denk
Patch by Eric Benard, 07 Apr 2005
2005-09-25CleanupWolfgang Denk
2005-09-25Add ARM946E cpu and core module targets; remap memory to 0x00000000Wolfgang Denk
Patch by Peter Pearse, 2 Feb 2005
2005-08-23Fix make dependencies for at91rm9200 and ks8695 cpusWolfgang Denk
Patch by Steven Scholz, 23 Aug 2005
2005-08-12Eliminate calls of ARM libgcc.a helper functions _divsi3 and _modsi3Wolfgang Denk
Patch by Anders Larsen, 26 Apr 2005
2005-08-02Coding style cleanupWolfgang Denk
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-04-20Cleanup serial console baudrate calculation on AT91RM9200wdenk
2005-04-13* Fixes for TQM8560 board:wdenk
- fix clock rates - remove debug messages - fix flash sector protection * Patch by Steven Scholz, 07 Apr 2005: Fix warning in cpu/arm920t/at91rm9200/i2c.c
2005-04-07* Patch by Steven Scholz, 07 Apr 2005:wdenk
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C * Patch by Steven Scholz, 07 Apr 2005: Fix compiler warning in altera.c * Patch by Ladislav Michl, 06 Apr 2005: Fix voiceblue configuration.
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-05Patches by Steven Scholz, 05 Apr 2005:wdenk
- Use i.MX watchdog timer for reset_cpu() - Move reset_cpu() out of cpu/arm920t/start.S into the SoC specific subdirectories cpu/arm920t/imx/ and cpu/arm920t/s3c24x0/ (now in interupts.c)
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-04Fix timer code for ARM systems: make sure that udelay() does notwdenk
reset timers so it's save to use udelay() in timeout code.
2005-04-03Patch by Steven Scholz, 25 Oct 2004:wdenk
Declare reset_cpu() in include/common.h instead locally
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-03-14* Patch by David Brownell, 10 Mar 2005:wdenk
Restore copyright statements in OHCI drivers. * Add support for TQM8540 board
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-10-09Patch by Steven Scholz, 16 Aug 2004:wdenk
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-06-09Patch by Markus Pietrek, 04 May 2004:wdenk
Fix clear_bss code for ARM systems (all except s3c44b0 which doesn't clear BSS at all?)
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2003-12-07* Patches by David Müller, 14 Nov 2003:wdenk
- board/mpl/common/common_util.c * implement support for BZIP2 compressed images * various cleanups (printf -> puts, ...) - board/mpl/common/flash.c * report correct errors to upper layers * check the erase fail and VPP low bits in status reg - board/mpl/vcma9/cmd_vcma9.c - board/mpl/vcma9/flash.c * various cleanups (printf -> puts, ...) - common/cmd_usb.c * fix typo in comment - cpu/arm920t/usb_ohci.c * support for S3C2410 is missing in #if line - drivers/cs8900.c * reinit some registers in case of error (cable missing, ...) - fs/fat/fat.c * support for USB/MMC devices is missing in #if line - include/configs/MIP405.h - include/configs/PIP405.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support - include/configs/VCMA9.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support * enable USB support - lib_arm/armlinux.c * change calling convention of ARM Linux kernel as described on http://www.arm.linux.org.uk/developer/booting.php * Patch by Thomas Lange, 14 Nov 2003: Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to support all these AMD boards. * Patch by Thomas Lange, 14 Nov 2003: Workaround for mips au1x00 physical memory accesses (the au1x00 uses a 36 bit bus internally and cannot access physical memory directly. Use the uncached SDRAM address instead of the physical one.)
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-09-29* Adapt TRAB configuration and auto_update to new memory layoutdzu
