path: root/configs
2015-11-30armv8: ls2085a: Add support of LS2085A SoCPrabhakar Kushwaha
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality. Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Updated MAINTAINERS files Dropped #ifdef in cpu.h Add CONFIG_SYS_NS16550=y in defconfig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30armv8: LS2080A: Rename LS2085A to reflect LS2080APrabhakar Kushwaha
LS2080A is a prime personality of Freescale’s LS2085A. It is a non-AIOP personality without support of DP-DDR, L2 switch, 1588, PCIe endpoint etc. So renaming existing LS2085A code base to reflect LS2080A (Prime personality) Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> [York Sun: Dropped #ifdef in cpu.c for cpu_type_list] Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30Merge git://git.denx.de/u-boot-socfpgaTom Rini
2015-11-30arm: socfpga: Repair SoCrates boardMarek Vasut
This board was constantly parasiting on the CV SoCDK, so split it into it's own separate directory. Moreover, the board config was missing important bits, like simple-bus support in SPL, the DRAM configuration was incorrect and the DTS was also missing the pre reloc bits. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Dinh Nguyen <dinh.linux@gmail.com> Cc: Jan Viktorin <viktorin@rehivetech.com>
2015-11-29arm: kirkwood: add ZyXEL NSA310S deviceGerald Kerma
This patch add ZyXEL NSA310S 1-Bay Media Server The ZyXEL NSA310S device is a Kirkwood based NAS: - SoC: Marvell 88F6702 1000Mhz - SDRAM memory: 256MB DDR2 400Mhz - Gigabit ethernet: PHY Marvell 88E1318 - Flash memory: 128MB - 1 Power button - 1 Power LED (blue) - 4 Status LED (green) - 1 Copy/Sync button - 1 Reset button - 1 SATA II port - 2 USB 2.0 ports (front and back) - Smart fan Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Tony Dinh <mibodhi@gmail.com> Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
2015-11-25arm: spear: x600: Enable tiny-printfStefan Roese
Enabling the new tiny-printf function makes the SPL image fit again in the 8KiB restricted area. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com>
2015-11-25cgtqmx6eval: Add DFU supportOtavio Salvador
Add MMC and SPI DFU support. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-25cgtqmx6eval: Add SPL supportOtavio Salvador
Congatec has several MX6 boards based on quad, dual, dual-lite and solo. Add SPL support so that all the variants can be supported Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-22sunxi: Update new defconfigsTom Rini
After introduction of CONFIG_SYS_NS16550 these defconfig files were added and need to be updated. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-22Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-11-22sunxi: Add support for the Lamobo R1 boardJelle de Jong
The lamobo-r1 board, sometimes called the BPI-R1 but not labelled as such on the PCB, is meant as a A20 based router board. As such the board comes with a built-in switch chip giving it 5 gigabit ethernet ports, and it has a large empty area on the pcb with mounting holes which will fit a 2.5 inch harddisk. To complete its networking features it has a Realtek RTL8192CU for WiFi 802.11 b/g/n. The dts file is identical to the one submitted upstream. Signed-off-by: Jelle de Jong <jelledejong@powercraft.nl> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-11-22sunxi: Add support for Orangepi Plus and Orangepi PC boardsHans de Goede
Add defconfig files for the Orangepi Plus and Orangepi PC. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-11-21vexpress64: store env in flashRyan Harkin
Add support for storing the environment in CFI NOR flash on Juno and FVP models. I also removed some config values that are not used by CFI flash parts. Juno has 1 flash part with 259 sectors. The first 255 sectors are 0x40000 (256kb) and are followed by 4 sectors of 0x10000 (64KB). FVP models simulate a 64MB NOR flash part at base address 0x0FFC0000. This part has 256 x 256kb sectors. We use the last sector to store the environment. To save the NOR flash to a file, the following parameters should be passed to the model: -C bp.flashloader1.fname=${FILENAME} -C bp.flashloader1.fnameWrite=${FILENAME} Foundation models don't simulate the NOR flash, but having NOR support in the u-boot binary does not harm: attempting to write to the NOR will fail gracefully. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-21nios2: 10m50: change to ns16550 uartThomas Chou
Change to ns16550 uart for 10m50 devboard based on a new Altera release. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: zap CONFIG_NS16550_SERIALThomas Chou
