Enable CONFIG_MMC_PWRSEQ configuration about boards that is using
rockchip_dw_mmc driver.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
The DM_DMA option is needed in order to translate physical address into
bus addresses on a per-device basis.
Signed-off-by: Nicolas Saenz Julienne <nsaenzjulienne@suse.de>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
Add test to validate dev->dma_offset is properly set on devices.
We find the iProc RNG200 in the Raspberry Pi 4. Add it to all it's
config so that it can be used.
[mb: drop rpi_4_32b_defconfig]
The switch driver for LS1028A Ethernet switch is now compiled in for
the NXP LS1028A reference design boards and for the Kontron SMARC-sAL28.
Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com>
Signed-off-by: Claudiu Manoil <claudiu.manoil@nxp.com>
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Acked-by: Michael Walle <michael@walle.cc>
This board has not been converted to CONFIG_DM by the deadline of v2020.01
and is missing other conversions which depend on this as well. Remove it.
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
As this is the last SH4A board, remove that support as well.
Cc: Marek Vasut <marek.vasut+renesas@gmail.com>
Patch-cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Patch-cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
This board relies on using CONFIG_LIBATA but does not enable CONFIG_AHCI. The
deadline for this conversion was the v2019.07 release. The use of CONFIG_AHCI
requires CONFIG_DM. The deadline for this conversion was v2020.01. Remove
this board.
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
this board.
this board.
this board.
This board has not been converted to CONFIG_DM_MMC by the deadline of
v2019.04, which is almost two years ago. In addition there are other DM
migrations it is also missing. Remove it.
Cc: Chris Packham <judge.packham@gmail.com>
Acked-by: Chris Packham <judge.packham@gmail.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Lauri Hintsala <lauri.hintsala@bluegiga.com>
Acked-by: Lauri Hintsala <lauri.hintsala@silabs.com<mailto:lauri.hintsala@silabs.com>>
Signed-off-by: Tom Rini <trini@konsulko.com<mailto:trini@konsulko.com>>
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic
- Add configuration helpers for MIPI D-PHY
- generic-phy: add configure op
- Add Amlogic AXG MIPI D-PHY driver & MIPI PCIe Analog PHY driver
- odroid: add runtime detection of the N2/N2+/C4/HC4 variants
Use the ADC channel 1 to check the hardware revision of the board and
detect the N2 vs. N2+ and the C4 vs. HC4 variants. Each of them use
different dtb file, so adjust fdtfile environment variable to the
detected variant.
The ADC min/max values for each variant are taken from the vendor code,
adjusted to the 12-bit ADC driver operation mode (vendor code use 10-bit
mode).
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Enable the fastboot oem command bootbus, used to configure the eMMC
boot behavior, with same format than 'mmc bootbus'
and with parameter: boot_bus_width reset_boot_bus_width boot_mode
On stm32mp1 boards the expected command is
$> fastboot oem partconf:0 0 0
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Enable the fastboot oem command partconf, used to select the correct
eMMC boot partition, with same format than 'mmc partconf'
with parameter: boot_ack boot_partition
On stm32mp1 family:
- boot_ack = 1 (Boot Acknowledge is needed by ROM code)
- boot_partition = 1 or 2 (Boot partition 1 / 2 enabled for boot)
So on EV1 board the expected commands to select boot partition 1 or 2
$> fastboot oem partconf:1 1
$> fastboot oem partconf:1 2
Enable the fastboot oem command format and set the variable
"partitions" with default eMMC partitions list.
Signed-off-by: Jean-Philippe ROMAIN <jean-philippe.romain@st.com>
Activate fastboot support on boot partition for eMMC, mmc1 device
on STMicroelectronics board (EV1).
