path: root/configs
2016-04-27sunxi: Enable LDO3 at 3.3V on A13-OLinuXino boardHans de Goede
LDO3 is used for the VGA output, this fixes a regression where the VGA output on these boards would no longer work. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-26ARM: uniphier: revive some commands lost by Kconfig re-syncMasahiro Yamada
The recently added uniphier_ld20_defconfig missed the tree-wide re-sync by commit 89cb2b5f8be4 ("configs: Re-sync with cmd/Kconfig"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-25pico-imx6ul: Update the defconfigTom Rini
The defconfig/config.h file were merged but were already out of sync with mainline. This brings them further into line now. Cc: Richard Hu <richard.hu@technexion.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25ARM: hisilicon: hikey: Enable OF_CONTROL for hikey board.Peter Griffin
Currently only the serial pl01x driver is using DT, and the other drivers still use platform data but as more DT lands in the upstream kernel the aim is to migrate the other drivers over to DT as well to have a fully DT configured hikey u-boot. Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-25configs: Re-sync CONFIG_USB_MUSB_HOSTTom Rini
Now that CONFIG_USB_MUSB_HOST is part of Kconfig, migrate that over to the defconfig files. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-uniphierTom Rini
2016-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-04-24ARM: uniphier: add PH1-LD20 SoC supportMasahiro Yamada
This is the first ARMv8 SoC from Socionext Inc. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-20configs: Update some Xilinx configsTom Rini
As part of 3457bba these configs didn't get updated. Update them now. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: configs/bcm28155_ap_defconfig configs/dra72_evm_defconfig configs/dra74_evm_defconfig configs/ma5d4evk_defconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_PHY_* to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_OMAP to KconfigSam Protsenko
2016-04-20usb: dwc3: Move CONFIG_USB_DWC3_GADGET/HOST to KconfigSam Protsenko
Description was borrowed from kernel dwc3 Kconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-19Add initial support for Technexion's PICO-IMX6UL-EMMC boardFabio Estevam
Add support for Technexion's PICO-IMX6UL-EMMC board. For information about this board, please visit: http://www.technexion.com/products/pico/pico-som/pico-imx6-emmc Signed-off-by: Richard Hu <richard.hu@technexion.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-18bx50v3: Enable CONFIG_OF_LIBFDT in defconfigAkshay Bhat
As of commit 69e173eb57d1f4848f070c83456096ba5d2ba1b4, CONFIG_OF_LIBFDT needs to be selected in defconfig instead of board specific header file. Hence enable CONFIG_OF_LIBFDT in defconfig. Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
2016-04-18configs: ks2: move CMD_NAND to defconfigsLokesh Vutla
NAND is not yet enabled on all Keystone2 platforms. So enabled CMD_NAND in the respective defconfigs only if available. Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18memory: Move TI_AEMIF config to KCONFIGLokesh Vutla
Not all Keystone2 devices has AEMIF NAND controller. So adding Kconfig entry for CONFIG_TI_AEMIF and enabling it in respective defconfigs on platforms with AEMIF controller. Reported-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18am57x: Move CONS_INDEX to KconfigDaniel Allred
- Move the CONS_INDEX selection out of CONFIG_SYS_EXTRA_OPTIONS and into Kconfig proper. - Edit the relevant am57x configs to remove the now unneeded CONFIG_SYS_EXTRA_OPTIONS. Signed-off-by: Daniel Allred <d-allred@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18kconfig: Move CONFIG_OF_LIBFDT to KconfigMichal Simek
This patch follows work done by: "Move CONFIG_OF_LIBFDT to Kconfig" (sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4) Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Add xpress* to the patch] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-18bcm281xx: enable CONFIG_OF_LIBFDTSteve Rae
set the Kconfig parameter: CONFIG_OF_LIBFDT Signed-off-by: Steve Rae <srae@broadcom.com>
2016-04-18configs: dra74_evm: enable mmc driver modelMugunthan V N
enable mmc driver model for dra74 evm as omap_hsmmc supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-18configs: dra72_evm: enable mmc driver modelMugunthan V N
enable mmc driver model for dra72 evm as omap_hsmmc supports driver model Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-15sandbox: Enable many more commandsTom Rini
- Set CONFIG_SYS_CACHELINE_SIZE to ARCH_DMA_MINALIGN as that should be good enough. - Make <asm/io.h> include <asm/types.h> like other arches do - Enable many many more drivers in sandbox_defconfig so that we can get more build-time testing on this platform. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-04-13ARM64: zynqmp: Use i2c cadence DM driverMichal Simek
Use i2c cadence DM driver for all zynqmp targets except ZCU102 because I2C muxes and PCA953x are not supported in the tree yet. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-04-13ARM64: zynqmp: Enable CMD_GPIO and DM_GPIO for ep108Michal Simek
Enable missing GPIO options. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Add support for zc1751 with DC cardsMichal Simek
Support ZynqMP zc1751 with DC cards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Add defconfig for zcu102 revB boardMichal Simek