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers is completed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-20ns16550: unify serial_x86Thomas Chou
Unify serial_x86, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: Enable USB keyboardSimon Glass
Enable the USB keyboard on sandbox, now that we have a suitable emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: Enable console recording and silent consoleSimon Glass
Allow console recording so that tests can use it. Also allow the console output to be suppressed, to reduce test output 'noise'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: add a sandbox timer and basic testThomas Chou
Add a sandbox timer which get time from host os and a basic test. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19rockchip: Turn on CONFIG_DEBUG_UART_NS16550 in defconfigsAriel D'Alessandro
No UART driver was specified in defconfig, thus DEBUG_UART_ALTERA_JTAGUART was incorrectly selected by default since commit 220e8021af96741bd7149ca9895e1f0c8a38d0bb added a new Altera UART driver. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-18powerpc/83xx: add support for kmtegr1 boardValentin Longchamp
This board uses the same CPU (8309) as VECT1. The memory however is different since it has NAND Flash, the NOR Flash partitioning is different and of course the FPGAs as well. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com>
2015-11-18powerpc/83xx: add support for kmtepr2 boardChristoph Dietrich
This board is similar to TUXX1, but it has differend FPGAs. Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com> Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18board: ti: beagle_x15: Rename to indicate support for TI am57xx evmsKipisz, Steven
BeagleBoard X15 (http://beagleboard.org/x15) support in u-boot does actually support two different platform configuration offered by TI. In addition to BeagleBoard X15, it also supports the TMDXEVM5728 (or more commonly known as AM5728-evm). Information about the TI AM57xx EVM can be found here http://www.ti.com/tool/tmdxevm5728 The EVM configuration is 1-1 compatible with BeagleBoard X15 with the additional support for mPCIe, mSATA, LCD, touchscreen, Camera, push button and TI's wlink8 offering. Hence, we rename the beagle_x15 directory to am57xx to support TI EVMs that use the AM57xx processor. By doing this we have common code reuse. This sets the stage to have a common u-boot image solution for multiple TI EVMs such as that already done for am335x and am437x. This sets the stage for upcoming multiple TI EVMs that share the same code base. NOTE: Commit eae7ae185335 ("am437x: Add am57xx_evm_defconfig using CONFIG_DM") introduced DT support for beagle_x15 under am57xx_evm platform name. However, this ignored the potential confusion arising for users as a result. To prevent this, existing beagle_x15_defconfig is renamed as am57xx_evm_nodt_defconfig to denote that this is the "non device tree" configuration for the same platform. We still retain am57xx-beagle-x15.dts at this point, since we just require the common minimum dts. As a result of this change, users should expect changes in build procedures('make am57xx_evm_nodt_defconfig' instead of 'make beagle_x15_defconfig'). Hopefully, this would be a one-time change. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Schuyler Patton <spatton@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-11-17Merge git://git.denx.de/u-boot-marvellTom Rini
2015-11-17arm: kirkwood: ib62x0: make use of defconfigLuka Perkov
2015-11-17arm: kirkwood: Move configuration of some commands to _defconfig filesQuentin Armitage
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING and USB commands, and HUSH_PARSER into the _defconfig file, rather than the include/configs/*plug.h files. This avoids compiler warnings of duplicate definitions if the option is selected in the .config, but also defined in the include/configs/*plug.h file. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-18board: axs10x switch serial port and Ethernet to driver modelAlexey Brodkin
With this change Synopsys DesignWare SDP board is switched to driver model for both serial port (serial_dw) and Ethernet (Designware GMAC). This simplifies include/configs/axs101.h and allows for reuse of Linux's Device Tree description. For simplicity Linux's .dts files are not blindly copied but only very few extracts of them are really used (those that are supported in U-Boot at the moment). Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-13Merge branch 'series1_v2' of git://git.denx.de/u-boot-sparcTom Rini
