This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Commit 76ec988b062e (net: Remove all calls to net_random_ethaddr())
accidentally deleted CONFIG_TARGET_BCT_BRETTL2=y, and since then
bct-brettl2 would not build.
Since commit a26cd04920dc (arch: Make board selection choices
optional), Kconfig actually allows such a .config file in which no
board is selected, but the build never succeeds.
add support for imx6dl based aristainetos2 board
U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: WDOG
Board: aristaitenos2
Watchdog enabled
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Display: lg4573 (480x800)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Prior to this commit, ZC702 and ZC706 shared the same configuration
and were built as follows:
ZC702: make zynq_zc70x_defconfig && make
ZC706: make zynq_zc70x_defconfig && make DEVICE_TREE=zynq-zc706
This commit introduces separate configuration for them, which makes
the next commit much easier.
Going forward, the recommended build commands are:
ZC702: make zynq_zc702_defconfig && make
ZC706: make zynq_zc706_defconfig && make
Although the old work flow is still supported, CONFIG_TARGET_ZC70X
has been marked as deprecated. If used, the warning message is
shown to prompt users to switch to the new scheme.
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
Signed-off-by: Stefan Agner <stefan@agner.ch>
[scottwood: updated vf610twr_nand_defconfig]
Currently we need to build one U-boot image for each of the wandboard
variants: quad, dual-lite and solo.
By switching to SPL we can support all these variants with a single binary,
which is very convenient.
Based on the work from Richard Hu.
Tested kernel booting on the three boards.
Signed-off-by: Richard Hu <hakahu@gmail.com>
Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Enable the new env unit tests on sandbox.
Make all unit tests selectable as a menu of test suites instead of just
sitting in the top-level menu individually.
Unify the command for running unit tests further by moving the "ut_time"
command over to "ut time".
Unify the command for running unit tests further by moving the "dm test"
command over to "ut dm".
Stop using the sandbox arch Kconfig to override defaults for config
options. This is a bit of abuse and may be causing build problems.
The defconfigs should not be edited directly. They should be generated
by editing the .config (through menuconfig or whatever) and then run
make savedefconfig to have the Kconfig system generate a clean defconfig
I did this for sandbox here with no actual changes.
Remove the calls to net_random_ethaddr() that some boards and some
drivers are calling. This is now implemented inside of net/eth.c
Enable the feature for all boards that previously enabled it.
Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part)
Series-changes: 2
-Fixed bfin build errors
The ga10h is an 10" tablet with an A33 or A23 soc, 1G RAM, 8G or 16G nand,
sdio wifi, 2 micro usb ports, 1 otg and 1 host and 1 micro sd slot.
This commit adds a defconfig for the v1.1 pcb with an a33 soc.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg>
Certain features we desire require a larger stack than is available by using
iRAM (most notably for us, env_mmc). Relocate the stack to DRAM so that
we can use these features.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Hummingboard dual, dual-lite and solo are now supported via SPL mechanism.
Remove the previous hummingboard support, which does not use SPL and supported
only the solo variant.
This commit enables:
- emulated i2c PMIC driver
- sandbox PMIC I/O driver
- sandbox PMIC's regulator driver
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Tested on sandbox:
This change enables the configs required to init and setup max77686
regulator driver, using the new driver model pmic and regulator API.
And also changes the old pmic framework calls to the new ones.
This commits enables:
- CONFIG_ERRNO_STR
- CONFIG_DM_PMIC
- CONFIG_DM_PMIC_CMD
- CONFIG_DM_PMIC_MAX77686
- CONFIG_DM_REGULATOR
- CONFIG_DM_REGULATOR_CMD
- CONFIG_DM_REGULATOR_MAX77686
And removes the unused:
- CONFIG_DM_I2C_COMPAT
- CONFIG_POWER
- CONFIG_POWER_I2C
- CONFIG_POWER_MAX77686
Add the PMIC, LCD settings, PWM and also show the board info at the top of
the LCD when starting up.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Remove board support for afeb9260, tny_a9260, and sbc35_a9g20.
They have not been converted into Generic Board yet.
See doc/README.generic-board for details.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Having this as a Kconfig allows it to be a dependent feature.
As this board seems to be unmaintained for quite some time, and its
not moved to the generic board ingrastructure, lets remove it.
This will also enable us to remove the CONFIG_AUTOBOOT_DELAY_STR2
and CONFIG_AUTOBOOT_STOP_STR2 macros, as this sc3 board is the
only one using one of this macros. A removal patch will follow
soon.
Cc: Juergen Beisert <jbeisert@eurodsn.de>
Acked-by: Heiko Schocher <hs@denx.de>
This patch adds device tree for the ST Micro stv0991 board & enables
device tree control. Progressively device tree support for the drivers
being used will also be added.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Signed-off-by: Peter Howard <phoward@gme.net.au>
Switch to a more standard way of board select; put the SoC select
into arch/arm/Kconfig and move the board select menu under
arch/arm/mach-socfpga/Kconfig.
