path: root/configs
2016-03-09MIPS: pic32mzdask: use CONFIG_USE_PRIVATE_LIBGCC=yDaniel Schwierzeck
MIPS EL boards should define CONFIG_USE_PRIVATE_LIBGCC=y to work with EB-only toolchains like the one from kernel.org. If one do not globally set CONFIG_USE_PRIVATE_LIBGCC=y, the build fails with: /opt/gcc-4.9.0-nolibc/mips-linux/bin/mips-linux-ld.bfd: /opt/gcc-4.9.0-nolibc/mips-linux/bin/../lib/gcc/mips-linux/4.9.0/libgcc.a(_lshrdi3.o): compiled for a big endian system and target is little endian /opt/gcc-4.9.0-nolibc/mips-linux/bin/mips-linux-ld.bfd: /opt/gcc-4.9.0-nolibc/mips-linux/bin/../lib/gcc/mips-linux/4.9.0/libgcc.a(_lshrdi3.o): endianness incompatible with that of the selected emulation /opt/gcc-4.9.0-nolibc/mips-linux/bin/mips-linux-ld.bfd: failed to merge target specific data of file /opt/gcc-4.9.0-nolibc/mips-linux/bin/../lib/gcc/mips-linux/4.9.0/libgcc.a(_lshrdi3.o) /opt/gcc-4.9.0-nolibc/mips-linux/bin/mips-linux-ld.bfd: /opt/gcc-4.9.0-nolibc/mips-linux/bin/../lib/gcc/mips-linux/4.9.0/libgcc.a(_ashldi3.o): compiled for a big endian system and target is little endian /opt/gcc-4.9.0-nolibc/mips-linux/bin/mips-linux-ld.bfd: /opt/gcc-4.9.0-nolibc/mips-linux/bin/../lib/gcc/mips-linux/4.9.0/libgcc.a(_ashldi3.o): endianness incompatible with that of the selected emulation /opt/gcc-4.9.0-nolibc/mips-linux/bin/mips-linux-ld.bfd: failed to merge target specific data of file /opt/gcc-4.9.0-nolibc/mips-linux/bin/../lib/gcc/mips-linux/4.9.0/libgcc.a(_ashldi3.o) /work/git-trees/u-boot-mips/Makefile:1171: recipe for target 'u-boot' failed One example for a failing build is Travis CI. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Purna Chandra Mandal <purna.mandal@microchip.com>
2016-03-08OMAP3: am3517_evm: Add NAND MTD partitions with UBI/UBIFS supportDerald D. Woods
- Add required UBI/UBIFS config definitions - Add reasonable MTD partition layout - Remove JFFS2 config definitions - Drop some CFI verbage and definitions - Make comment 'one-liners' truly one line - Improve readability and content arrangement Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-29sniper: Various minor cleanups, missing Kconfig configs and reorganisationPaul Kocialkowski
This introduces some minor cleanups, regarding aspects such as board name, code and headers organization as well as deprecated and missing config options. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-29ARM: uniphier: rework UniPhier SoC select in KconfigMasahiro Yamada
The chains of "depends on <SoC_name>" in the current Kconfig is clumsy. The idea here is to allow users to choose a SoC group first (SoC group consists of some SoCs that can coexist in one binary). Then, allow to enable/disable each SoC support in the selected SoC group. This makes the Kconfig menu clearer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: merge two defconfig filesMasahiro Yamada
PH1-Pro5 support and ProXstream2/PH1-LD6b support can coexist in one image and there is bit more room in SPL to accommodate all of them. Merge uniphier_pro5_defconfig into uniphier_pxs2_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: enable UniPhier SD/MMC host driverMasahiro Yamada
Enable the driver in all UniPhier defconfig files and add some needed defines to the common files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-29ARM: uniphier: enable GPIO command and driver for UniPhier SoCsMasahiro Yamada
This allows to use the "gpio" command. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-26sandbox: Enable the early timerSimon Glass
Enable this so that tracing works with sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-26sandbox: Correct ordering of defconfigSimon Glass
This has got out of order: fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-02-24arm: am437x: cm-t43: define promptNikita Kiryanov
Define prompt for cm-t43. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24arm: am437x: cm-t43: support all available SPI flash chipsNikita Kiryanov
Add full support for SPI flash chips to future-proof U-Boot for cm-t43. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24arm: am437x: cm-t43: migrate CONFIG_DM_SERIAL to config fileNikita Kiryanov
Move CONFIG_DM_SERIAL to cm_t43_defconfig. This forces us to update the CONFIG_SYS_NS16550_REG_SIZE value for SPL. Cc: Tom Rini <trini@konsulko.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: move everything possible from board's headerfile to KConfigHannes Schmelzer
We drop everything possible things from board headerfiles and replace this functionality with responsible settings in Kconfig (_defconfig). Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24board/BuR: use default u-boot prompt on all B&R boardsHannes Schmelzer
There is no need to have some specific prompt, so we drop this within defconfigs. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-24stm32: add support for stm32f7 & stm32f746 discovery boardVikas Manocha
This patch adds support for stm32f7 family & stm32f746 board. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-02-24arm: ls1021a: Add QSPI or IFC support in SD boot for LS1021AQDS boardAlison Wang