2015-11-13x86: qemu: Convert to use driver model ethBin Meng
Move to driver model for ETH (e1000) on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model usbBin Meng
Move to driver model for USB on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model pciBin Meng
Move to driver model for pci on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13sparc: leon3: Add debug_uart support to LEON3 serial driver.Francois Retief
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-13sparc: Kconfig: Move the CMD_AMBAPP command to KconfigFrancois Retief
Add an initr function in the board_r.c file for the AMBA Plug&Play command. Add a Kconfig entry for the ambapp command and remove all CONFIG_CMD_AMBAPP defines from the board configuration headers. Add a Kconfig entry to display the AMBA Plug&Play information on startup. This option is off by default. Remove relevent define from board configuration headers. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-13sparc: Update GRSIM board with memory settings for TSIM evalFrancois Retief
Update the GRSIM board with the memory settings for the evaluation version of TSIM. This free version of TSIM is used for testing. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-12hrcon: Add support for the DH variantDirk Eibach
hrcon DH(dual head) has two video outputs per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12mpc83xx: Add strider boardDirk Eibach
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> [trini: Drop setting CONFIG_SYS_GENERIC_BOARD, this is always true now] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12sunxi: cubietruck: Enable the USB OTG controllerMaxime Ripard
The Cubietruck has a mini-USB connector that can be used to power up the board and as an OTG connector. Since we have already some USB host-only ports right beside this one, enable it in gadget mode Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-12sunxi: A13-Olinuxino: Enable the USB OTG controllerMaxime Ripard
The A13-Olinuxino has a mini-USB connector that can be used to power up the board and as an OTG connector. Since we have already some USB host-only ports right beside this one, enable it in gadget mode Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-12board/BuR/kwb: use bootvx(...) (with bootline feature) instead go(...)Hannes Petermaier
Since we don't have for sure a valid IP-setup during board_late_init(...) because it maybe allready stored in environment or not, we cannot form a proper vxWorks bootline at this place. So we move to the way, forming the bootline just before executing/launching vxWorks. To do this we use the bootvx command instead go. We only have to form the "othbootargs" environment variable, the rest is done pretty good by the "bootvx" commannd. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-12Merge branch 'next' of git://git.denx.de/u-boot-blackfinTom Rini
2015-11-12nios2: rename board nios2-generic to 3c120_devboardThomas Chou
Rename board nios2-generic to 3c120_devboard. Since nios2 is converted to driver model and device tree control of u-boot, the nios2-generic board directory is removed. We can rename the board back to a real board name. Now the boards maintained in u-boot mainline are the same as Linux kernel, namely 3c120 and 10m50. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2015-11-12nios2: add 10m50 devboard supportThomas Chou
Add 10m50 devboard support. It is based on the Golden Hardware Reference Design (GHRD), available at, http://rocketboards.org/foswiki/view/Documentation/ AlteraMAX1010M50RevCDevelopmentKitLinuxSetup Though we supported only one nios2-generic board in the past. Now, with the removal of the nios2-generic board dir, adding new nios2 boards to u-boot is easier than before. It should be helpful to add those boards supported in Linux mainline. There are only two such nios2 boards, the 3c120 devboard and 10m50 devboard. The nios2-generic is actually 3c120, and should restore the name. The 10m50 is this one. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-11-12nios2: use cfi flash driver modelThomas Chou
Use cfi flash driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-11-06nios2: enable setexpr command in defconfigThomas Chou
Enable setexpr command in defconfig because it is really useful as suggested by Marek. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-11-05Merge git://git.denx.de/u-boot-samsungTom Rini
