path: root/configs
2022-04-12tbs2910: Convert to DM_SERIALFabio Estevam
Conversion to DM_SERIAL is mandatory. Select DM_SERIAL and add a imx6q-tbs2910-u-boot.dtsi file that describes the nodes that require dm-pre-reloc, which allows the DM model to configure the UART pinctrl early. Remove the now unneeded board UART initialization. Signed-off-by: Fabio Estevam <festevam@denx.de> Tested-by: Soeren Moch <smoch@web.de>
2022-04-12warp7: Remove UART initialization codeFabio Estevam
With DM_SERIAL selected, it is no longer needed board code to initialize the UART. Describe the nodes that require dm-pre-reloc, which allows the DM model to configure the UART pinctrl early. Remove the now unneeded board UART initialization. Signed-off-by: Fabio Estevam <festevam@denx.de>
2022-04-12board: gateworks: gw_ventana: convert to DM_I2CTim Harvey
convert to DM_I2C for U-Boot while leaving SPL legacy I2C: - Move I2C config from common to SPL - Move PMIC config from common to SPL (no need to re-configure pmic) - add DM_I2C support to eeprom/gsc functions shared by SPL and U-Boot Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2022-04-12ARM: imx: imx8mn-evk: enable DM_SERIALHeiko Thiery
U-Boot complains that CONFIG_SERIAL is not converted to CONFIG_DM_SERIAL and gives a deadline before possibly removing the board. Migrate to DM_SERIAL to fulfill the request. Signed-off-by: Heiko Thiery <heiko.thiery@gmail.com> Reviewed-by: Fabio Estevam <festevam@denx.de>
2022-04-12configs: imx6dl_mamoj_defconfig: Enable LTO on imx6dl_mamoj boardMichael Trimarchi
Enable LTO on mamoj to reduce SPL and uboot size. Tested with gcc gcc-11.1.0 U-Boot 2022.04-rc4-00051-g17fc5facd0 (Mar 23 2022 - 16:43:43 +0100) CPU: Freescale i.MX6DL rev1.3 996 MHz (running at 792 MHz) CPU: Extended Commercial temperature grade (-20C to 105C) at 40C Reset cause: POR Model: BTicino i.MX6DL Mamoj board DRAM: 512 MiB Core: 29 devices, 12 uclasses, devicetree: separate MMC: FSL_SDHC: 2 Loading Environment from MMC... OK In: serial Out: serial Err: serial Net: Error: ethernet@2188000 address not set. No ethernet found. Tested-by: Raffaele RECALCATI <raffaele.recalcati@bticino.it> Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com> Reviewed-by: Fabio Estevam <festevam@denx.de>
2022-04-12PPC: Enable Job ring driver model.Gaurav Jain
removed sec_init() call from board files. sec is initialized based on job ring information processed from device tree. Signed-off-by: Gaurav Jain <gaurav.jain@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2022-04-12Layerscape: Enable Job ring driver model.Gaurav Jain
LS(1021/1012/1028/1043/1046/1088/2088), LX2160, LX2162 platforms are enabled with JR driver model. removed sec_init() call from board files. sec is initialized based on job ring information processed from device tree. Signed-off-by: Gaurav Jain <gaurav.jain@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: Michael Walle <michael@walle.cc>
2022-04-12mx6sabre: Remove unnecessary SPL configsYe Li
Because we don't use SPL_DM on mx6sabresd and mx6sabreauto, so it is unnecessary to have SPL DTB related configs and SPL_OF_CONTROL enabled. Signed-off-by: Ye Li <ye.li@nxp.com> Reviewed-by: Fabio Estevam <festevam@denx.de> Reviewed-by: Gaurav Jain <gaurav.jain@nxp.com>
2022-04-12LS1043ARDB, LS1046ARDB, LS1088ARDB: Enable SPL_OF_CONTROL in SECURE Boot ↵Kshitiz Varshney
defconfig If enable SPL_DM without SPL_OF_CONTROL, build errors "undefined reference to fdt_get_resource", is coming in function `caam_jr_probe'. Added SPL_OF_CONTROL to remove the error. Signed-off-by: Kshitiz Varshney <kshitiz.varshney@nxp.com>
2022-04-08configs: Resync with savedefconfigTom Rini
