path: root/cpu/74xx_7xx/cache.S
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2008-10-1874xx/7xx/86xx: Rename flush_data_cache to flush_dcache to match 85xx versionKumar Gala
2008-08-19Clean up usage of icache_disable/dcache_disableKumar Gala
There is no point in disabling the icache on 7xx/74xx/86xx parts and not also flushing the icache. All callers of invalidate_l1_instruction_cache() call icache_disable() right after. Make it so icache_disable() calls invalidate_l1_instruction_cache() for us. Also, dcache_disable() already calls dcache_flush() so there is no point in the explicit calls of dcache_flush(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-05-097450 and 86xx L2 cache invalidate bug correctionsWheatley Travis
The 7610 and related parts have an L2IP bit in the L2CR that is monitored to signal when the L2 cache invalidate is complete whereas the 7450 and related parts utilize L2I for this purpose. However, the current code does not account for this difference. Additionally the 86xx L2 cache invalidate code used an "andi" instruction where an "andis" instruction should have been used. This patch addresses both of these bugs. Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com> Acked-By: Jon Loeliger <jdl@freescale.com>
2002-11-11* Patch by Jim Sandoz, 07 Nov 2002:LABEL_2002_11_11_2211wdenk
Increase number of network RX buffers (PKTBUFSRX in "include/net.h") for EEPRO100 based boards (especially SP8240) which showed "Receiver is not ready" errors when U-Boot was processing the receive buffers slower than the network controller was filling them. * Get rid of obsolete include/mpc74xx.h