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported in SD boot now. For the customer's demand, QSPI needs to be supported in SD boot too. This patch adds QSPI or IFC support in SD boot according to the corresponding defconfig. For detail, ls1021aqds_sdcard_ifc_defconfig is used to support IFC in SD boot and ls1021aqds_sdcard_qspi_defconfig is used to support QSPI in SD boot. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-02-24arm: ls1021aqds: Enable driver model lpuart serial driverYork Sun
Convert ls1021aqds_nor_lpuart and ls1021aqds_ddr4_nor_lpuart to driver model suport. Enable lpuart port driver. Signed-off-by: York Sun <york.sun@nxp.com> CC: Alison Wang <alison.wang@nxp.com> CC: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2016-02-23Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2016-02-23sunxi: H3: Add support for the host usb-physJelle van der Waa
Add support for phy 1-3. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> [hdegoede@redhat.com: use setclrbits_le32 instead of read-modify-write] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-02-23sunxi: power: add support for sy8106a driverJelle van der Waa
SY8106A is a PMIC which is used on the Allwinner H3 Orange Pi Pc and Plus board. The VOUT1_SEL register is implemented to set the default V-CPU voltage to 1200 mV. This driver is required to ensure the SY8106A V-CPU voltage is set to 1200 mV after a software reset. On cold boot the default SY8106A output voltage is selected to be 1200 mV by a pair of resistors on the Orange Pi PC and Plus. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Tested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-02-23arm: ls1021aqds: Convert to driver model and enable serial supportYork Sun
Split duart configuration as device tree file. Move /chosen node out of board commone device tree. Convert ls1021aqds nor and SD configurations to driver model support (qspi already uses DM). Enable ns16550 DM serial driver for nor configurations. Signed-off-by: York Sun <york.sun@nxp.com> CC: Alison Wang <alison.wang@nxp.com> CC: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Alison Wang <alison.wang@nxp.com>
2016-02-23Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2016-02-23defconfig: am437x_sk_evm: enable dma driver modelMugunthan V N
enable dma driver model for am437x_sk_evm as ti-edma3 supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-02-22mmc: Kconfig: Add Arasan SDHCI entryMichal Simek
Add Arasan SDHCI entry to Kconfig and fix all references. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-02-21Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-02-21imx: mx7d: isolate resources to domain 0 for A7 corePeng Fan
In current design, if any peripheral was assigned to both A7 and M4, it will receive ipg_stop or ipg_wait when any of the 2 platforms enter low power mode. We will have a risk that, if A7 enter wait, M4 enter stop, peripheral will have chance to get ipg_stop and ipg_wait asserted same time. Also if M4 enters stop mode, A7 will have no chance to access the peripheral. There are 26 peripherals affected by this IC issue: SIM2(sim2/emvsim2) SIM1(sim1/emvsim1) UART1/UART2/UART3/UART4/UART5/UART6/UART7 SAI1/SAI2/SAI3 WDOG1/WDOG2/WDOG3/WDOG4 GPT1/GPT2/GPT3/GPT4 PWM1/PWM2/PWM3/PWM4 ENET1/ENET2 Software Workaround: The solution is to set the peripherals to Domain0 by A core, since A core in Domain0. The peripherals which will be used by M4, will be set to Domain1 by M4. For example, A core set WDOG4 to domain0, but when M4 boots up, M4 will set WDOG4 to domain1, because M4 will use WDOG4. So the peripherals are not shared by them. This way requires the uboot implemented the RDC driver and set the 26 IPs above to domain 0 only. M4 image will set the M4 to domain 1 and set peripheral which it will use to domain 1. This patch enables the CONFIG_IMX_RDC and CONFIG_IMX_BOOTAUX for i.MX7D SABRESD board, and setup the 26 IP resources to domain 0. Signed-off-by: Ye.Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2016-02-21x86: Add Intel Cougar Canyon 2 boardBin Meng
This adds basic support to Intel Cougar Canyon 2 board, a board based on Chief River platform with an Ivy Bridge processor and a Panther Point chipset. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-20Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-02-20arc: cache - accommodate different L1 cache line lengthsAlexey Brodkin
ARC core could be configured with different L1 and L2 (AKA SLC) cache line lengths. At least these values are possible and were really used: 32, 64 or 128 bytes. Current implementation requires cache line to be selected upon U-Boot configuration and then it will only work on matching hardware. Indeed this is quite efficient because cache line length gets hardcoded during code compilation. But OTOH it makes binary less portable. With this commit we allow U-Boot to determine real L1 cache line length early in runtime and use this value later on. This extends portability of U-Boot binary a lot. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-02-19ARM: Add Support for the VInCo platformGregory CLEMENT
