In Linux this DT file is named at91-sama7g5ek.dts. Rename it accordingly.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com>
CONFIG_VIDEO_BCM2835
This is the final ad-hoc CONFIG_VIDEO_... to convert.
Acked-by: Matthias Brugger <mbrugger@suse.com>
This does not use driver model and is more than two years past the
migration date. Drop it.
It can be added back later if needed.
Prepare v2022.04-rc5
CONFIG_LCD_INFO
CONFIG_LCD_LOGO
CONFIG_LCD_INFO_BELOW_LOGO
CONFIG_LCD_IN_PSRAM
CONFIG_ATMEL_LCD
CONFIG_ATMEL_LCD_BGR555
CONFIG_ATMEL_LCD_RGB565
CONFIG_GURNARD_SPLASH
CONFIG_MII_INIT
CONFIG_PHY_RESET_DELAY
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_SYS_RX_ETH_BUFFER
CONFIG_TFTP_PORT
CONFIG_RMII
CONFIG_SYS_FAULT_ECHO_LINK_DOWN
CONFIG_RESET_PHY_R
CONFIG_ATMEL_LEGACY
Cc: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_AT91_GPIO_PULLUP
CONFIG_AT91SAM9G10EK
CONFIG_AT91SAM9261EK
CONFIG_AT91SAM9G10
CONFIG_AT91SAM9G20EK
CONFIG_AT91SAM9260EK
CONFIG_AT91SAM9G20EK_2MMC
CONFIG_AT91SAM9260
CONFIG_AT91SAM9G20
CONFIG_AT91SAM9XE
CONFIG_AT91SAM9261
CONFIG_AT91SAM9263
CONFIG_AT91SAM9G45
CONFIG_AT91SAM9M10G45
CONFIG_AT91SAM9N12
CONFIG_AT91SAM9RL
CONFIG_AT91SAM9X5
CONFIG_SAM9X60
CONFIG_SAMA7G5
CONFIG_SAMA5D2
CONFIG_SAMA5D3
CONFIG_SAMA5D4
These options are already select'd as needed, so we're just cleaning up
files here.
CONFIG_AM335X_USB0
CONFIG_AM335X_USB0_MODE
CONFIG_AM335X_USB1
CONFIG_AM335X_USB1_MODE
We do this by introducing specific options for static configuration of
USB0/USB1 in SPL rather than defining CONFIG_AM335X_USBx_MODE to the
enum value being used. Furthermore, with how the code is used now we do
not need to have OTG mode exposed as an option here, so remove that.
A small number of i.MX6/7 and vf610 boards have not enabled DM_ETH yet.
Given the state of the rest of the platform, enable DM_ETH.
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Richard Hu <richard.hu@technexion.com>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Uri Mashiach <uri.mashiach@compulab.co.il>
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
CONFIG_NFS_TIMEOUT
CONFIG_BOOT_RETRY_TIME
CONFIG_BOOT_RETRY_MIN
CONFIG_RESET_TO_RETRY
We also introduce CONFIG_BOOT_RETRY to gate these options, and clean up
the associated Makefile entry and C code for picking default values of
CONFIG_BOOT_RETRY_MIN.
CONFIG_NET_RETRY_COUNT
CONFIG_ARP_TIMEOUT
CONFIG_ARMV7_SECURE_BASE
CONFIG_ARMV7_SECURE_MAX_SIZE
CONFIG_ARMV7_SECURE_RESERVE_SIZE
As the CI test for stopping platforms from being merged that were
defining symbols that had Kconfig entries, a small number of symbols
needed to be migrated again. Do so, and catch two cases the README
should also have been updated but was not.
This is very useful to access the LibreComputer eMMC as removable
storage from a PC (e.g. like so `ums 0 mmc 0`). It has been tested as
working on my Renegade board.
Signed-off-by: Leonidas P. Papadakos <papadakospan at gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Add support for Kevin, an RK3399-based convertible chromebook that is
very similar to Bob. This patch is mostly based on existing support for
Bob, with only minor changes for Kevin-specific things.