2022-04-08Convert CONFIG_FSL_QIXIS et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_FSL_QIXIS CONFIG_QIXIS_I2C_ACCESS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-08Convert CONFIG_DIMM_SLOTS_PER_CTLR to KconfigTom Rini
This converts the following to Kconfig: CONFIG_DIMM_SLOTS_PER_CTLR Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-08spi: cadence_qspi: Migrate CONFIG_CQSPI_REF_CLK to KconfigTom Rini
This is a little tricky since SoCFPGA has code to determine this as runtime. Introduce a guard variable for platforms to select if they have a static value to use. Then for ARCH_SOCFPGA, call cm_get_qspi_controller_clk_hz() and otherwise continue the previous behavior. Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-08Convert CONFIG_SH_SCIF_CLK_FREQ to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SH_SCIF_CLK_FREQ Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-08Convert CONFIG_CMDLINE_PS_SUPPORT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CMDLINE_PS_SUPPORT Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-08Convert CONFIG_BOARD_SIZE_LIMIT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOARD_SIZE_LIMIT To do this, introduce CONFIG_HAS_BOARD_SIZE_LIMIT. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-05power: Rename CONFIG_POWER_TPS65217 with CONFIG_PMIC_TPS65217Lukasz Majewski
Up till now the CONFIG_POWER_TPS65217 has been defined in several header files for am335x SoC. This patch renames it to CONFIG_PMIC_TPS65217, which better reflects the role of this IC circuit. Moreover, new CONFIG_PMIC_TPS65217 has been introduced in Kconfig to be used with boards, which both support DM_PMIC and DM_I2C. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> [trini: Migrate all other platforms as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-05Merge branch '2022-04-04-platform-updates'Tom Rini
- Updates for exynos78x0 and TI K3 platforms
2022-04-05Merge tag 'xilinx-for-v2022.07-rc1-v2' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-microblaze Xilinx changes for v2022.07-rc1 v2 xilinx: - Allow booting bigger kernels till 100MB zynqmp: - DT updates (reset IDs) - Remove unneeded low level uart initialization from psu_init* - Enable PWM features - Add support for 1EG device serial_zynq: - Change fifo behavior in DEBUG mode zynq_sdhci: - Fix BASECLK setting calculation clk_zynqmp: - Add support for showing video clock gpio: - Update slg driver to handle DT flags net: - Update ethernet_id code to support also DM_ETH_PHY - Add support for DM_ETH_PHY in gem driver - Enable dynamic mode for SGMII config in gem driver pwm: - Add driver for cadence PWM versal: - Add support for reserved memory firmware: - Handle PD enabling for SPL - Add support for IOUSLCR SGMII configurations include: - Sync phy.h with Linux - Update xilinx power domain dt binding headers
2022-04-05Merge branch 'master' of https://source.denx.de/u-boot/custodians/u-boot-sunxiTom Rini
A big part is the DM pinctrl driver, which allows us to get rid of quite some custom pinmux code and make the whole port much more robust. Many thanks to Samuel for that nice contribution! There are some more or less cosmetic warnings about missing clocks right now, I will send the trivial fixes for that later. Another big chunk is the mkimage upgrade, which adds RISC-V and TOC0 (secure images) support. Both features are unused at the moment, but I have an always-secure board that will use that once the DT lands in the kernel. On top of those big things we have some smaller fixes, improving the I2C DM support, fixing some H6/H616 early clock setup and improving the eMMC boot partition support. The gitlab CI completed successfully, including the build test for all 161 sunxi boards. I also boot tested on a A64, A20, H3, H6, and F1C100 board. USB, SD card, eMMC, and Ethernet all work there (where applicable).