Also, consolidate SYS_BOARD, SYS_VENDOR, SYS_SOC, SYS_CONFIG_NAME.
Enable this command for sandbox.
Enable real-time-clock support in sandbox.
This patch adds support for the Marvell DB-88F6820-GP Armada A38x
evaluation board.
Supported peripherals are:
- UART
- Ethernet (mvneta)
- I2C
- SPI (including SPI NOR flash)
Please note that this board support right now only supports the
main U-Boot. Without the bin_hdr integration (DDR training etc). This
will be added in a few days / weeks to complete this board port. But
till then this U-Boot version can be run on the target via the
original Marvell U-Boot via this command:
tftpboot 4000000 db-88f6820-gp/u-boot.bin;go 4000000
Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com>
Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
New QorIQ p1020 based board support from Arcturus Networks Inc.
http://www.arcturusnetworks.com/products/ucp1020/
Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
Signed-off-by: Oleksandr G Zhadan <oleks@arcturusnetworks.com>
[York Sun: remove patman tags from commit message]
Reviewed-by: York Sun <yorksun@freescale.com>
1. board/freescale/t4qds/t4_rcw.cfg
1.8GHz support is requested as default frequency, so update the rcw.
2. remove un-used configs
configs/T4160QDS_SPIFLASH_defconfig
configs/T4240QDS_SPIFLASH_defconfig
SPI boot is not available on T4QDS, so the configs should be removed.
3. board/freescale/t4qds/MAINTAINERS
Updated MAINTAINERS accordingly.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
[York Sun: revise subject]
T1023RDB is a Freescale Reference Design Board that hosts the T1023 SoC.
T1023RDB board Overview
- T1023 SoC integrating two 64-bit e5500 cores up to 1.4GHz
- CoreNet fabric supporting coherent and noncoherent transactions with
prioritization and bandwidth allocation
- Memory: 2GB Micron MT40A512M8HX unbuffered 32-bit fixed DDR4 without ECC
- Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC
- Ethernet interfaces:
- one 1G RGMII port on-board(RTL8211F PHY)
- one 1G SGMII port on-board(RTL8211F PHY)
- one 2.5G SGMII port on-board(AQR105 PHY)
- PCIe: Two Mini-PCIe connectors on-board.
- SerDes: 4 lanes up to 10.3125GHz
- NOR: 128MB S29GL01GS110TFIV10 Spansion NOR Flash
- NAND: 512MB S34MS04G200BFI000 Spansion NAND Flash
- eSPI: 64MB S25FL512SAGMFI010 Spansion SPI flash.
- USB: one Type-A USB 2.0 port with internal PHY
- eSDHC: support SD/MMC card and eMMC on-board
- 256Kbit M24256 I2C EEPROM
- RTC: Real-time clock DS1339 on I2C bus
- UART: one serial port on-board with RJ45 connector
- Debugging: JTAG/COP for T1023 debugging
As well updated T1024RDB to add T1023RDB.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
[York Sun: fix defconfig files]
This patch adds SD boot support for T4240RDB board. SPL
framework is used. PBL initializes the internal RAM and
copies SPL to it. Then SPL initializes DDR using SPD and
copies u-boot from SD card to DDR, finally SPL transfers
control to u-boot.
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
[York Sun: Fix T4240RDB_SDCARD_defcofig]
T4240 SoC has been available for a long time. Emulator support
is no longer needed.
Signed-off-by: York Sun <yorksun@freescale.com>
Now that we've everything prepared for it remove the DM settings from the
defconfig(s) and simply always set them for sunxi.
This makes all sunxi boards allways use the driver model for gpios and
ethernet, and allows us to move over more bits to the driver-model without
the need to introduce #ifdef-ery for boards which are not yet using DM.
This is a preparation patch for switching all sunxi boards over to using
the driver model.
Note that rather then defining both CONFIG_DEFAULT_DEVICE_TREE (for u-boot)
and CONFIG_FDTFILE (for the kernel), this commit simply replaces all
CONFIG_FDTFILE defconfig settings with CONFIG_DEFAULT_DEVICE_TREE and
uses CONFIG_DEFAULT_DEVICE_TREE for setting the default fdtfile env value
in sunxi-common.h .
Move the axp-gpio code out of the drivers/power/axp*.c code, and into
a new separate axpi-gpio driver.
This change drops supports for the gpio3 pin on the axp209, as that requires
special handling, and no boards are using it.
Besides cleaning things up by moving the code to a separate driver, as
a bonus this change also adds support for the (non vusb) gpio pins on the
axp221 and the gpio pins on the axp152.
The new axp-gpio driver gets its own Kconfig option, and is only enabled
on boards which need it. Besides that it only gets enabled in the regular
u-boot build and not for the SPL as we never need it in the SPL.
Add a defconfig for generic 7" tablets using the Ippo q8h v1.2 pcb,
with an A33 SoC (the pcb can take an A23 or an A33), and a 1024x600 LCD.
