https://gitlab.denx.de/u-boot/custodians/u-boot-atmel
First set of u-boot-atmel features for 2020.10 cycle
Migrate the ST Microelectronics STUSB160X Type-C controller code in
a generic I2C driver in st/common, based on Linux one in :
drivers/usb/typec/stusb160x.c
This patch simplifies the stm32mp1 board code and allows to reuse
this STUSB160X driver in other boards.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Activate the command env erase to reset the environment with the command:
> env erase
it is simpler than:
> env default -a
> env save
As kernel v5.6 have a solution since so we will be able to enable
the watchdog at boot time. It is reloaded by the watchdog
framework (if CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED is set) and
until the userspace watchdog daemon takes over control.
Need presence of kernel patch 85fdc63fe256 ("drivers: watchdog:
stm32_iwdg: set WDOG_HW_RUNNING at probe") integrated in v5.6-rc1.
This patch revert the previous commit ca351e705a5c ("stm32mp1:
deactivate WATCHDOG in defconfig").
This patch activates the new configuration CONFIG_GPIO_HOG.
Add a function stmpic_init to early initialize the PMIC STPMIC1
- keep vdd on during the reset cycle (to avoid issue when backup battery
is absent)
- Check if debug is enabled to program PMIC according to the bit
This patch allows to remove the compilation of spl.c file from stm32mp1
board in dh_stm32mp1.
CONFIG_SPL_BOARD_INIT is removed as the new function is called earlier
in SPL, in the function board_early_init_f.
Rock Pi N8 is a Rockchip RK3288 based SBC, which has
- VMARC RK3288 SOM (as per SMARC standard) from Vamrs.
- Compatible carrier board from Radxa.
VAMRC RK3288 SOM need to mount on top of radxa dalang
carrier board for making Rock Pi N8 SBC.
So, add initial support for Rock Pi N8 by including rk3288,
rk3288 vamrc-som and raxda dalang carrier board dtsi files.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Rock Pi N10 is a Rockchip RK3399Pro based SBC, which has
- VMARC RK3399Pro SOM (as per SMARC standard) from Vamrs.
VAMRC RK3399Pro SOM need to mount on top of radxa dalang
carrier board for making Rock Pi N10 SBC.
So, add initial support for Rock Pi N10 by including rk3399,
rk3399pro vamrc-som and raxda dalang carrier board dtsi files.
rk3399pro-rock-pi-n10.dts was synced from linux-next v5.7-rc1.
Tested
- ROCK PI N10 Model B
- ROCK PI N10 Model C
- Boot from SD
Some minor fixes for SPI flash on the Pinebook Pro and also
default to saving environment to the SPI flash as it's
guaranteed to be on board.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
(applied with make savedefconfig)
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
The built in keyboard on the Pinebook Pro is attached via USB so
fix this up to ensure USB works as expected.
Enable the rng so UEFI can provide entropy for KASLR
With video output enabled and USB keyboard supported there is no need
for serial console. So let initialize USB subsystem so keyboard connected to
board (either directly or via hub) can be used to interrupt autoboot.
U-Boot TPL 2020.07-rc3-00123-g52d6cbd1a7 (Jun 03 2020 - 17:34:20)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.07-rc3-00123-g52d6cbd1a7 (Jun 03 2020 - 17:34:20 +0200)
Trying to boot from SPI
U-Boot 2020.07-rc3-00123-g52d6cbd1a7 (Jun 03 2020 - 17:34:20 +0200)
SoC: Rockchip rk3399
Reset cause: RST
Model: Pine64 RockPro64 v2.1
DRAM: 3.9 GiB
PMIC: RK808
MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPI Flash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
OK
In: serial
Out: vidconsole
Err: vidconsole
Net: eth0: ethernet@fe300000
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus usb@fe3a0000: USB OHCI 1.0
Bus usb@fe3c0000: USB EHCI 1.00
Bus usb@fe3e0000: USB OHCI 1.0
Bus dwc3: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus usb@fe3a0000 for devices... 1 USB Device(s) found
scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found
scanning bus usb@fe3e0000 for devices... 2 USB Device(s) found
scanning bus dwc3 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Hit any key to stop autoboot: 0
Signed-off-by: Marcin Juszkiewicz <marcin@juszkiewicz.com.pl>
Merge all outstanding changes from the current next branch in now that
we have released.
