2002-11-19 | * Patch by Thomas Frieden, 13 Nov 2002: | wdenk | |
Add code for AmigaOne board (preliminary merge to U-Boot, still WIP) * Patch by Jon Diekema, 12 Nov 2002: - Adding URL for IEEE OUI lookup - Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED being defined. - In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and root-on-nfs macros are designed to switch how the default boot method gets defined. | |||
2002-11-11 | * Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211 | wdenk | |
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h | |||
2002-11-03 | Initial revision | wdenk | |
2002-10-07 | Initial revision | wdenk | |
2002-09-17 | Initial revision | wdenk | |
2002-08-31 | Initial revision | wdenk | |
2002-08-27 | Initial revision | wdenk | |
2002-08-17 | Initial revision | wdenk | |
2002-07-20 | Initial revision | wdenk | |
2002-02-17 | Initial revision | wdenk | |
2002-01-15 | Initial revision | wdenk | |
