path: root/configs
2017-05-26Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-05-26Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
Move FTMAC100 to where it should be, alphabetically in drivers/net/Kconfig Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: drivers/net/Kconfig
2017-05-23Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2017-05-23armv8: ls2080ardb: Add LS2081ARDB board supportPriyanka Jain
LS2081ARDB board is similar to LS2080ARDB board with few differences It hosts LS2081A SoC Default boot source is QSPI-boot It does not have IFC interface RTC and QSPI flash device are different It provides QIXIS access via I2C Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23armv8: ls2080ardb: Add QSPI-boot supportPriyanka Jain
QSPI-boot is supported on LS2088ARDB RevF board with LS2088A SoC. LS2088ARDB RevF Board has limitation that QIXIS can not be accessed. CONFIG_FSL_QIXIS is not enabled. Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Signed-off-by: Suresh Gupta <suresh.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-05-23nds32: eth: Support ftmac100 DM.rick
Support Andestech eth ftmac100 device tree flow on AG101P/AE3XX platform. Verification: Boot linux kernel via dhcp and bootm ok. NDS32 # setenv bootm_size 0x2000000;setenv fdt_high 0x1f00000; NDS32 # dhcp 0x600000 10.0.4.97:boomimage-310y-ae300-spi.bin BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4899 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'boomimage-310y-ae300-spi.bin'. Load address: 0x600000 Loading: ################################################################# ################################################################# ################################################################# ... ... ################################### 233.4 KiB/s done Bytes transferred = 13872076 (d3abcc hex) NDS32 # dhcp 0x2000000 10.0.4.97:ae300.dtb BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 DHCP client bound to address 10.0.4.178 (4592 ms) Using mac@e0100000 device TFTP from server 10.0.4.97; our IP address is 10.0.4.178 Filename 'ae300.dtb'. Load address: 0x2000000 Loading: # 82 KiB/s done Bytes transferred = 2378 (94a hex) NDS32 # bootm 0x600000 - 0x2000000 Image Name: Created: 2017-03-22 6:52:03 UTC Image Type: NDS32 Linux Kernel Image (uncompressed) Data Size: 13872012 Bytes = 13.2 MiB Load Address: 0000c000 Entry Point: 0000c000 Verifying Checksum ... OK Booting using the fdt blob at 0x2000000 Loading Kernel Image ... OK Loading Device Tree to 01efc000, end 01eff949 ... OK Linux version 3.10.102-20375-gb0034c1-dirty (rick@app09) (gcc version 4.9.3 (2016-07-06_nds32le-linux-glibc-v3_experimental) ) #293 PREEMPT Wed Mar 22 14:49:28 CST 2017 CPU: NDS32 N13, AndesCore ID(wb), CPU_VER 0x0d11103f(id 13, rev 17, cfg 4159) ... ... Signed-off-by: rick <rick@andestech.com>
2017-05-22Merge git://git.denx.de/u-boot-sunxiTom Rini
trini: Make Kconfig SPL_xxx entires only show if SPL, so that we don't get Kconfig errors on platforms without SPL, ie sandbox (without SPL). Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2017-05-22Convert CONFIG_LZMA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_LZMA Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IRQ to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IRQ Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IOLOOP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IOLOOP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IMMAP to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IMMAP Also move this command out of the cmd/ directory since it is PowerPC-specific. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_HDMIDETECT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_HDMIDETECT Note that we cannot do 'default y if VIDEO' because this option is only enabled for a small subset of mx6 boards. Also this command is is not a great implementation (it doesn't use driver model). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_HD44760 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_HD44760 Also drop CONFIG_CMD_HD44780 which appears to be a typo. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_GSC to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_GSC Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FUSE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FUSE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGA_LOADBP et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGA_LOADBP CONFIG_CMD_FPGA_LOADFS CONFIG_CMD_FPGA_LOADMK CONFIG_CMD_FPGA_LOADP Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FPGAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FPGAD Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_FDC to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FDC Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ETHSW to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ETHSW Also enable it for sandbox to increase build coverage. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_ENV_FLAGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_FLAGS Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_CALLBACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_CALLBACK Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_EECONFIG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EECONFIG Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ECCTEST to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ECCTEST Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Drop three-wire serial (TWS) supportSimon Glass
This subsystem has not been converted to driver model, there is only one driver and only one board that uses it. Drop it and its CONFIG option. Also drop the rtc4543 RTC driver since it uses TWS. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_DS4510 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_DS4510 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22FIT: Rename FIT_DISABLE_SHA256 to FIT_ENABLE_SHA256_SUPPORTTom Rini
We rename CONFIG_FIT_DISABLE_SHA256 to CONFIG_FIT_ENABLE_SHA256_SUPPORT which is enabled by default and now a positive option. Convert the handful of boards that were disabling it before to save space. Cc: Dirk Eibach <eibach@gdsys.de> Cc: Lukasz Dalek <luk0104@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22nds32: Support AE3XX platform.rick
Support Andestech AE3xx platform: serial, timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AG101P timer DM.rick
Support AG101P timer device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22nds32: Support AG101P serial DM.rick
Support AG101P serial device tree flow. Signed-off-by: rick <rick@andestech.com>
2017-05-22ARM: rmobile: salvator-x: Add R8A7796 supportMarek Vasut
Add minor ifdeffery and default board config for the Salvator-XS board with R8A7796 M3 SoC. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Rename the defconfig to match the SoCMarek Vasut
Rename the salvator-x_defconfig to r8a7795_salvator-x_defconfig in preparation for the r8a7796 support on salvator-x board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Add USB supportMarek Vasut
Add support for the EHCI USB. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Add RAVB ethernet supportMarek Vasut
Add support for the AVB ethernet on the Salvator-X board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Add SD supportMarek Vasut
Add support for the SD card slots on the Salvator-X board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Set default device treeMarek Vasut
Set default device tree file in the salvator-x_defconfig and use it in the environment. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: salvator-x: Move OF_LIBFDT and CMD_FDT to board configMarek Vasut
Move these two Kconfig symbols to the salvator-x_defconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-22ARM: rmobile: Allow R8A7796 Salvator-X configurationMarek Vasut
The Salvator-X can have both H3 and M3 CPU on it, drop the select R8A7795 to allow both configurations. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-05-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-05-18arm: socfpga: Add config and defconfig for Arria 10Ley Foon Tan
Add config and defconfig for the Arria10 and update socfpga_common.h. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18imx: mx7dsabresd: fix secure config after switching to DMStefano Babic
mx7dsabresd_secure_defconfig was not updated after moving to DM. Signed-off-by: Stefano Babic <sbabic@denx.de>
2017-05-18imx: mx7dsabresd: switch to DM USBPeng Fan
Switch to use DM USB. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2017-05-18imx: mx7dsabresd: enable more DM driversPeng Fan
Enable more DM drivers. The imx I2C/MMC DM drivers needs DM_GPIO enabled. The 74x164 drivers needs SOFT_SPI and DM_GPIO enabled. So needs to enable them together. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