2022-04-05sunxi: defconfig: enable eMMC boot partition supportAndre Przywara
Now that the SPL can safely detect whether it was loaded from an eMMC boot partition or the normal user data partition, let's enable this feature on some boards that feature eMMC storage. That covers the boards where I could test this on, and allows the same build to be written to an SD card, eMMC user partition, eMMC boot partition, or into SPI NOR flash. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2022-04-04configs: am64x_evm_r5: Add CONFIG_NR_DRAM_BANKS as done in a53 defconfigDave Gerlach
Add CONFIG_NR_DRAM_BANKS from am64x_evm_a53_defconfig as this is needed to calculate the size of DDR that is available. Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
2022-04-04configs: am64x_evm_a53_defconfig: Switch to per-cpu timer as tick providerVignesh Raghavendra
On arm64 systems, recommendation is to use per-cpu timer for time keeping. Currently AM64 ends up using DM timer as tick timer as driver is enabled in the config. Drop OMAP DM Timer related configs, this will switch to using armv8 per-cpu timer as tick timer for A53 SPL/U-Boot. Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com> Reviewed-By: Nishanth Menon <nm@ti.com>
2022-04-04configs: am64x_evm_r5_defconfig: Add support for ESMHari Nagalla
Enable ESM driver for AM64x R5 SPL/u-boot builds. Signed-off-by: Hari Nagalla <hnagalla@ti.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2022-04-04board: axy17lte: get board usable - add bootcmd and docsDzmitry Sankouski
U-boot is intended to replace linux kernel in android boot image(ABL), and it's FIT payload to replace initramfs file. The boot process is similar to boot image with linux: - android bootloader (ABL) unpacks android boot image - ABL sets `linux,initrd-start property` in chosen node in unpacked FDT - ABL sets x0 register to FDT address, and passes control to u-boot - u-boot reads x0 register, and stores it in `prevbl_fdt_addr` env variable - u-boot reads `linux,initrd-start` property, and stores it in `prevbl_initrd_start_addr` In this way, u-boot bootcmd relies on `prevbl_initrd_start_addr` env variable, and boils down to `bootm $prevbl_initrd_start_addr`. If more control on boot process is desired, pack a boot script in FIT image, and put it to default configuration What done: - Rearrange defconfig option order - Add CONFIG_SAVE_PREV_BL_* options - Doc updates: - remove wrong SBOOT memory corruption note, because memory is changed during u-boot bringup process, not by SBOOT - put payload on ramdisk place in abl boot image creation step Signed-off-by: Dzmitry Sankouski <dsankouski@gmail.com>
2022-04-04board: starqltechn: get board usable - add bootcmd and docsDzmitry Sankouski
U-boot is intended to replace linux kernel in android boot image(ABL), and it's FIT payload to replace initramfs file. The boot process is similar to boot image with linux: - android bootloader (ABL) unpacks android boot image - ABL sets `linux,initrd-start property` in chosen node in unpacked FDT - ABL sets x0 register to FDT address, and passes control to u-boot - u-boot reads x0 register, and stores it in `prevbl_fdt_addr` env variable - u-boot reads `linux,initrd-start` property, and stores it in `prevbl_initrd_start_addr` In this way, u-boot bootcmd relies on `prevbl_initrd_start_addr` env variable, and boils down to `bootm $prevbl_initrd_start_addr`. If more control on boot process is desired, pack a boot script in FIT image, and put it to default configuration What done: - strip unneeded config options - add FIT image support - add framebuffer node, u-boot logo and video console - increase LMB_MAX_REGIONS, to store all linux dtb reserved memory regions - add linux kernel image header Uart driver causes hang, when u-boot is used in android boot image instead of linux. Temporary disable console driver, until investigated and fixed. Signed-off-by: Dzmitry Sankouski <dsankouski@gmail.com> Cc: Ramon Fried <rfried.dev@gmail.com>
2022-04-04Merge branch 'next'Tom Rini
2022-04-04Merge tag 'u-boot-at91-2022.07-a' of ↵Tom Rini
https://source.denx.de/u-boot/custodians/u-boot-at91 into next First set of u-boot-at91 features for the 2022.07 cycle: This feature set includes the new driver for the Atmel TCB timer, alignment in DT for sama7g5 and sama7g5ek board, one Kconfig conversion for external reset, and the usage of Galois tables from ROM for sama5d2 device.
