Enable GPIO regulator.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Add initial A53 defconfig support for AM64x SoCs.
Add initial R5 defconfig support for AM64x SoCs.
Enable all relevant configs needed for SPL to apply overlays to U-Boot.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Enable I2C GPIO expander related configs in SPL.
The J721E R5 SPL will no longer support booting of the Main R5FSS Core0
after the R5 SPL re-architecture for System Firmware split. The MCU R5F
branch-only boot does not use the K3 R5F remoteproc driver, and relies
only on the filesystem (FS) support for now. The K3 R5F remoteproc driver
is therefore no longer needed in R5 SPL, so drop it from the J721E R5
defconfig.
Signed-off-by: Suman Anna <s-anna@ti.com>
commit f72edfddde5cd90e6aa52e11374adc7af499adce upstream.
Enable relevant configs that checks for the size of image and stack:
BSS: 3KB
Initial MALLOC: ~22KB
Initial Stack: 8K
SPL Image size can be: ~215KB
commit 489274eb6c579cddf2104623c8cd30d7a9aa9cbc upstream.
Add configs for voltage switching and UHS modes for the SD card
and HS200 for the eMMC.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
commit 79a30b112876c8c2b9f51f4f34fbdca05a6ce472 upstream.
Add configs to support UHS modes for the SD card and HS200 for the eMMC.
commit d1d34f79859630ac96a04af040cef2367be5f497 upstream.
sequence number
commit 59a51c307603c1ec7ff27cf6a310158190ab1508 upstream.
AM65x SoC has two USB subsystems and their corresponding device tree nodes
have the same name but different path. While allocating sequence numbers
for these device tree nodes using alias, phandles can be used to
distinguish them.
Enable config for phandle check while getting sequence number to
distinguish the USB device tree nodes.
On the XEA board (imx28) one needs in the SPL support for GPIO, MMC and
SPI. Two last ones are necessary for booting the device. The GPIO support
allows deciding which medium will be used. For example the GPIO DTS node
(gpio@0 at imx28.dtsi) has pinctrl parent (pinctrl@80018000) for which we
don't need driver asigned for correct operation.
In the spl/dts/dt-platdata.c the gpio@0 has index 4 and its parent -
pinctrl@80018000 has index 5.
In the bind_drivers_pass() function (at drivers/core/lists.c) call to
device_bind_by_name() for `fsl_imx23_pinctrl` returns -2, which is
expected.
With current setup - when the SPL_OF_PLATDATA_PARENT=y
The gpio@0 node with index 4 is skipped as its parent with 5 is not yet
bound. It cannot be as we don't need and provide the driver for it.
As a result the gpio@0 is never bound and we end up with bricked board in
the SPL stage.
When CONFIG_SPL_OF_PLATDATA_PARENT is NOT set, all entries from
spl/dts/dt-platdata.c are scanned in ascending index order, so gpio@0 is
properly initialized. For `fsl_imx_pinctrl` we simply check 10 times if
the driver for is available (which is not) and exit.
As a result the GPIOs are initialized and can be used in early SPL stage.
This commit fixes XEA regression introduced with e41651fffda7da55f6.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
The usage of the preboot feature is now controlled via a separate Kconfig
option - namely CONFIG_USE_PREBOOT.
It must be enabled for preboot code executing commands now defined in
CONFIG_PREBOOT (also moved to the Kconfig).
After defining both CONFIG_USE_PREBOOT and CONFIG_PREBOOT in
imx28_xea_defconfig the define of CONFIG_PREBOOT shall be removed from
xea.h as it is redundant.
SPI flash on this machine is located on bus 1, default to using bus 1
for SPI flash and stop aliasing it to bus 0.
Signed-off-by: Hugh Cole-Baker <sigmaris@gmail.com>
Suggested-by: Simon Glass <sjg@chromium.org>
Fixes: c4cea2bb ("rockchip: Enable building a SPI ROM image on bob")
The dart6ul has an i2c eeprom at 0x50 which contains, among other
things, the manufacturing/revision/options info of the SoM. This patch
replaces the current checkboard() implementation with a more
exhaustive one based on the content of the eeprom.
Since this code uses the new driver model, some changes were also
required in the DTS to make the nodes related to i2c available before
relocation.
This code was inspired from the supported u-boot code from Variscite
which can be found here:
https://github.com/varigit/uboot-imx/tree/imx_v2018.03_4.14.78_1.0.0_ga_var02
New output example:
Board: PN: VSM-6UL-705B, Assy: AS1812142257, Date: 2019 Feb 17
Storage: eMMC, Wifi: yes, DDR: 1024 MiB, Rev: 2.4G
Signed-off-by: Marc Ferland <ferlandm@amotus.ca>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
When booting imx8mp-evk the following allocation error
message is seen:
U-Boot 2021.01-rc3-00200-ge668bec96a5f (Dec 21 2020 - 14:36:42 -0300)
alloc space exhausted
Fix it by increasing CONFIG_SYS_MALLOC_F_LEN to 0x10000 like it
is done on other i.MX8MM/8MN boards.
