Signed-off-by: Detlev Zundel <dzu@denx.de>
__attribute__ follows gcc's documented syntax and is generally more
common than __attribute. This change is only asthetic and should not
affect functionality.
Rather than forcing people to define a custom "LITTLEENDIAN", just use the
__LITTLE_ENDIAN one from the Linux byteorder headers that every arch is
already setting up.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
drivers/usb/usb_ohci.c
At a lot of places in the code the PIPE_INTERRUPT flags and friends
are used wrong. The wrong bits are compared to this flag resulting
in wrong conditions. Also there are macros that should be used for
PIPE_* flags.
This patch tries to fix them all, however, I was not able to test the
changes, because I do not have any of these boards.
Review required!
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This patch fixes three typos.
The first is a repetition of CONFIG_CMD_BSP.
The second makes the #endif comment match its #if.
The third is a spelling error.
Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
Acked-by: Markus Klotzbuecher <mk@denx.de>
This patch adds NAND support to the S3C24x0 SoC code in u-boot
Signed-off-by: Harald Welte <laforge@openmoko.org>
This patch adds support for CONFIG_SERIAL_MULTI on s3c24x0 CPU's
This patch adds a IRQ demultiplexer callback to the arm920 cpu core code,
plus a stub implementation of it for the S3C2410.
The purpose is to allow arm920t implementations such as the s3c24x0 to
implement interrupt handlers in u-boot without having to touch core
arm920t code.
and usb_ohci.c warning differ in signedness
to choose between the old and the generic OHCI drivers.
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Patch by JinHua Luo, 01 Sep 2005
If the bus is blocked because of a previously interrupted
transfer, up to eleven clocks are generated on the I2CSCL
line to complete the transfer and to free the bus.
With this fix pin I2CSCL (PG6) is really configured as GPIO
so the clock pulses are really generated.
Patch by Martin Krause, 04 Apr 2006
A new, Windows compatible init sequence was also backported from Linux 2.6,
but disabled with #undef NEW_INIT_SEQ as it wouldn't change the behaviour
of the memopry sticks we tested. Maybe it's not relevant for mass storage
devices. For recerence, see file common/usb.c, function usb_new_device(),
section #ifdef NEW_INIT_SEQ.
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
- Use i.MX watchdog timer for reset_cpu()
- Move reset_cpu() out of cpu/arm920t/start.S into the SoC specific
subdirectories cpu/arm920t/imx/ and cpu/arm920t/s3c24x0/
(now in interupts.c)
reset timers so it's save to use udelay() in timeout code.
Declare reset_cpu() in include/common.h instead locally
Restore copyright statements in OHCI drivers.
* Add support for TQM8540 board
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)"
- creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0
- moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/
- moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/
