path: root/configs
2015-01-23powerpc: remove icecube_5200, Lite5200, cpci5200, mecp5200, pf5200Masahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2015-01-23powerpc: mpc5xxx: PM520 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Josef Wagner <Wagner@Microsys.de>
2015-01-23powerpc: mpc5xxx: remove Total5200 board supportMasahiro Yamada
2015-01-23powerpc: ppc4xx: remove PPChameleonEVB, CATcenter boardsMasahiro Yamada
These boards are still non-generic boards. It is a good thing that we can drop board-specific hack code from drivers/mtd/nand/nand_base.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
2015-01-23powerpc: mpc85xx: remove P2020DS board supportMasahiro Yamada
2015-01-23powerpc: mpc85xx: remove P2020COME board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Ira W. Snyder <iws@ovro.caltech.edu>
2015-01-23powerpc: mpc85xx: remove P1_P2_RDB boardsMasahiro Yamada
These boards are still non-generic boards: P1011RDB, P1022RDB, P2010RDB, P2020RDB Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
2015-01-23powerpc: mpc83xx: remove MPC8360ERDK, EMPC8360EMDS supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
2015-01-23Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-01-23sunxi: Add Hyundai A7HD supportHans de Goede
The Hyundai A7HD is a 7" 16:9 A10 powered tablet featuring 1G RAM, 8G nand, 1024x600 IPS screen, a mini hdmi port, mini usb receptacle and a headphones port for details see: http://linux-sunxi.org/Hyundai_A7HD Cc: Mark Janssen <maniac@maniac.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-23sunxi: Add support for Mele M5.Ian Campbell
HDMI, SATA, USB and Ethernet appear functional, I've not done extensive tests of all peripherals though. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-23sunxi: Convert sun7i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun7i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. This has been tested on a A20-Olinuxino-Lime, A20-Olinuxino_MICRO, Bananapi, Bananapro, Cubieboard2, Cubietruck, Mele_M3 and a Linksprite_pcDuino3. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-23sunxi: Drop qt840a_defconfigHans de Goede
The qt840a is one of the many tv-boxes using the "i12" A20 pcb, but it populates only one of the 2 places for a 16 bit dram ic, thus reducing the buswidth to 16 bits, and the amount of ram to 512M, which is why we had a separate config for it. This commit switches the generic i12-tvbox_defconfig over to DRAM autoconfiguration, so that it will work with the qt840a too, and drops the qt840a specific config, like we've done with other memory-amount specific configs before. Tested on a generic i12-tvbox with 32 bit bus-width / 1G RAM, and on a qt840a with 16 bit bus-width / 512M RAM. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-23sunxi: Add new Chuwi V7 CW0825 board / defconfigHans de Goede
The Chuwi V7 is an A10 (sun4i) based tablet with 1G of RAM, 16G of nand flash, microsd slot, 7" 1024x768 lvds ips panel, mini hdmi out, headphones out, stereo speakers, front & back camera and usb wifi. It is clearly marked "CHUWI", "V7" and "Model: CW0825" on the back of the tablet. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Hookup OTG USB controller supportHans de Goede
Hookup OTG USB controller support and enable the otg controller + USB-keyb on various tablets. This allows tablet owners to interact with u-boot without needing to solder a serial console onto their tablet PCB. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Add Gemei G9 (Allwinner A10/sun4i) tabletPriit Laes
Gemei G9 is an A10 based tablet, with 1G RAM, 16G NAND, 1024x768 IPS LCD display, stereo speakers, 1.3MP front camera and 5 MP rear camera, 8000mAh battery, GT901 2+1 touchscreen, Bosch BMA250 accelerometer and RTL8188CUS USB wifi. It also has MicroSD slot, miniHDMI, 1 x MicroUSB OTG port and 1 x MicroUSB host port and 3.5mm headphone jack. More details are available at: http://linux-sunxi.org/Gemei_G9 Signed-off-by: Priit Laes <plaes@plaes.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-22sunxi: Add Marsboard A10 supportAleksei Mamlin
This patch add support for Marsboard A10 board. The Marsboard A10 is a A10 based development board with 1G RAM, 1G NAND, micro SD card slot, SATA 2.0 socket, 10/100 ethernet, mini HDMI port, 1 USB OTG port and 2 USB 2.0 ports. Board does not use the AXP209 pmic, it does not have a pmic at all. Board also have 2 expansion 70 pin headers. Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-22sun6i: Add LCD display support for MSI Primo81 tabletSiarhei Siamashka
The MSI Primo81 tablet has B079XAN01/LP079X01 7.85" 768x1024 IPS MIPI display, connected to the parallel LCD interface via SSD2828 bridge chip. The panel has 18-bit color depth and needs dithering, in spite of having RGB data delivered from A31s to SSD2828 using 24-bit arrangement. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-22sunxi: Add mk802_a10s board / defconfigHans de Goede
The mk802_a10s re-uses is the "classic" mk802 case and functionality, but has an A10s SoC inside rather then the A10, it features 512M or 1G RAM, 4G nand, a mini-hdmi female connector, USB-A receptacle, mini-usb receptacle (OTG) and a sdio realtek wifi chip. Unlike the original mk802 it does have a pmic, the axp152. For more details see: http://linux-sunxi.org/Semitime_g2 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Add mk802ii board / defconfigHans de Goede