- Resync Kconfiglib with the v14.1.0 release.
- Re-sync our <linux/compiler*h> files with v5.7-rc5 from upstream.
- Fully resync checkpatch.pl with v5.7 release.
To safely to all of the above, we have a few bugfixes about functions
that need a 'static inline' but weren't. We also stop setting
CROSS_COMPILE in arch/*/config.mk. Finally, with the above changes
boards can now opt-in to optimizing inlining and we do this for the
socfpga stratix10 platform for space savings.
currently gpio hog function is not tested with "ut dm gpio"
so add some basic tests for gpio hog functionality.
For this enable GPIO_HOG in sandbox_defconfig, add
in DTS some gpio hog entries, and add testcase in
"ut dm gpio" command.
Starting from OpenSBI v0.7, the SBI firmware inserts/fixes up the
reserved memory node for PMP protected memory regions. All RISC-V
boards need to copy the reserved memory node from the device tree
provided by the firmware to the device tree used by U-Boot.
Turn on CONFIG_OF_BOARD_FIXUP by default for OF_SEPARATE.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
Reviewed-by: Atish Patra <atish.patra@wdc.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Enable the new CONFIG_OPTIMIZE_INLINING and CONFIG_SPL_OPTIMIZE_INLINING
options for this platform. With gcc-9.2 from kernel.org this saves us
1784 bytes in U-Boot and 80 bytes in SPL.
Cc: Chin-Liang See <chin.liang.see@intel.com>
Cc: Dinh Nguyen <dinh.nguyen@intel.com>
The Sipeed Maix series is a collection of boards built around the RISC-V
Kendryte K210 processor. This processor contains several peripherals to
accelerate neural network processing and other "ai" tasks. This includes a
"KPU" neural network processor, an audio processor supporting beamforming
reception, and a digital video port supporting capture and output at VGA
resolution. Other peripherals include 8M of sram (accessible with and
without caching); remappable pins, including 40 GPIOs; AES, FFT, and SHA256
accelerators; a DMA controller; and I2C, I2S, and SPI controllers. Maix
peripherals vary, but include spi flash; on-board usb-serial bridges; ports
for cameras, displays, and sd cards; and ESP32 chips. Currently, only the
Sipeed Maix Bit V2.0 (bitm) is supported, but the boards are fairly
similar.
Documentation for Maix boards is located at
<http://dl.sipeed.com/MAIX/HDK/>. Documentation for the Kendryte K210 is
located at <https://kendryte.com/downloads/>. However, hardware details are
rather lacking, so most technical reference has been taken from the
standalone sdk located at
<https://github.com/kendryte/kendryte-standalone-sdk>.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
This patch adds a generic reset driver. It is designed to be useful when
one has a register in a regmap which contains bits that reset other
devices. I thought this seemed like a very generic use, so here is a
generic driver. The overall structure has been modeled on the syscon-reboot
driver.
This type of bus is used in Linux to designate buses which have power
domains and/or clocks which need to be enabled before their child devices
can be used. Because power domains are automatically enabled before probing
in U-Boot, we just need to enable any clocks present.
- Minor updates to some platforms I am the listed maintainer of.
Notably this removes the ti814x_evm which stopped building with the PXA
MMC migration series (oops) but hasn't been functional in some time.
The TI814x (DM814x) platform is rather old and in need of a lot of
migration work. As much of that work is well past the deadline, remove
this platform.
