Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs
that used it in SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Convert the CONFIG_SATAPWR into kconfig.
Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some
defconfigs.
Convert CONFIG_RGMII to Kconfig. Thanks to that, it is possible to
update defconfig files of SYS_EXTRA_OPTIONS accordingly and
remove it when it is possible.
Convert the SUNXI_EMAC config to Kconfig. Remove it from SYS_EXTRA_OPTIONS
from many sunxi defconfig and renamed it into SUN4I_EMAC to not confuse it
with SUN8I_EMAC.
The USB_EHCI configuration is already set in this defconfig
using kconfig's config. This configuration in SYS_EXTRA_OPTIONS
must be removed and so the SYS_EXTRA_OPTIONS.
This configuration is not necessary in a defconfig file so
it is removed from the SYS_EXTRA_OPTIONS.
Remove the AXP209_POWER option from SYS_EXTRA_OPTIONS.
As this configuration already exists on Kconfig, we just need
to remove it from defconfig.
Move the SUNXI_GMAC config option to Kconfig, remove it
from SYS_EXTRA_OPTIONS and rename it into SUN7I_GMAC.
For using mipi display, we need to enable lcd3v3
which supplied by rk808,so enable rk808 first.
Signed-off-by: Eric Gao <eric.gao@rock-chips.com>
To enable mipi display, we need to enable pmic
rk808 first for lcd3v3 power,which use i2c0 to
communicate with soc. So enable i2c0.
The RK3399-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230
connector) system-on-module from Theobroma Systems, featuring the
Rockchip RK3399.
It provides the following feature set:
* up to 4GB DDR3
* on-module SPI-NOR flash
* on-module eMMC (with 8-bit interace)
* SD card (on a baseboad) via edge connector
* Gigabit Ethernet w/ on-module Micrel KSZ9031 GbE PHY
* HDMI/eDP/MIPI displays
* 2x MIPI-CSI
* USB
- 1x USB 3.0 dual-role (direct connection)
- 2x USB 3.0 host + 1x USB 2.0 (on-module USB 3.0 hub)
* on-module STM32 Cortex-M0 companion controller, implementing:
- low-power RTC functionality (ISL1208 emulation)
- fan controller (AMC6821 emulation)
- USB<->CAN bridge controller
Note that we use a multi-payload FIT image for booting and have
Cortex-M0 payload in a separate subimage: we thus rely on the FIT
image loader to put it into the SRAM region that ATF expects it in.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Fixed build warning on puma-rk3399:
Enable the early debug UART to debug problems when an ICE or other
debug mechanism is not available.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Update the configuration files to support the device tree and driver
model, so do SPL. The device clock and pins configuration are handled
by the clock and the pinctrl drivers respectively.
Fix build error with sama5d3_xplained_mmc:
driver model, so do SPL. The device clock and pins configuration
are handled by the clock and the pinctrl drivers respectively.
Add back CONFIG_PHY_MICREL to prevent a build error:
Allow LEDs to be blinked if the driver supports it. Enable this for
sandbox so that the tests run.
Reviewed-by: Ziping Chen <techping.chan@gmail.com>
This removes the default environment from the sr1500 header
and instead uses the common environment provided in
socfpga_common.h which now uses distro boot.
This board has no upstream devicetree in the kernel source,
so set to socfpga_cyclone5_sr1500.dtb.
Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
Changes in v2:
- Remove unneeded CONFIG_BOOTFILE
- set devicetree name to match socfpga_{fpga model}_{board model}.dts
pattern
This removes the default environment from the socrates headers
Change default devicetree name to match devicetree name in
upstream kernel source.
Changes in v2:
This removes the default environment from the SoCKit headers
Changes in v2:
This removes the default environment from the de1 headers
This board does not have a devicetree in the upstream kernel
source so set devicetree to socfpga_cyclone5_de1_soc.dtb.
Changes in V2:
pattern
This removes the default environment from the C5 SoCDK headers
In addition to the above, add support to boot from the custom
a2 type partition.
Changes in v2:
This removes the default environment from the A5 socdk headers
Add support to boot from the custom a2 type partition.
Changes in v3:
- Fix small typo in defconfig, missing "C"
Changes in v2:
- Fix dtb name
a5config test
This removes the default environment from the de0 headers
a2 type partition
Changes in v2:
The board is now manufactured by Aries Embedded GmbH , rename it.
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Toradex Colibri Vybrid
module.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Rename CONFIG_FSL_DCU_FB to CONFIG_VIDEO_FSL_DCU_FB
and convert it to Kconfig.
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
Reviewed-by: Alison Wang <alison.wang@nxp.com>
Enable new Meson GX MMC driver in Odroid C2 defconfig.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Here with some DM changes as well as the long-standing AT91 DM/DT
conversion patches which I have picked up via dm.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Do not condition the compilation of the U_BOOT_DRIVER by !OF_PLATDATA.
This is inconsistent with the majority of other drivers. This also
blocks OF_PLATDATA boards with an 16550-compatible serial from using
serial in SPL.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
Added tweak for rock to avoid a TPL build failure:
Drop CONFIG_STACKSIZE from include/configs/imx6_logic.h
Logic PD has an i.MX6Q system on module (SOM) with a development kit. The
SOM has a built-in microSD socket, DDR and NAND flash. The development kit
has an SMSC Ethernet PHY, serial debug port and a variety of peripherals.
This have been verified to boot the i.MX6Q version over either SD
on the development kit or NAND built into the SOM. Items in the dtsi file
are specific to the SOM itself. Items in the dts file are in the baseboard.
Future versions of the SOM will come out supporting the same basebord and
potentially future base boards will come out supporting the same SOM.
Move the OPTEE load address to 0xbdb00000 in order to avoid
overlap with the memory regions used in radio and RVC usecases.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
Enable SPL_USB_HOST_SUPPORT in the default defconfig to allow
booting from USB peripherals. Unlike the non-HS boards, we
already load SPL to a 0x4030_0000+ address, so no other changes
are needed.
Enable CONFIG_SPL_USBETH_SUPPORT in the default defconfig to allow
booting as a USB RNDIS peripheral.
Enable Eth/Net boot support in the default defconfig to allow
network booting.
Additions have been made to the non-HS defconfig without the same
being made to the HS defconfig, sync them.
Sync new additions to non-HS defconfig with HS defconfig. Also add SPL
NAND support, this was disabled before due to size constraints, enable
this now at the expense of the less used GPT partition support.
TI K2G secure devices have to be built with TI_SECURE_DEVICE, FIT, and
FIT_IMAGE_POST_PROCESS enabled. Add a dedicated defconfig for this.