The mk802ii is a revised version of the mk802 A10 based hdmi tv-stick, it features 1G RAM, 4G nand, a hdmi male connector, USB-A receptacle, 2 micro usb receptacles (OTG & power) and USB-wifi, and does come with an axp209 pmic. For more details see: http://linux-sunxi.org/Rikomagic_mk802ii Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Add mk802 board / defconfigHans de Goede
The mk802 is the "classic" Allwinner A10 based hdmi tv-stick, it features 512M or 1G RAM, 4G nand, a mini-hdmi female connector, USB-A receptacle, mini-usb receptacle (OTG) and USB-wifi. Somewhat unique the mk802 does not use the AXP209 pmic, it does not have a pmic at all. For more details see: http://linux-sunxi.org/Rikomagic_mk802 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Remove CONFIG_TARGET_FOO for sun4i, sun6i and sun8i boardsHans de Goede
CONFIG_TARGET_FOO is only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), iow it is not used at all on any sun4i, sun6i and sun8i boards so lets get rid of it there. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Convert sun4i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun4i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. Tested-by: Hans de Goede <hdegoede@redhat.com> on a A10-OLinuXino-Lime, Chuwi_V7_CW0825 and ba10_tv_box Tested-by: Zoltan HERPAI <wigyori@uid0.hu> on a pcduino Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Stop differentiating between 512M and 1G variants of the same boardHans de Goede
While working on adding more boards I noticed that we lack a config for the 512M cubieboard, and that some of the new boards which I want to add also have 512M and 1G variants, rather then adding 2 defconfig's for all of these, lets switch the exising boards which have both a 512M and 1024M variant over to the sun4i dram autoconfig code. This also drops the foo_RAMSIZE_defconfig variants of boards where we currently have 2 separate configs already. Note: 1) The newly introduced CONFIG_DRAM_EMR1 kconfig value is not used with a value other then its default for now, but we need this to be configurable to support some new boards with auto dram config. 2) We always set all CONFIG_DRAM_foo values in defconfigs, even if they match the defaults, this is done to make it more clear what values are used for a certain board. This has been tested on a Mele A1000, Mini-X and a Cubieboard, all 1G variants, the dram autoconfig code has also been tested on a 512M mk802 (a defconfig for the mk802 is added in a later patch). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: ba10_tv_box_defconfig: Fix USB not workingHans de Goede
PH12 is Vbus enable for Vbus2, not Vbus1. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: display: Make lcd display clk phase configurableHans de Goede
While running some tests with an Olinuxino-A13-Micro + a 7" Olimex LCD module I noticed that the screen flickered. This is caused by the lcd display clk phase reg value being set to 0, where it should be 1 in this setup. This commit adds a Kconfig option for the lcd display clk phase, so that we can set it per board. This defaults to 1, because looking at all the fex files in sunxi-boards, that is by far the most used value. This commit updated the Ippo and MSI Primo73 tablet defconfigs to override the default of 1 with 0, as that is the correct value for those tablets, this keeps the register settings the same as before this commit. The Olinuxino-A13 defconfigs are not updated, changing the register setting for these boards from 0 to 1, this is intentional. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-16t1024qds: add missing T1024QDS_defconfigShengzhou Liu
Add missing T1024QDS_defconfig for NOR boot on T1024QDS. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-16powerpc: SECURE BOOT- Add secure boot target for T1042RDBgaurav rana
Secure boot target is added for T1042RDB platform. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-16powerpc/mpc85xx: SECURE BOOT- Add secure boot target for P5040DSgaurav rana
Secure boot target is added for P5040DS platform. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-16powerpc/c29xpcie: Add secure boot supportPo Liu
Add NOR and SPI flash secure boot target for C29XPCIE board. Signed-off-by: Po Liu <Po.Liu@freescale.com> Signed-off-by: Mingkai.Hu <Mingkai.Hu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2015-01-14Kconfig: move CONFIG_SYS_CLK_FREQ to KconfigAlexey Brodkin
It makes sense to specify CONFIG_SYS_CLK_FREQ in "configs/xx_defconfig" instead of "include/configs/xxx.h" because then header will be reusable across boards with different CPU clocks. Also this nice to have an ability for end user to tune this value himself via "menuconfig". For now I'm only applying this change to all ARC configs because otherwise scope of change will be huge. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Hans de Goede <hdegoede@redhat.com> cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2015-01-14Add support for Seagate BlackArmor NAS220Evgeni Dobrev
Add support for Seagate BlackArmor NAS220 Signed-off-by: Evgeni Dobrev <evgeni@studio-punkt.com>
2015-01-14sunxi: Hummingbird_A31_defconfig: Enable VGA output through external DACChen-Yu Tsai
The Hummingbird A31 uses an external DAC connected to the LCD0 outputs for the on board VGA output. The DAC has a power control that's toggled by GPIO. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sunxi: add Linksprite pcDuino v1/v2 supportZoltan HERPAI