Reported-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
i.MX8M series includes support for high speed modes in uSDHC controllers.
Turn on corresponding configuration options for EVK boards, which would
enable high speed modes to be included in U-Boot.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
The i.MX8MM is capable of HS400. Enable it in both
U-Boot and SPL for faster throughput.
Enable DM_SPI/DM_SPI_FLASH with a related config option.
Build fine, but not tested.
Cc: Ludwig Zenz <lzenz@dh-electronics.de>
Cc: Andreas Geisreiter <ageisreiter@dh-electronics.de>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Enable DM_SPI/DM_SPI_FLASH with associated config
options.
Cc: Uri Mashiach <uri.mashiach@compulab.co.il>
DM is the modern default approach for the drivers in U-Boot.
It also allows to configure code via Device Tree.
Move Intel Edison to use DM_USB_GADGET and drop hard coded values.
None of the driver for Edison is using DM_PCI_COMPAT, hence drop it.
make lx2162aqds platform to enable gpio driver.
Signed-off-by: Hui Song <hui.song_1@nxp.com>
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable eMMC HS400 mode support on LX2162AQDS.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable CONFIG_BOARD_EARLY_INIT_R for SDHC adapter card
identification and configuration.
[Rebased]
Enable support to compile OPTEE driver, access AVB TA
and RPMB API's access via RPC from OPTEE for lx2162
Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com>
Signed-off-by: Gaurav Jain <gaurav.jain@nxp.com>
This patch add base support for LX2162AQDS board.
LX2162AQDS board supports LX2162A family SoCs.
This patch add basic support of platform.
Signed-off-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Signed-off-by: hui.song <hui.song_1@nxp.com>
Signed-off-by: Manish Tomar <manish.tomar@nxp.com>
Signed-off-by: Vikas Singh <vikas.singh@nxp.com>
Signed-off-by: Meenakshi Aggarwal <meenakshi.aggarwal@nxp.com>
[Rebased]
Move CORTINA_NO_FW_UPLOAD to Kconfig file so that it can
be controlled via defconfig files.
LX2160A-Rev1 uses PCIe layerscape Gen4 controller.
Enable CONFIG_PCIE_LAYERSCAPE_GEN4 for lx2160a.
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Done via moveconfig.py
This commit adds initial support for the Toradex Apalis iMX8X 2GB WB
IT V1.1A System on Module support [1].
Boot log:
U-Boot 2020.10-02940-g894aebb7e8-dirty (Oct 22 2020 - 09:43:57 +0300)
CPU: NXP i.MX8QXP RevB A35 at 1200 MHz at 30C
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... OK
In: serial@5a070000
Out: serial@5a070000
Err: serial@5a070000
Model: Toradex Apalis iMX8 QuadXPlus 2GB Wi-Fi / BT IT V1.1A,
Serial# 06617018
Net: eth0: ethernet@5b040000 [PRIME]
Hit any key to stop autoboot: 0
Functionality wise the following is known to be working:
- eMMC and MMC/SD card
- Ethernet (*)
- GPIOs
- I2C
Unfortunately, there is no USB functionality for the i.MX 8QXP as of
yet.
* With the SCU FW from the latest Toradex BSP 5.0.0 (SCU FW 1.5.1)
ETH PHY encounters bring up problems after reset, this will be fixed
soon on SCU FW side.
[1] https://www.toradex.com/computer-on-modules/apalis-arm-family/nxp-imx-8x
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Acked-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
V1.1A HW switched the PMIC from BD71837 to PCA9450.
- Disable combined DVS in PCA9450_BUCK123_DVS.
- Increase DDR Voltage to 0.95V as we use a 1.5GHz RAM.
- Configure WDOG_B behaviour.
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
enable Environment protection with:
CONFIG_ENV_APPEND=y
CONFIG_ENV_WRITEABLE_LIST=y
CONFIG_ENV_ACCESS_IGNORE_FORCE
and add board specific env_get_location()
function.
add support for aristainetos2c_cslb board variant.
Removed aristainetos2, 2b, 2b-csl. This boards have been
recalled and destroyed.
Adapt board code to remove stuff not needed anymore.
Fix checkpatch warning, remove fdt_high and initrd_high
from default environment.
zu remove
Activate ARCH_SUPPORT_PSCI as other TEGRA124 target and remove
CONFIG_ARMV7_PSCI and CONFIG_ARMV7_PSCI_NR_CPUS in configs file as they
are migrated in Kconfig.