Support natively revB board. Till now support for revB was done via zcu102 defconfig where device-tree was changed to revB. This patch is adding direct defconfig for RevB. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Add support for ZCU102 platformMichal Simek
Add new board support. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Extend early malloc space to be able to run DM driversMichal Simek
DM drivers need more malloc space for early DM models allocation. Use 4k instead of 1k. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Do not setup DM_ETH/GPIO/MMC by default for all boardsMichal Simek
There are mini configurations which need to be fit to OCM that's why these options shouldn't be enabled by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Extend microzed board supportMichal Simek
Add missing DT nodes and enable USB. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
2016-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-04-12sunxi: Add defconfig and dts file for Orange Pi One SBCHans de Goede
The Orange Pi One SBC, is a stripped down version of the popular Orange Pi PC. The one is a H3 based SBC, with 512M of RAM, micro-sd slot, 1 host usb, 1 otg usb, hdmi and 100Mbit ethernet. The dts is identical to the dts submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-12sunxi: Enable usb ports on the Sinovoip BPI M3Hans de Goede
DLDO3 is used to provide Port-D power and PD is used for the usb-hub / sata-5v enable pins. The 2.5V comes from the schematic and matches the factory image fex file. The dts changes are the minimal changes needed for u-boot to pick-up the usb host controllers. The upstream kernel does not (yet) have usb host support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-12sunxi: Set DCDC1 to 3.3V on the Sinovoip BPI M3Hans de Goede
This is the value used in the fex file of the manufacturer images, and also the DCDC1 default. Sometimes lower values are used to save battery power, but that does not apply to a SBC. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-11ARM: add Raspberry Pi 3 64-bit configStephen Warren
On all Pis so far, the VC FW provides a short stub to set up the ARM CPU before entering the kernel (a/k/a U-Boot for us). This feature is not currently supported by the VC FW when booting in 64-bit mode. However, this feature will likely appear in the near future, and this U-Boot port assumes that such a feature is in place. Without that feature, or a temporary workaround described below, U-Boot will not boot. Once the VC FW does provide the ARM stub, u-boot.bin built for rpi_3 can be used drectly as kernel7.img, in the same way as any other RPi port. The following config.txt is required: # Fix mini UART input frequency, and setup/enable up the UART. # Without this option, U-Boot will not boot, even if you don't care # about the serial console. This option will always be required for # all RPi3 use-cases, unless the PL011 UART is used, which is not # yet supported by rpi_3* builds of U-Boot. enable_uart=1 # Boot in AArch64 (64-bit) mode. # It is possible that a future VC FW will remove the need for this # option, instead auto-setting 32-/64-bit mode based on the "kernel" # filename present on the SD card. arm_control=0x200 Prior to the VC FW providing the ARM boot stub, you can use the following steps to build an equivalent stub into the U-Boot binary: git clone https://github.com/swarren/rpi-3-aarch64-demo.git \ ../rpi-3-aarch64-demo (cd ../rpi-3-aarch64-demo && ./build.sh) Build U-Boot for rpi_3 in the usual way cat ../rpi-3-aarch64-demo/armstub64.bin u-boot.bin > u-boot.bin.stubbed Use u-boot.bin.stubbed as kernel7.img on the Pi SD card. In this case, the following additional entries are required in config.txt: # Tell the FW to load the kernel image at address 0, the reset vector. kernel_old=1 Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-11arm: socfpga: sr1500: Remove USB_GADGETSam Protsenko
"buildman" tool revealed that USB_GADGET was enabled by mistake for this board in process of moving that option to Kconfig. Remove it to bring things back to correct state. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Acked-by: Stefan Roese <sr@denx.de>
2016-04-10Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2016-04-10arm: socfpga: migration of CONFIG_SPI_FLASH_BARDenis Bakhvalov
CONFIG_SPI_FLASH_BAR was deleted from socfpga_common.h and placed in socfpga_*_defconfig because it is Kconfig symbol. Signed-off-by: Denis Bakhvalov <dendibakh@gmail.com> Reported-by: Denis Bakhvalov <dendibakh@gmail.com> Cc: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2016-04-10board: pic32mzda: enable USB-host, USB-storage support.Purna Chandra Mandal
Enable MUSB host and USB storage support for Microchip PIC32MZ[DA] Starter Kit. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
2016-04-06armv8: LS2080A: Consolidate LS2080A and LS2085AYork Sun
LS2080A is the primary SoC, and LS2085A is a personality with AIOP and DPAA DDR. The RDB and QDS boards support both personality. By detecting the SVR at runtime, a single image per board can support both SoCs. It gives users flexibility to swtich SoC without the need to reprogram the board. Signed-off-by: York Sun <york.sun@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2016-04-04Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