This platform is already using DM in general and the MMC controller is
the early generation of what is compatible with "ti,omap4-hsmmc" so
enable DM_MMC (which in turn gets BLK enabled).
https://gitlab.denx.de/u-boot/custodians/u-boot-mips into next
- net: pcnet: cleanup and add DM support
- Makefile: add rule to build an endian-swapped U-Boot image
used by MIPS Malta EL variants
- CI: add Qemu tests for MIPS Malta
Enable CONFIG_DM_MMC.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Enable CONFIG_CMD_DM.
Move CONFIG_PXA_MMC_GENERIC to Kconfig.
The Qemu Malta machine expects the firmware in Big-Endian byte order.
Therefore the Little-Endian variants of the Malta board needs to
be byte swapped.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Add Kconfig entries for the pcnet driver and convert MIPS malta
to use those.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
CONFIG_CADENCE_QSPI
This change allows more fine tuning of driver model based SPI support in
SPL and TPL. It is now possible to explicitly enable/disable the DM_SPI
support in SPL and TPL via Kconfig option.
Before this change it was necessary to use:
/* SPI Flash Configs */
#if defined(CONFIG_SPL_BUILD)
#undef CONFIG_DM_SPI
#undef CONFIG_DM_SPI_FLASH
#undef CONFIG_SPI_FLASH_MTD
#endif
in the ./include/configs/<board>.h, which is error prone and shall be
avoided when we strive to switch to Kconfig.
The goal of this patch:
Provide distinction for DM_SPI support in both U-Boot proper and SPL (TPL).
Valid use case is when U-Boot proper wants to use DM_SPI, but SPL must
still support non DM driver.
Another use case is the conversion of non DM/DTS SPI driver to support
DM/DTS. When such driver needs to work in both SPL and U-Boot proper, the
distinction is needed in Kconfig (also if SPL version of the driver
supports OF_PLATDATA).
In the end of the day one would have to support following use cases (in
single driver file - e.g. mxs_spi.c):
- U-Boot proper driver supporting DT/DTS
- U-Boot proper driver without DT/DTS support (deprecated)
- SPL driver without DT/DTS support
- SPL (and TPL) driver with DT/DTS (when the SoC has enough resources to
run full blown DT/DTS)
- SPL driver with DT/DTS and SPL_OF_PLATDATA (when one have constrained
environment with no fitImage and OF_LIBFDT support).
Some boards do require SPI support (with DM) in SPL (TPL) and some only
have DM_SPI{_FLASH} defined to allow compiling SPL.
This patch converts #ifdef CONFIG_DM_SPI* to #if CONFIG_IS_ENABLED(DM_SPI)
and provides corresponding defines in Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Adam Ford <aford173@gmail.com> #da850-evm
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[trini: Fixup a few platforms]
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
CONFIG_BOOTM_NETBSD
CONFIG_CONSOLE_MUX
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
CONFIG_CONS_INDEX
CONFIG_BOOTP_DNS2
CONFIG_BOOTP_PXE_CLIENTARCH
CONFIG_BOOTCOUNT_ENV
CONFIG_BOOTCOUNT_LIMIT
CONFIG_BOARD_TYPES
CONFIG_BCH
CONFIG_BOOTARGS
CONFIG_BOARD_EARLY_INIT_F
CONFIG_BOARD_EARLY_INIT_R
CONFIG_AUTOBOOT_PROMPT
CONFIG_AUTOBOOT_KEYED
CONFIG_AUTOBOOT_STOP_STR
CONFIG_ATMEL_USART
CONFIG_ATMEL_NAND_HW_PMECC
CONFIG_ATMEL_NAND_HWECC
CONFIG_NAND_ATMEL
CONFIG_PMECC_CAP
CONFIG_PMECC_SECTOR_SIZE
CONFIG_ATMEL_HLCD
CONFIG_AT91_GPIO
CONFIG_ARM_PL180_MMCI
CONFIG_ARCH_MISC_INIT
CONFIG_AM335X_LCD