2022-04-01vexpress64: Add ARMv8R-64 board variantPeter Hoyes
The ARMv8-R64 architecture introduces optional VMSA (paging based MMU) support in the EL1/0 translation regime, which makes that part mostly compatible to ARMv8-A. Add a new board variant to describe the "BASE-R64" FVP model, which inherits a lot from the existing v8-A FVP support. One major difference is that the memory map in "inverted": DRAM starts at 0x0, MMIO is at 2GB [1]. * Create new TARGET_VEXPRESS64_BASER_FVP target, sharing most of the exising configuration. * Implement inverted memory map in vexpress_aemv8.h * Create vexpress_aemv8r defconfig * Provide an MMU memory map for the BASER_FVP * Update vexpress64 documentation At the moment the boot-wrapper is the only supported secure firmware. As there is no official DT for the board yet, we rely on it being supplied by the boot-wrapper into U-Boot, so use OF_HAS_PRIOR_STAGE, and go with a dummy DT for now. [1] https://developer.arm.com/documentation/100964/1114/Base-Platform/Base---memory/BaseR-Platform-memory-map Signed-off-by: Peter Hoyes <Peter.Hoyes@arm.com> [Andre: rebase and add Linux kernel header] Signed-off-by: Andre Przywara <andre.przywara@arm.com> [trini: Add MAINTAINERS entry for Peter]
2022-04-01vexpress64: defconfigs: allow default commandsAndre Przywara
Right now the defconfig the Arm VExpress64 boards disables quite some standard commands, for apparently no good reasons (as image size is hardly a concern here). Remove the lines explicitly disabling those features, leaving it to the U-Boot default settings to set them. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2022-04-01vexpress64: fvp: add distro_boot supportAndre Przywara
So far the FVP model just supports booting through semihosting, so by loading files from the host the model is running on. This allows for quick booting of new kernels (or replacing DTBs), but prevents more featureful boots like using UEFI. Enable the distro_boot feature, and provide a list of possible boot sources that U-Boot should check: - For backwards compatibility we start with semihosting, which gets its commands migrated from CONFIG_BOOTCOMMAND into the distro_boot infrastructure. This is also slightly tweaked to fail graceful in case the required files could not be found. - Next we try to use a user provided script, that could be easily placed into memory using the model command line. - Since we gained virtio support with the enablement of OF_CONTROL, let's check virtio block devices next. This is where UEFI boot can be easily used, for instance by providing a distro installer .iso file through virtio-blk. - Networking is now provided by virtio as well, so enable the default PXE and DHCP boot flows, mostly because we can. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2022-04-01vexpress64: move hardware setting from defconfig to KconfigAndre Przywara
The defconfigs for the Arm Juno board and the FVP model are quite large, setting a lot of platform-fixed variables like SYS_TEXT_BASE. As those values are not really a user choice, let's provide default values for them in our Kconfig file, so a lot of cruft can be removed from the defconfig files. This also moves the driver selection out of there, since this is again not something a user should really decide on. Instead we allow users to enable or disable subsystems, and select the appropriate drivers based on that in the Kconfig file. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2022-04-01vexpress64: fvp: enable OF_CONTROLAndre Przywara
The FVP base model is relying on a DT for Linux operation, so there is no reason we would need to rely on hardcoded information for U-Boot. Letting U-Boot use a DT will open up the usage of actual peripherals, beyond the support for semihosting only. Enable OF_CONTROL in the Kconfig, and use the latest dts files from Linux. Depending on whether we use the boot-wrapper or TF-A, there is already a DTB provided or not, respectively. To cover the boot-wrapper, we add an arm64 Linux kernel header, which allows the boot-wrapper to treat U-Boot like a Linux kernel. U-Boot will find the pointer to the DTB in x0, and will use it. Even though TF-A carries a DT, at the moment this is not made available to non-secure world, so to not break users, we use the U-Boot provided DTB copy in that case. For some reason TF-A puts some DT like structure at the address x0 is pointing at, but that is very small and doesn't carry any hardware information. Make the code to ignore those small DTBs. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2022-04-01vexpress64: Kconfig: move board definitions out of arch/armAndre Przywara