Unlike other Gru boards, coreboot sets Kevin's center logic to 925 mV,
so adjust it here in the dts as well. The rk3399-gru-kevin devicetree
has an unknown event code reference which has to be defined, set it
to the Linux counterpart. The new defconfig is copied from Bob with the
diffconfig:
DEFAULT_DEVICE_TREE "rk3399-gru-bob" -> "rk3399-gru-kevin"
DEFAULT_FDT_FILE "rockchip/rk3399-gru-bob.dtb" -> "rockchip/rk3399-gru-kevin.dtb"
VIDEO_ROCKCHIP_MAX_XRES 1280 -> 2400
VIDEO_ROCKCHIP_MAX_YRES 800 -> 1600
+TARGET_CHROMEBOOK_KEVIN y
With this Kevin can boot from SPI flash to a usable U-Boot prompt on the
display with the keyboard working, but cannot boot into Linux for
unknown reasons.
eMMC starts in a working state but fails to re-init, microSD card works
but at a lower-than-expected speed, USB works but causes a hang on
de-init. There are known workarounds to solve eMMC and USB issues.
Cc: Marty E. Plummer <hanetzer@startmail.com>
[Alper: commit message, resync config with Bob, update MAINTAINERS,
add to Rockchip doc, add Kconfig help message, set regulator]
Co-developed-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
Signed-off-by: Alper Nebi Yasak <alpernebiyasak@gmail.com>
This patch enables some configs that should be working on the Bob board,
based on what is observed to work on the Kevin board.
The Bob board uses an Embedded DisplayPort panel compatible with the
simple panel and Rockchip eDP drivers. Its backlight is controlled by
the Chromium OS Embedded Controller Pulse Width Modulator. Enable these
for the board.
Also set VIDEO_ROCKCHIP_MAX_{XRES,YRES} to 1280x800, the resolution of
its panel. This had to be done for the Kevin board, but it's untested if
this is actually necessary for Bob.
The Rockchip video driver needs to assert/deassert some resets, so also
enable the reset controller. RESET_ROCKCHIP defaults to y for this board
when DM_RESET=y, so it's enough to set that.
The Bob board has two USB 3.0 Type-C ports and one USB 2.0 Type-A port
on its right side. Enable the configs relevant to USB devices so these
can be used. This is despite a known issue with RK3399 boards where USB
de-init causes a hang, as there is a known workaround.
Some other rk3399-based devices enable support for the SoC's random
number generator in commit a475bef5340c ("configs: rk3399: enable rng on
firefly/rock960/rockpro64"), as it can provide a KASLR seed when booting
using UEFI. Enable it for Bob as well.
The default misc_init_r() for Rockchip boards sets cpuid and ethernet
MAC address based on e-fuse block. A previous patch extends this on Gru
boards to set registers related to SoC IO domains as is necessary on
these boards. Enable this function and configs for it on Bob.
The microSD card slot on this board (and others based on Gru) is
connected to a GPIO controlled regulator (ppvar-sd-card-io), which must
be operable by U-Boot. Enable the relevant config option to allow this.
Bob boards also use the Winbond W25Q64DW SPI flash chip, enable support
for Winbond SPI flash chips in the board config so U-Boot can boot with
this chip.
https://source.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2022.07-rc1
microblaze:
- Add support for reserved memory
xilinx:
- Update FRU code with MAC reading
zynqmp:
- Remove double AMS setting
- DT updates (mostly for SOMs)
- Add support for zcu106 rev 1.0
zynq:
- Update nand binding
nand:
- Aligned zynq_nand to upstream DT binding
net:
- Add support for ethernet-phy-id
mmc:
- Workaround CD in zynq_sdhci driver also for ZynqMP
- Add support for dynamic/run-time SD config for SOMs
gpio:
- Add driver for slg7xl45106
firmware:
- Add support for dynamic SD config
power-domain:
- Update zynqmp driver with the latest firmware
video:
- Add skeleton driver for DP and DPDMA
i2c:
- Fix i2c to work with QEMU
pinctrl:
- Add driver for zynqmp pinctrl driver
- Config tweaks to enable the right I2C driver
Add Python scripts to test 'ls' and 'load' commands, as well as
test related filesystem functions.