Add support for a sun4i board built by Linksprite. This addition covers both v1 and v2 versions. As the board has been working with 408MHz memory setting in the u-boot-sunxi branch, and has been proven to be running stable during my tests as well, a respective new DRAM config file is added as well. Signed-off-by: Zoltan HERPAI <wigyori@uid0.hu> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sunxi: video: Add VGA output supportHans de Goede
Add support for VGA directly from the sunxi SoC / display engine. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Ippo_q8h defconfigs: Enable the LCD panel found on these tablets.Hans de Goede
Enable the new LCD support on Ippo_q8h tablets. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Tested-by: Chen-Yu Tsai <wens@csie.org>
2015-01-14sunxi: A13-OLinuXino defconfigs: Enable VGA output, add lcd-mode for 7" LCDHans de Goede
Enable VGA output on the A13-OLinuXino and A13-OLinuXinoM now that we've support for it. Also add LCD timing and gpio info for the Olimex 7" LCD module. We can safely put this in the default config on this boards, since by default we will always use VGA, and the LCD timing info will only get used if the user explicitly sets monitor=lcd in the video-mode env. variable. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun7i: Add new Bananapro board / defconfigHans de Goede
Add support for the new Bananapro A20 development board from lemaker.org. This board features 1G RAM, 2 USB A receptacles, 1 micro USB receptacle for OTG, 1 micro USB receptacle for power, HDMI, sata, Gbit ethernet, ir receiver, 3.5 mm jack for a/v out, on board microphone, 40 gpio pins and sdio wifi. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun7i: Add defconfig for MSI Primo73 tabletSiarhei Siamashka
This patch uses the same DRAM settings as in the pre-installed Android firmware. The LCD display is supported too. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sun6i: Add defconfig for MSI Primo81 tabletSiarhei Siamashka
This patch uses the same ZQ and DRAM clock settings as in the pre-installed Android firmware. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sun8i: Add defconfig for Ippo_q8h v1.2Hans de Goede
We need separate defconfigs for the v5 and v1.2 versions of this board, as they use different DRAM parameters. Note they also use different dtb files, as the wifi is different too. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun8i: Ippo_q8h_v5_defconfig: Enable SPL supportHans de Goede
Now that we've sun8i dram-init support we can enable the SPL for sun8i boards. While at it also replace CONFIG_DEFAULT_DEVICE_TREE with CONFIG_FDTFILE, the former is for u-boot's own fdt usage, which we do not use (yet), the later specifies the fdt to pass to the kernel, which is the one we want. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Make dcdc1 voltage configurableHans de Goede
The dcdc1 voltage is typically used as generic 3.3V IO voltage for things like GPIO-s, sdcard interfaces, etc. On most boards this is undervolted to 3.0V to safe battery, but not on all, make it configurable so that we can use the same settings as the original firmware on all boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Add Kconfig help and sane defaults for typical ldo usageHans de Goede
Some of the ldo-s of the axp221 are used in the same way on most boards, add comments to the Kconfig help text to reflect this, and give them defaults matching their typical usage. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add new board Merrii Hummingbird A31Chen-Yu Tsai
The Merrii Hummingbird A31 is a A31 based development board with 1G RAM, 8G NAND, AP6210 WiFi+BT, gigabit ethernet, USB OTG, 2 USB 2.0 ports connected to a USB hub chip, HDMI, VGA, TV and stereo in/out. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sun6i: Update Colombus defconfig settingsHans de Goede
The Colombus defconfig settings are missing a number of settings for recently added features, because we did not know exactly how things were hooked up. Maxime Ripard has run various tests to get us the necessary details, this commit updates the defconfig with this info. This commit also updates the dram clk and zq values with values verified by Maxime to be the ones used by the original firmware for this board. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add new CSQ_CS908 boardHans de Goede
The CSQ CS908 is an A31s based top-set box, with 1G RAM, 8G NAND, rtl8188etv usb wifi, 2 USB A receptacles (1 connected through the OTG controller), ethernet, 3.5 mm jack with a/v out and hdmi out: http://www.geekbuying.com/item/CS908-Allwinner-A31S-Quad-Core-1-2GHz-Android-4-4-Mini-TV-Box-HDMI-HDD-Player-1G-8G-WIFI-Miracast---Black-333395.html Note it has no sdcard slot and therefore can only be fel booted. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Make dram clk and zq value Kconfig optionsHans de Goede
It turns out that there is a too large spread between boards to handle this with a default value, turn this into Kconfig options, and set the values the factory images are using for the Colombus and Mele_M9 boards. Note this changes the ZQ default when not overriden through defconfig from 120 to 123, as that is what most boards seem to actually use. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-13Merge git://git.denx.de/u-boot-x86Tom Rini