At the moment we define three "VExpress64" boards in arch/arm/Kconfig, plus have a second Kconfig file in board/armltd/Kconfig. One of those three boards is actually bogus (TARGET_VEXPRESS64_AEMV8A), that stanza looks like being forgotten in a previous cleanup. To remove the clutter from the generic Kconfig file, just define some ARCH_VEXPRESS64 symbol there, enable some common options, and do the board/model specific configuration in the board/armltd Kconfig file. That allows to streamline and fine tune the configuration later, and to also pull a lot of "non user choices" out of the defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2022-04-01configs: Resync with savedefconfigTom Rini
2022-04-01Convert CONFIG_SYS_MONITOR_BASE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MONITOR_BASE Note that for how this is re-used on some PowePC platforms, we introduce CONFIG_SPL_SYS_MONITOR_BASE and CONFIG_TPL_SYS_MONITOR_BASE and use the CONFIG_VAL macro to get the correct value at build time, in the code. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_NORFLASH_PS32BIT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_NORFLASH_PS32BIT Note that we also attempt to correct the behavior of the code here, which had been testing for "NORFLASH_PS32BIT" which would never be set, instead check for the now set "CONFIG_NORFLASH_PS32BIT", which results in some behavior change. Cc: TsiChung Liew <Tsi-Chung.Liew@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01at91: Switch to SD_BOOT / CONFIG_NAND_BOOTTom Rini
The values CONFIG_SYS_USE_NANDFLASH and CONFIG_SYS_USE_MMC serve the same purpose as CONFIG_SD_BOOT / CONFIG_NAND_BOOT so migrate to using these switches instead as they're already in Kconfig. Cc: Stelian Pop <stelian@popies.net> Cc: Heiko Schocher <hs@denx.de> Cc: Daniel Gorsulowski <daniel.gorsulowski@esd.eu> Cc: Eugen Hristev <eugen.hristev@microchip.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_SRIO_PCIE_BOOT_SLAVE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SRIO_PCIE_BOOT_SLAVE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_DEEP_SLEEP to KconfigTom Rini
This converts the following to Kconfig: CONFIG_DEEP_SLEEP Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01M5329EVB, M5373EVB: Remove CONFIG_NANDFLASH_SIZETom Rini
In the case of M5373EVB we always had NANDFLASH_SIZE=16, so just use it directly. In the case of M5329EVB we had not removed the rest of NAND support when saying we didn't have NAND, so instead use that to key off of rather than NANDFLASH_SIZE. Cc: TsiChung Liew <Tsi-Chung.Liew@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_CLOCKS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CLOCKS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_CLOCK_SYNTHESIZER to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CLOCK_SYNTHESIZER Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_SYS_USE_NORFLASH et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_USE_NORFLASH CONFIG_SYS_USE_BOOT_NORFLASH Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01global: Remove CONFIG_SYS_USE_DATAFLASH*Tom Rini
There are a handful of variants around CONFIG_SYS_USE_DATAFLASH and none of them now control anything further within their board config.h files, so remove these from CONFIG_SYS_EXTRA_OPTIONS and then remove the empty blocks in the board config.h files. In a few places further clean up related logic. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_SDCARD et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SDCARD CONFIG_SPIFLASH Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01am43xx_evm_qspiboot: Remove CONFIG_SYS_EXTRA_OPTIONSTom Rini
CONFIG_QSPI is not used in the code, drop this. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01MPC837XERDB: Move CONFIG_PCIE to KconfigTom Rini
Move this symbol to the board Kconfig file. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_LPUART et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_LPUART CONFIG_LPUART_32B_REG And note that CONFIG_LPUART_32B_REG is unused in code. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-01Convert CONFIG_LSCHLV2 to Kconfig et alTom Rini
This converts the following to Kconfig: CONFIG_LSCHLV2 CONFIG_LSXHL Cc: Michael Walle <michael@walle.cc> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Michael Walle <michael@walle.cc>