The Versatile Industrial Communication platform is a community oriented board from Landis + Gyr. It comes with: - an RS-485 port - 2 Ethernet ports - a wireless M-BUS - a 4G modem - a 4MB SPI flash - a 4GB eMMC Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> [rebase on current TOT] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-18arm: at91: Add support for DENX MA5D4 SoM and EVKMarek Vasut
Add support for DENX MA5D4 SoM and MA5D4EVK board, based on the Atmel SAMA5D4 SoC. The SoM contains the SoC, eMMC, SPI NOR, SPI CAN controllers and DRAM, the baseboard contains UART connectors, ethernet port, microSD slot, LCD header, 2x CAN connector and a lot of expansion headers. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-18siemens,at91: enable features for smartwebMatthias Michel
New features for smartweb: * switch to hush command parser * change autoboot stop to <ESC><ESC> * allow to write ethaddr Signed-off-by: Matthias Michel <matthias.michel@siemens.com> Reviewed-by: Samuel Egli <samuel.egli@siemens.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-16tegra: Convert CONFIG_PWM_TEGRA to KconfigSimon Glass
Move this option to Kconfig and clean up the header files. Adjust the only user (the LCD driver) to work with the new driver. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Convert tegra20 LCD driver to driver modelSimon Glass
Move this driver over to use driver model. This involves rearranging the code somewhat. The effect is that everything is run from the probe() method. Boards which use this are fixed up, but only seaboard is tested. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: video: Rename CONFIG_VIDEO_TEGRA to CONFIG_VIDEO_TEGRA20Simon Glass
This option refers only to the tegra20 video driver, so name it as such to avoid confusion with tegra124. Also move this option to Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-16tegra: nyan-big: Move the LCD driver to driver modelSimon Glass
Adjust the driver to use driver model. The SOR becomes a bridge device. We use the normal simple_panel driver to handle the display itself. We also need to enable some options such as regulators, PWMs and DM_VIDEO itself. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-02-14Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-02-14ARM: uniphier: switch over to generic EHCI driverMasahiro Yamada
The UniPhier EHCI driver (drivers/usb/host/ehci-uniphier.c) does nothing special but set the base address and handle reset/clock. Since commit 4feefdcfe916 ("usb: add clock support for generic EHCI"), the generic one (drivers/usb/host/ehci-generic.c) can do those, too. We no longer need to stick to the dedicated driver. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-12zynqmp: nand: Add Nand driver support for zynqmpSiva Durga Prasad Paladugu
Add nand driver support for zynqmp. The Nand controller used in ZynqMP is Arasan Nand Flash controller. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> [scottwood: Fix checkpatch warning] Signed-off-by: Scott Wood <oss@buserror.net>
2016-02-08defconfig: k2g_evm_defconfig: enable net driver modelMugunthan V N
enable net driver model for k2g evm as keystone_net supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-08defconfig: k2e_evm_defconfig: enable net driver modelMugunthan V N
enable net driver model for k2e evm as keystone_net supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-08defconfig: k2l_evm_defconfig: enable net driver modelMugunthan V N
enable net driver model for k2l evm as keystone_net supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-08defconfig: k2hk_evm_defconfig: enable net driver modelMugunthan V N
enable net driver model for k2hk evm as keystone_net supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-08OMAP3_LOGIC: Setup defconfig to enable SPL and NAND bootingAdam Ford
The defconfig patch will enable the the SPL and NAND settings. The update to Kconfig will allow the SPL to configured in and built. Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingTom Rini
2016-02-06ppc: xilinx-ppc405-genericRicardo Ribalda
Fix device tree name: +(xilinx-ppc405-generic) Device Tree Source is not correctly specified. +(xilinx-ppc405-generic) Please define 'CONFIG_DEFAULT_DEVICE_TREE' +(xilinx-ppc405-generic) or build with 'DEVICE_TREE=<device_tree>' argument +(xilinx-ppc405-generic) make[2]: *** [arch/powerpc/dts/xilinx-ppc440-generic.dtb] Error 1 +(xilinx-ppc405-generic) make[1]: *** [dts] Error 2 Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-06rockchip: Drop old CONFIG_VIDEO_ROTATION optionSimon Glass
The option was renamed to CONFIG_CONSOLE_ROTATION and Rockchip boards were not updated. However this option is is not needed by default for Rockchip since we don't need a rotated console for current boards. So just remove the old option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-05x86: chromebox_panther: Convert to use driver model ethernetBin Meng
This board uses RTL8169 which is a driver model ethernet driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-05efi: app: Clean up defconfigBin Meng
Move some #undef from efi-x86.h to efi-x86_defconfig as these are already Kconfig options. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
