path: root/configs
2014-09-16vexpress64: kconfig: consolidate CONFIG_TARGET_VEXPRESS_AEMV8A_SEMIMasahiro Yamada
We do not have to distinguish CONFIG_TARGET_VEXPRESS_AEMV8A_SEMI from CONFIG_TARGET_VEXPRESS_AEMV8A. Rename the former to the latter. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Steve Rae <srae@broadcom.com> Cc: David Feng <fenghua@phytium.com.cn>
2014-09-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-09-09Merge branch 'u-boot-sunxi/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-09-08arm: ls102xa: Add basic support for LS1021ATWR boardWang Huan
LS102xA is an ARMv7 implementation. This patch is to add basic support for LS1021ATWR board. One DDR controller DUART1 is used as the console For the detail board information, please refer to README. Signed-off-by: Chen Lu <chen.lu@freescale.com> Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com>
2014-09-08arm: ls102xa: Add basic support for LS1021AQDS boardWang Huan
LS102xA is an ARMv7 implementation. This patch is to add basic support for LS1021AQDS board. One DDR controller DUART1 is used as the console For the detail board information, please refer to README. Signed-off-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Jason Jin <jason.jin@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Yuan Yao <yao.yuan@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-09-05sun7i: Add support for Olimex A20-OLinuXino-LIMEFUKAUMI Naoki
This patch adds support for Olimex A20-OLinuXino-LIME board. Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-09-05sunxi: Correct typo CONFIG_FTDFILE => CONFIG_FDTFILEIan Campbell
Patch is the result of: sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig Reported-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> [ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
2014-09-05kconfig: remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONSMasahiro Yamada
CONFIG_SPL is defined as a primary option in Kconfig. It should not be added to CONFIG_SYS_EXTRA_OPTIONS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-09-05odroid: kconfig: add odroid_defconfigPrzemyslaw Marczak
This config is valid for two devices: - Odroid X2, - Odroid U3. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-31mx6: tqma6: get board support back to Kconfig build systemMasahiro Yamada
The QS Systems TQMa6 board support was added by commit cb07d74e and lost by commit e82abaeb. Commit e82abaeb merged the IMX branch based on pre-Kconfig and the mainline based on post-Kconfig, simply deleting the boards.cfg file. As a result, some boards added just before the merge were lost. This commit adds Kconfig, defconfig, MAINTAINERS for TQMa6 board to work on the Kconfig infrastructure. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de>
2014-08-30nomadik: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Nomadik board select menu to nomadik/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="nomadik"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30highbank: kconfig: move common settingsMasahiro Yamada
Move Highbank-specific settings to highbank/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <robh@kernel.org>
2014-08-30orion5x: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Orion5x board select menu to orion5x/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="orion5x"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-30keystone: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Keystone board select menu to keystone/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="keystone"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com>
2014-08-30omap5: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP5 board select menu to omap5/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap5"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-30omap4: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP4 board select menu to omap4/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap4"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-08-30davinci: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Davinci board select menu to davinci/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="davinci"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com>
2014-08-30exynos: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Exynos board select menu to exynos/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="exynos"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-08-30versatile: kconfig: move common settingsMasahiro Yamada
Move Versatile-specific settings to versatile/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-08-30zynq: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Zynq board select menu to zynq/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="zynq"). Refactor board/xilinx/zynq/MAINTAINERS too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Michal Simek <michal.simek@xilinx.com>
2014-08-30arm: convert Cygnus and NSP boards to KconfigSteve Rae
Convert the bcm958300k and the bcm958622hr boards from "boards.cfg" to Kconfig. Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: bcm281xx: add board with Ethernet capabilitySteve Rae
Add board which has Broadcom StarFighter2 Ethernet capability. Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-29Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-08-29Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2014-08-29Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-08-29Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2014-08-28Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-08-25am335x_evm: Convert CONFIG_CONS_INDEX into a menu choiceTom Rini
- Drop CONFIG_SERIAL[1-6] and use CONFIG_CONS_INDEX tests instead - Add choice and help text to board/ti/am335x/Kconfig - Correct comment about IDK in board/ti/am335x/mux.c - Remove am335x_evm_uart* defconfig files as they're just variations on a config option now. Signed-off-by: Tom Rini <trini@ti.com>
2014-08-24nios2: remove obsolete PCI5441 and PK1C20 boardsThomas Chou
2014-08-21powerpc: mpc8xx: remove FLAGADM board supportMasahiro Yamada
This board has been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove GEN860T, GEN806T_SC board supportMasahiro Yamada
These boards have been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove SXNI855T board supportMasahiro Yamada
2014-08-21powerpc: mpc8xx: remove svm_sc8xx boardMasahiro Yamada
2014-08-21powerpc: mpc8xx: remove stxxtc board supportMasahiro Yamada
2014-08-21omap: remove omap5912osk board supportMasahiro Yamada
Emails to the board maintainer "Rishi Bhattacharya <rishi@ti.com>" have been bouncing. Tom suggested to remove this board. Remove also omap1510_udc.c because this is the last board to enable it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Tom Rini <trini@ti.com>
2014-08-20mx6sxsabresd: Convert to the new Kconfig styleFabio Estevam
mx6sxsabresd was not in the master branch when the conversion to the new Kconfig style happened, so convert it now so that it can build again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-08-19ARM: tegra: remove custom define for Jetson TK1Stephen Warren
Now that Kconfig has a per-board option, we can use that directly rather than inventing a custom define for the AS3722 code to determine which board it's being built for. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-08-18ARM: tegra: add Colibri T30 board supportStefan Agner
This adds board support for the Toradex Colibri T30 module. Working functions: - SD card boot - eMMC environment and boot - USB host/USB client (on the dual role port) - Network (via ASIX USB) Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-08-13Update aristainetos board to KconfigStefano Babic
aristainetos board was merged in u-boot-imx before Kconfig was integrated, but it is not yet mainline. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-08-12sunxi: Add environment settings to make extlinux.conf booting workHans de Goede
Automatic booting using an extlinux.conf file requires various environment variables to be set. Also modify CONFIG_SYS_LOAD_ADDR and CONFIG_STANDALONE_LOAD_ADDR to match the value chosen for kernel_addr_r, see the added comment for why the new value is chosen. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-07-31sun7i: Add bananapi boardHans de Goede
The Banana Pi is an A20 based development board using Raspberry Pi compatible IO headers. It comes with 1 GB RAM, 1 Gb ethernet, 2x USB host, sata, hdmi and stereo audio out + various expansion headers: http://www.lemaker.org/ Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31sun7i: Add support for a number of new sun7i boardsHans de Goede
Add support for boards which I own and which already have a dts file in the upstream kernel. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31sun5i: Add support for a number of new sun5i boardsHans de Goede
2014-07-31sun4i: Add support for a number of new sun4i boardsHans de Goede
2014-07-31sunxi: Enable EHCI on various sunxi boardsHans de Goede
Most sunxi boards have the EHCI controller hooked up, enable it on all relevant boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31cubieboard2: Enable AXP209 power controllerIan Campbell
Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