Signed-off-by: Huang Jianan <jnhuang95@gmail.com>
https://source.denx.de/u-boot/custodians/u-boot-stm
mtd: add NAND write protect support to stm32_fmc2_nand
stm32mp1 bsec: Add permanent lock write support
stm32mp1 bsec: Add dev in function description
cmd_stboard: Update test on misc_read() result
video: fix the check of return value of clk_set_rate in stm32_ltdc
DT: Alignment with kernel v5.17 for stm32mp15
DT: Add USB OTG pinctrl and regulator in SPL for DHCOR
DT: Move vdd_io extras into Avenger96 extras
DT: Add DFU support for DHCOM recovery
ram: stm32mp1: Unconditionally enable ASR
psci: Implement PSCI system suspend and DRAM SSR for stm32mp
This patch configures U-Boot SPL for DHCOM SoM to permit DFU upload of
SPL and subsequent u-boot.itb for recovery or commissioning purposes.
The DFU usage procedure is identical to STM32MP1 DHCOR SoM, see commit
3919aa1722a ("ARM: dts: stm32: Add DFU support for DHCOR recovery") ,
except for switching the SoM into DFU mode. By default, the DHCOM SoM
has no dedicated mechanism for setting BOOTn straps into UART/USB mode,
therefore to enter DFU mode, the SoC must fail to boot from boot media
which can be selected by the BOOTn strap override mechanism first and
then fall back to DFU mode.
In case of a SoM with pre-populated BOOTn strap override button, power
the system off, remove microSD card (if applicable), hold down the BOOTn
strap override button located between eMMC and SoM edge connector, power
on the SoM. The SoC will fail to boot from SD card and fall back into
DFU mode.
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
https://source.denx.de/u-boot/custodians/u-boot-video
- fix display of the u-boot logo on Apple devices
- convert Nokia RX-51 to CONFIG_DM_VIDEO
Prepare v2022.04-rc4
This saves about 12 kBytes image size and helps to stay within the
size limit.
Suggested-by: Tom Rini <trini@konsulko.com>
Signed-off-by: Soeren Moch <smoch@web.de>
Commit 90f262a6951f ("vexpress64: Clean up BASE_FVP boot configuration")
cleaned up the usage of default address variables, but missed to update
the address for the kernel in the FVP's bootcmd definition.
Change ${kernel_addr} to read ${kernel_addr_r} to bring back the
automated boot for the fastmodel.
Also use "setenv" instead of the potentially ambiguous "set" on the way.
Fixes: 90f262a6951f ("vexpress64: Clean up BASE_FVP boot configuration")
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Enable I2C support for R-Car V3H (R8A77980) on Condor board.
Signed-off-by: Nam Nguyen <nam.nguyen.yh@renesas.com>
Signed-off-by: Hai Pham <hai.pham.ud@renesas.com>
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Enable I2C support for R-Car V3M (R8A77970) on Eagle board.
Enable I2C support for R-Car V3U (R8A779A0) on Falcon board.
- sunXi SPI fixups (Andre)
- bcm iproc qspi (Rayagonda)
This adds platform code and the device tree for the Phytium Pomelo Board.
The initial support comprises the UART and the PCIE.
Signed-off-by: weichangzheng <nicholas_zheng@outlook.com>
QSGMII PHY present on the j721e common processor board requires
to be initialized before the core boots up. Therefore, run the
corresponding command during boot to do the same.
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Add the command "boot_rprocs" that is required for booting remote
processors in U-Boot.
Fixes: 5980925e2a5a ("include: configs: j721e_evm: Add support to boot ethfw core in j721e")
Reported-by: Jesse Villarreal <jesse.villarreal@ti.com>
Enabling DM_PMIC, DM_REGULATOR_FIXED, and DM_REGULATOR_GPIO
gives us the ability to better monitor voltages and enable
hardware through the device tree. The TL4030 (TPS65950) is
not yet migrated to DM, so this patch only enables the fixed
and GPIO controlled regulators.
Based on commit [1][2].
[1] a40d3cc845756e1e38af5ac31986539417e64abb
[2] 2448e42d73fb91e4b56bb41b2677e18ab99a6c83
Signed-off-by: Romain Naour <romain.naour@gmail.com>
The simple pinctrl driver currently available works with the omap3.
Enabling this will use the device tree to automatically set the
pin-muxing for various drivers.
Based on commit: 57dbf754e37d3347cad441f3869bf72c0d726a71
