path: root/cpu/arm720t
2005-10-09Add support for NetSilicon NS7520 processor.Wolfgang Denk
Patch by Art Shipkowski, 12 May 2005 Cleanup.
2005-10-09Cleanup warnings for cpu/arm720t & cpu/arm1136 files.Wolfgang Denk
sed the linker scripts, rather than pre-process them. Patch by Peter Pearse, 07 Oct 2005
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-04Fix timer code for ARM systems: make sure that udelay() does notwdenk
reset timers so it's save to use udelay() in timeout code.
2005-04-03Patch by Steven Scholz, 25 Oct 2004:wdenk
Declare reset_cpu() in include/common.h instead locally
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-01-09* Patch by Jon Loeliger, 02 Sep 2004:wdenk
Reset monitor size back to 256 so environment can be written to flash on MPC85xx ADS and CDS releases. * Patch by Paolo Broggini, 02 Sep 2004: Make BSS clearing on ARM systems more robust * Patch by Yue Hu and Joe, 01 Sep 2004: - add PCI support for ixp425; - add EEPRO100 suppor tfor ixdp425 board. * Fix problem with protected sector detection in driver/cfi_flash.c
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-11Patch by Curt Brune, 07 Jul 2004:wdenk
relocate exception vectors on arm720t if needed
2004-07-11* Patch by George G. Davis, 06 Jul 2004:wdenk
- update mach-types.h to latest arm.linux.org.uk master list - Set correct OMAP1610 bi_arch_number for build target * Patch by Curt Brune, 06 Jul 2004: evb4510: add support for timer interrupt; cleanup
2004-07-01* Code cleanup (ARM mostly)wdenk
* Patch by Curt Brune, 17 May 2004: - Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC) - Add support for ESPD-Inc. EVB4510 Board
2004-06-09Patch by Markus Pietrek, 04 May 2004:wdenk
Fix clear_bss code for ARM systems (all except s3c44b0 which doesn't clear BSS at all?)
2004-02-23* Patch by Laurent Mohin, 10 Feb 2004:wdenk
Fix buffer overflow in common/usb.c * Patch by Tolunay Orkun, 10 Feb 2004: Add support for Cogent CSB272 board * Code cleanup
2004-02-23* Patch by Thomas Elste, 10 Feb 2004:wdenk
Add support for NET+50 CPU and ModNET50 board * Patch by Sam Song, 10 Feb 2004: Fix typos in cfi_flash.c * Patch by Leon Kukovec, 10 Feb 2004 Fixed long dir entry slot id calculation in get_vfatname * Patch by Robin Gilks, 10 Feb 2004: add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==, !=, <>, <, >, <=, >=)
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-09-17Support new configuration of TRAB board with more memorywdenk
Minor cleanup of comments
2002-09-08Initial revisionwdenk
2002-09-05Initial revisionwdenk