- Espressobin: Set default env values at runtime (Pali)
- Espressobin: Set the maximum slave SPI speed to 40MHz (Pali)
- theadorable: PCIe test code enhancement and early deemphasis
enabling (Stefan)
- pci_mvebu: Disable config access to PCI host bridge ports (Stefan)
- mv_sdhci: parse device-tree entry (Baruch)
Layerscape: Enable gpio
Bug fixes & updates related to dspi, qspi, pciep, SVR mask,
stream-id, env variables, mdio for LAyerscape Platforms
Add SATA, network variant 1, 2 support on sl28
powerpc: T1042: drop CONFIG_VIDEO, Add kmcent2 board supporrt, keymile
Bug fixes and updates for keymile, Kontron
- Beacon EmbeddedWorks RZG2H/N Dev Kit support
Enable CMD_GPIO for board lx2160aqds
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Enable CMD_GPIO for board lx2160ardb
Enable DM_GPIO and CMD_GPIO for board ls1088ardb
Enable DM_GPIO and CMD_GPIO for board ls1088aqds
Enable CMD_GPIO for board ls2088aqds
Enable DM_GPIO and CMD_GPIO for board ls2088ardb
Enable CMD_GPIO for board ls1046aqds
Enable CMD_GPIO for board ls1046ardb
Enable CMD_GPIO for board ls1043ardb
Enable CMD_GPIO for board ls1043aqds
Enable CMD_GPIO for board ls1028ardb
Enable CMD_GPIO for board ls1028aqds
Enable CMD_GPIO for ls1021atwr
Enable CMD_GPIO for board ls1021aqds
Enable CMD_GPIO for ls1012ardb
Enable CMD_GPIO for ls1012afrwy
Drop the CONFIG_VIDEO to fix the following build warning.
===================== WARNING ======================
This board does not use CONFIG_DM_VIDEO Please update
the board to use CONFIG_DM_VIDEO before the v2019.07 release.
UPD include/generated/dt.h
Failure to update by the deadline may result in board removal.
See doc/driver-model/migration.rst for more info.
UPD include/generated/timestamp_autogenerated.h
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Add basic support for the Hitachi Power Grids kmcent2 board, based
on the NXP QorIQ T1040 SoC.
Signed-off-by: Valentin Longchamp <valentin.longchamp@hitachi-powergrids.com>
Signed-off-by: Rainer Boschung <rainer.boschung@hitachi-powergrids.com>
Signed-off-by: Niel Fourie <lusus@denx.de>
Cc: Holger Brunck <holger.brunck@hitachi-powergrids.com>
[Fixed blank line at EOF errors]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable SATA support. Although not supported by the usual SATA pins on
the SMARC baseboard connector, SATA mode is supported on a PCIe lane.
This way one can use a mSATA card in a Mini PCI slot.
We need to invert the received data because in this mode the polarity of
the SerDes lane is swapped. Provide a fixup in board_early_init_f() for
the SPL. board_early_init_f() is then not common between SPL and u-boot
proper anymore, thus common.c is removed, as it just contained said
function.
Signed-off-by: Michael Walle <michael@walle.cc>
Although the status register is protected by the hardware write
protection, there is a hardware jumper to disable that hardware write
protection. Thus if a user would set this jumper any u-boot start would
disable the write protection altogether.
Circumvent that by not disabling the write protection in the first
place.
While the SPI controller speed is defined by DTS, the maximum
slave speed (connected devices) is limited by the pre-defined
configuration value CONFIG_SF_DEFAULT_SPEED to 1MHz
This patch increases this maximum SPI slave device speed to 40MHz
Change-Id: I0d1239bd8a2061c66725c2c227c1e1f49c92c29e
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
Reviewed-on: http://vgitil04.il.marvell.com:8080/59516
Tested-by: iSoC Platform CI <ykjenk@marvell.com>
Reviewed-by: Igal Liberman <igall@marvell.com>
[pali: Set CONFIG_SF_DEFAULT_SPEED via defconfig]
Signed-off-by: Pali Rohár <pali@kernel.org>