Select CONFIG_ARMV7_PSCI_0_1 (the first PSCI version),
because CONFIG_ARMV7_PSCI_0_2 and CONFIG_ARMV7_PSCI_1_0
are not activated in this product.
This patch depend on the previous serie [1].
I don't test this patch on real hardware but
after this patch the size of the binary don't change.
In .config we have:
CONFIG_ARCH_SUPPORT_PSCI=y
CONFIG_ARMV7_PSCI=y
# CONFIG_ARMV7_PSCI_1_0 is not set
# CONFIG_ARMV7_PSCI_0_2 is not set
CONFIG_ARMV7_PSCI_0_1=y
CONFIG_ARMV7_PSCI_NR_CPUS=4
In u-boot.cfg, this patch only add the 2 lines
#define CONFIG_ARCH_SUPPORT_PSCI 1
#define CONFIG_ARMV7_PSCI_0_1 1
[1] "Convert CONFIG_ARMV7_PSCI_1_0 and CONFIG_ARMV7_PSCI_0_2 to Kconfig"
http://patchwork.ozlabs.org/project/uboot/list/?series=184029
Regards
Patrick
END
Reviewed-by: Peter Chubb <peter.chubb@data61.csiro.au>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Add DT for DH PicoITX unit, which is a bare-bones carrier board for
the DHCOM. The board has ethernet port, USB, CAN, LEDs and a custom
board-to-board expansion connector.
Cc: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
TPMs are becoming popular that's why enable drivers and command for it.
Remove fixed configuration and detect flash based on DT.
Also increase amount of flash sectors to 2048 because on kc705 flash has
1027 sectors.
Bank # 1: CFI conformant flash (16 x 16) Size: 128 MB in 1027 Sectors
Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x8962
Erase timeout: 4096 ms, write timeout: 2 ms
Buffer write timeout: 5 ms, buffer size: 1024 bytes
The PinePhone is a smartphone produced by Pine64, with an A64 SoC,
2 or 3 GiB LPDDR3 RAM, 16 or 32 GiB eMMC, 720x1440 MIPI-DSI panel,
and Quectel EG25-G modem.
There are two main board revisions: 1.1 for early adopters, and 1.2
for mass production. Since there is code to detect the board revision
at boot, one config/image can support both boards.
Acked-by: Maxime Ripard <mripard@kernel.org>
Signed-off-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-ti
- Fix Nokia RX-51 boot issues
- Fix CONFIG_LOGLEVEL on K3 devices
- Add phyBOARD REGOR support
By default CONFIG_LOGLEVEL seems to be set to 4 which is
too low and doesn't show dev_info/dev_notice/dev_warn
messages on console. This has been deliberately set low
globally to be conservative setting across the board due to
primary bootloader size limitations. It is best to tune
per board config as per user needs.
On K3 we have separate SPL and u-boot configs so we
can afford to set u-boot CONFIG_LOGLEVEL to 7.
On AM65 this patch causes u-boot.img size to change from
932KB to 940KB with 1 line additional print during
MMC boot. i.e. details of Net subsystem
"Net: K3 CPSW: nuss_ver: 0x6BA00102 cpsw_ver: 0x6BA80102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000"
Similar 8KB difference was seen on J721E.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Reviewed-by: Nishanth Menon <nm@ti.com>
Use twl4030_i2c_read(), i2c_get_chip_for_busnum() and remove
CONFIG_SYS_I2C.
Signed-off-by: Pali Rohár <pali@kernel.org>
phyBOARD-REGOR is based on phyCORE AM335x R2 SoM (PCL060).
CPU : AM335X-GP rev 2.1
Model: Phytec AM335x phyBOARD-REGOR
DRAM: 512 MiB
NAND: 512 MiB
MMC: OMAP SD/MMC: 0
eth0: ethernet@4a100000
Working:
- Eth0
- i2C
- MMC/SD
- NAND
- UART
- USB (host)
Device trees were taken from Linux mainline:
commit c4d6fe731176 ("Linux 5.9.0")
Signed-off-by: Parthiban Nallathambi <parthiban@linumiz.com>
Improve USB config so keyboard and USB-A ports work.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Commit c4cea2bbf995 ("rockchip: Enable building a SPI ROM image on bob")
added an alias spi1 referring to spi@ff1d0000, however there was already
an alias spi0 referring to the same node in rockpro64's u-boot.dtsi, and
having both aliases present broke booting from SPI flash for this board.
Remove the spi0 alias, set the default bus for SPI flash to 1, and
enable support for numbered aliases in SPL so that it uses the same bus
numbering as U-Boot proper. This fixes booting from U-Boot in SPI flash
on the rockpro64 board.
Fixes: c4cea2bbf995 ("rockchip: Enable building a SPI ROM image on bob")
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
