path: root/cpu/arm920t
2007-11-18s3c24x0: Fix usb_ohci.c missing in MakefileJean-Christophe PLAGNIOL-VILLARD
and usb_ohci.c warning differ in signedness Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-10-24fix warning: no return statement in function returning non-voidJean-Christophe PLAGNIOL-VILLARD
2007-09-18Move coloured led API to status_led.hPeter Pearse
Improve indentation in drivers/at45.c
2007-09-11Final tidyPeter Pearse
2007-09-05Changed API name to coloured_led.hPeter Pearse
Removed code using deprecated ifdef CONFIG_BOOTBINFUNC Tidied other cpu/arm920t/start.S code
2007-09-04Add coloured led interface for ARM boards.Peter Pearse
Use it in cpu/arm920t/start.S to indicate U-Boot code has been entered.
2007-08-14Coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-14Add the files.Peter Pearse
2007-08-14Add MACH_TYPE records for several AT91 boards.Peter Pearse
Merge to two at45.c files into a common file, split to at45.c and spi.c Fix spelling error in DM9161 PHY Support. Initialize at91rm9200 board (and set LED). Add PIO control for at91rm9200dk LEDs and Mux. Change dataflash partition boundaries to be compatible with Linux 2.6. Signed-off-by: Peter Pearse <peter.pearse@arm.com> Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-07-09cpu/[7a-ln-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04cpu/ non-mpc*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-11-27Merge with /home/mk/git/u-boot-generic_ohci#generic_ohciWolfgang Denk
2006-11-27Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
2006-08-07Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-07-21Add support for friendly-arm SBC-2410X boardWolfgang Denk
Patch by JinHua Luo, 01 Sep 2005
2006-06-26More code cleanupWolfgang Denk
2006-06-26Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-06-16Bugfix in I2C initialisation on S3C2400.Wolfgang Denk
If the bus is blocked because of a previously interrupted transfer, up to eleven clocks are generated on the I2CSCL line to complete the transfer and to free the bus. With this fix pin I2CSCL (PG6) is really configured as GPIO so the clock pulses are really generated. Patch by Martin Krause, 04 Apr 2006
2006-05-30Support generic OHCI support for the s3c24x0 cpu.Markus Klotzbuecher
2006-05-23Changed the mp2usb (at91rm9200) board to use the generic OHCI driver. SomeMarkus Klotzbuecher
fixes to the latter.
2006-04-03Fix CONFIG_SKIP_LOWLEVEL_INIT dependency in cpu/arm920t/start.SWolfgang Denk
Patch by Peter Menzebach, 13 Oct 2005 [DNX#2006040142000473]
2006-03-11More GCC 4.x woesWolfgang Denk
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-13Support passing of OF flat trees to the kernel.Wolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-10-09Eliminate hard-coded address of Ethernet transfer buffer on at91rm9200Wolfgang Denk
Patch by Anders Larsen, 07 Oct 2005 The Atmel errata #11 states that the transfer buffer descriptor table must be aligned on a 16-word boundary. As it turned out, this is insufficient - it seems the table must be aligned on a boundary at least as large as the table itself (in Linux this is not an issue - the table is aligned on a PAGE_SIZE (4096) boundary).
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-10-06Complete support for the KwikByte KB920x boardsWolfgang Denk
Patch by Anders Larsen, 05 Oct 2005
2005-10-05Set the AT91RM9200 clock to asynchronous modeWolfgang Denk
Patch by Anders Larsen, 03 May 2005
2005-10-05Set the AT91RM9200 clock to synchronous modeWolfgang Denk
Patch by Anders Larsen, 29 Apr 2005
2005-10-05Add support for Cogent csb637Wolfgang Denk
2005-10-05Fix dm9161.c initializationWolfgang Denk
2005-10-05* Move dm9161.c and lxt972.c into cpu/arm920t/at91rm9200Wolfgang Denk
Patch by Anders Larsen, 29 Apr 2005 * Fix problems introduced by Patch by Steven Scholz, 02 Mar 2005 (8e2be51de8dd03c1ce4d06cbb18ad06133d47cd5)
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
2005-09-26Add support for AT91RM9200 OHCI Controller.Wolfgang Denk
Patch by Eric Benard, 07 Apr 2005
2005-09-25CleanupWolfgang Denk
2005-09-25Add ARM946E cpu and core module targets; remap memory to 0x00000000Wolfgang Denk
Patch by Peter Pearse, 2 Feb 2005
2005-08-23Fix make dependencies for at91rm9200 and ks8695 cpusWolfgang Denk
Patch by Steven Scholz, 23 Aug 2005
2005-08-12Eliminate calls of ARM libgcc.a helper functions _divsi3 and _modsi3Wolfgang Denk
Patch by Anders Larsen, 26 Apr 2005
2005-08-02Coding style cleanupWolfgang Denk
2005-07-21Fix low-level OHCI transfers for ARM920t and MPC5xxxWolfgang Denk
A new, Windows compatible init sequence was also backported from Linux 2.6, but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour of the memopry sticks we tested. Maybe it's not relevant for mass storage devices. For recerence, see file common/usb.c, function usb_new_device(), section #ifdef NEW_INIT_SEQ.
2005-05-19* Patch by Greg Ungerer, 19 May 2005:wdenk
add support for the KS8695P (ARM 922 based) CPU * Patch by Steven Scholz, 19 May 2005: Add support for CONFIG_SERIAL_TAG on ARM boards
2005-04-20Cleanup serial console baudrate calculation on AT91RM9200wdenk
2005-04-13* Fixes for TQM8560 board:wdenk
- fix clock rates - remove debug messages - fix flash sector protection * Patch by Steven Scholz, 07 Apr 2005: Fix warning in cpu/arm920t/at91rm9200/i2c.c
