This adds initial support for Colibri VF50/VF61 based on Freescale
Vybrid SoC. The board support package is based on Freescale Tower
board, with following differences:
- CPU clocked at 500MHz
- Use PLL2 as DDR3 clock (400MHz)
- New Machine ID
- Console on UART1 (Colibri UART_A)
- Ethernet on FEC1
- Enabled command line editing
- PLL5 based RMII clocking (e.g. no external crystal)
- UART_A and UART_C I/O muxing
- Boot from OCRAM gfxRAM
- Boot from NAND by default
Tested on Colibri VF50/VF61 booting using serial loader over UART.
Prepare v2014.10
Update Apalis T30 as per the following commits
c369139234c03b1494394d12cd27009f47aa6606
tegra: dts: Add serial port details
461be2f96e4b87e5065208c6659a47dd0ad9e9f8
kconfig: remove redundant "string" type in arch and board Kconfigs
f1ef2b62339526df3b921bcfefd174ce76d4c624
kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfig
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
The K2HK and K2E boards support SPL by default, so add
CONFIG_SPL option. Also export CONFIG_ARM, CONFIG_ARCH_KEYSTONE
and TARGET_K2*_EVM options to spl/.config as they are the same.
So now it's convinient to build gph images using only two commands:
make k2hk_evm_defconfig
make u-boot-spi.gph
Acked-By: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
These boards have been orphaned for more than 6 months.
This board has been orphaned for more than 6 months.
It is the last board defining CONFIG_APM821XX.
The code inside #ifdef CONFIG_APM821XX should be removed too.
This patch adds board support for the Toradex Apalis T30 a computer on
module which can be used on different carrier boards.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot and environment storage
- Gigabit Ethernet (once Thierry's PCIe as well as my E1000 resp. i210
fixes hit mainline)
- MMC/SD cards (both 8-bit as well as 4-bit slot)
- USB client/host (dual role port as client e.g. for DFU/UMS, other two
ports as host)
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit 90a565acf3a18c61170ec0e0b2046c98cb7ecc85)
The single file conflict below is actually trivial.
board/boundary/nitrogen6x/nitrogen6x.c
Change this board to add a device tree.
This also adds a pinmux header file although it is not used as yet.
Most of the smdkv310 features are common with other exynos4 boards. To
permit easier addition of driver model support, use the common file and
add a device tree file.
This patch adds support for the OT1200 series of devices.
Following components are used in u-boot:
+ ethernet
+ i2c
+ emmc
+ gpio
For more details see README.
Changes v1 > v2
- make use of enable_cspi_clock(..)
- fix usage of OUTPUT_40OHM define
- added README
Changes v2 > v3
- improve spelling in README
- added own copy of mx6q_4x_mt41j128.cfg
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
This commit allows to build Panasonic UniPhier family:
PH1-LD4, PH1-Pro4, PH1-sLD8
Update the ddr scripts for LPDDR2 and add two build configs for LPDDR2
arm2 board. Since the LPDDR2 arm2 board has different DDR size, use
CONFIG_DDR_MB in defconfig to replace the PHYS_SDRAM_SIZE.
Signed-off-by: Ye.Li <B37916@freescale.com>
This patch adds the i.MX6DL arm2 board support. The i.MX6DL ARM2
shared the same board with i.MX6Q ARM2 board since the i.MX6DL is
pin-pin compatible with i.MX6Q.
The patch also support the DDR 32-BIT mode option. Please define
CONFIG_DDR_32BIT in the board configure file to enable DDR 32-BIT
mode.But due to the board design, it's 64bit DDR buswidth physically,
so, if you CONFIG_DDR_32BIT, the DDR memory size will be half of it.
LS1021AQDS has a variant with DDR4 slot. This patch adds a new defconfig
for this variant to enable DDR4 support. RAW timing parameters are not
added for DDR4. The board timing parameters are only tuned for single-
rank 1600 and 1800MT/s with Micron DIMM 9ASF51272AZ-2G1A1 due to DIMM
availability.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Alison Wang <alison.wang@freescale.com>
This option specifies the default Device Tree used for the run-time
configuration of U-Boot.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Michal Simek <michal.simek@xilinx.com>
This commit moves:
CONFIG_OF_CONTROL
CONFIG_OF_SEPARATE
CONFIG_OF_EMBED
CONFIG_OF_HOSTFILE
Because these options are currently not supported for SPL,
the "Device Tree Control" menu does not appear in the SPL
configuration.
Note:
zynq-common.h should be adjusted so as not to change the
default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Since CONFIG_CMD_IMPORTENV is defined in config_cmd_defaults.h,
it should be enabled for all the boards except bf506f-ezkit
that undefs it explicitely.
Since CONFIG_CMD_EXPORTENV is defined in config_cmd_defaults.h,
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h,
it is enabled for all the boards except the ones undefining it
explicitly:
kwb
tseries_mmc
tseries_nand
tseries_spi
vct_platinum_onenand_small
vct_platinum_small
vct_platinumavc_onenand_small
vct_platinumavc_small
vct_premium_onenand_small
vct_premium_small
The default value of this config option should be "y" and
"# CONFIG_CMD_CRC32 is not set" should be added for those exceptions.
CONFIG_CMD_BOOTM is defined in config_cmd_defaults.h
which is forcebly included from each board.
So, the default value of "config CMD_BOOTM" should be "y".
For some boards undefining it (bf506f-ezkit, controlcenterd_TRAILBLA,
controlcenterd_TRAILBLAZER_DEVELOP, controlcenterd_TRAILBLAZER),
"# CONFIG_CMD_BOOTM is not set" should be added to their defconfig.
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
T1042RDB is a Freescale reference board that hosts the T1042 SoC
(and variants). The board is similar to T1040RDB, T1042 is a reduced
personality of T1040 SoC without Integrated 8-port Gigabit(L2 Switch).
T1042RDB is configured with serdes protocol 0x86 which can support
following interfaces
- 2 RGMII's on DTSEC4, DTSEC5
- 1 SGMII on DTSEC3
DTSEC1, DTSEC2 are not connected on board.
This Patch
- add T1042RDB support
- updates README file for T1042RDB details and update commands for switching
to alternate banks from vBank0 to vBank4 and vice versa
This patch also does minor clean ups for fdt defines for T1042RDB and
T1042RDB_PI board
Signed-off-by: Vijay Rai <vijay.rai@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Provide cgtqmx6eval board its own variant of ddr
setup config file. Move board/freescale/imx/ddr/
mx6q_4x_mt41j128.cfg to board/freescale/mx6sabresd/
as this is was designed for the mx6sabresd board.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
We do not have to distinguish CONFIG_TARGET_VEXPRESS_AEMV8A_SEMI
from CONFIG_TARGET_VEXPRESS_AEMV8A. Rename the former to the latter.
Reviewed-by: Steve Rae <srae@broadcom.com>
Cc: David Feng <fenghua@phytium.com.cn>
This adds NAND support for the Vybrid tower system (TWR-VF65GS10)
provided by the vf610_nfc driver. Full 16-Bit bus width is
supported. Also an aditional config vf610twr_nand is introduced
which gets the environment from NAND. However, booting U-Boot from
NAND is not yet possible due to missing boot configuration block
(BCB).
Signed-off-by: Stefan Agner <stefan@agner.ch>
Currently mx6dlsabresd shares the same DCD settings with the nitrogen board.
Provide a DCD configuration file specific to mx6dlsabresd with the settings
recommended by the Freescale hardware team.
Add initial support for Compulab CM-FX6 CoM.
Support includes MMC, SPI flash, and SPL with dynamic DRAM detection.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
LS102xA is an ARMv7 implementation. This patch is to add
basic support for LS1021ATWR board.
One DDR controller
DUART1 is used as the console
For the detail board information, please refer to README.
Signed-off-by: Chen Lu <chen.lu@freescale.com>
Signed-off-by: Yuan Yao <yao.yuan@freescale.com>
Signed-off-by: Alison Wang <alison.wang@freescale.com>
basic support for LS1021AQDS board.
One DDR controller
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
This patch adds support for Olimex A20-OLinuXino-LIME board.
Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Patch is the result of:
sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h
sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Hans de Goede <hdegoede@redhat.com>
[ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove
redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
CONFIG_SPL is defined as a primary option in Kconfig.
It should not be added to CONFIG_SYS_EXTRA_OPTIONS.
This config is valid for two devices:
- Odroid X2,
- Odroid U3.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
The QS Systems TQMa6 board support was added by commit cb07d74e
and lost by commit e82abaeb.
Commit e82abaeb merged the IMX branch based on pre-Kconfig
and the mainline based on post-Kconfig, simply deleting
the boards.cfg file. As a result, some boards added just before
the merge were lost.
This commit adds Kconfig, defconfig, MAINTAINERS for TQMa6 board
to work on the Kconfig infrastructure.
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Nomadik board select menu to nomadik/Kconfig.
Move also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="nomadik").
