Add default U-Boot configuration for the DHCOR SoM on AV96 board.
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
Cc: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Cc: Patrice Chotard <patrice.chotard@st.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic
- Enable USB Host for Odroid-C2 board
- Add Open-Drain/Open-Source emulation in GPIO uclass
https://gitlab.denx.de/u-boot/custodians/u-boot-ti
- Fix boot issues on Nokia RX-51
- Configure AM6 CPSW for 10Mbps in rgmii mode.
- Minor changes for J721e
Enable the second USB controller, which is connected to a hub with 4
ports. The first controller is for the OTG port and is currently not
supported.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
[narmstrong: removed useless DWC2_UTMI_WIDTH in meson64.h]
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Maximal allowed size of U-Boot binary for Nokia N900 is just 262144 bytes.
Signed-off-by: Pali Rohár <pali@kernel.org>
After this change both device display and serial console would contain
U-Boto output automatically without any future configuration. This would
allow easier debugging on real device as access to serial console is hard
and also in qemu emulator where it is easier to copy+paste from serial
console as from SDL framebuffer.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
In commit commit 43ede0bca7fc ("Kconfig: Migrate MTDIDS_DEFAULT /
MTDPARTS_DEFAULT") were removed definitions for onenand partitions.
Revert them back and enable needed options for onenand support.
In commit commit 37304aaf60bf ("Convert CONFIG_USE_PREBOOT and
CONFIG_PREBOOT to Kconfig") was moved complicated multiline script code
from C header to oneliner in defconfig. After this change multiline to wide
oneliner it is hard to read this code and even harder to debug. Moreover
this script code should be at place where are other scripts, so move it
back to C header file.
Define new env variable preboot which stores this script and in option
CONFIG_PREBOOT calls this preboot variable.
Beacon EmbeddedWorks, formerly known as Logic PD, is releasing
a devkit based on the i.MX8M Mini SoC consisting of baseboard +
SOM.
It supports eMMC on the SOM, microSD on the baseboard, various
GPIO, the PINCTRL, and UART.
It is safe to run SPL with caches enabled on i.MX8M, so
remove such restriction.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Add initial support for Technexion Pico-iMX8MQ SoM on PicoPI carrier
board. Currently working is ethernet, serial, eMMC. DT is imported
from Linux 5.4.28 ("462afcd6e7ea") .
Cc: Fabio Estevam <festevam@gmail.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
There is no reason to enable MEMTEST from headers when was converted to
Kconfig already.
Move CONFIG_SYS_MTDPARTS_RUNTIME into Kconfig done by moveconfig.py.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Move CONFIG_SET_DFU_ALT_INFO into Kconfig done by moveconfig.py.
Acked-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
The Juno board features a standard compliant EHCI/OHCI USB host
controller pair, which we can just enable.
The platform data is taken from the device tree.
This allows to use USB mass storage (the only storage on a Juno r0)
for loading.
At least on my board USB seems a bit flaky, I need two "usb reset"
sequences after the "usb start" to detect an USB hard drive.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Liviu Dudau <liviu.dudau@arm.com>
The Arm Juno board was still somewhat stuck in "hardcoded land", even
though there are stable DTs around, and one happens to actually be on
the memory mapped NOR flash.
Enable the configuration options to let the board use OF_CONTROL, and
add a routine to find the address of the DTB partition in NOR
flash, to use that for U-Boot's own purposes.
This can also passed on via $fdtcontroladdr to any kernel or EFI
application, removing the need to actually load a device tree.
Since the existing "afs" command and its flash routines require
flash_init() to be called before being usable, and this is done much
later in the boot process, we introduce a stripped-down partition finder
routine in vexpress64.c, to scan the NOR flash partitions for the
DT partition. This location is then used for U-Boot to find and probe
devices.
The name of the partition can be configured, if needed, but defaults
to "board.dtb", which is used by Linaro's firmware image provided.
- Add DM model for P1010RDB
- Add I2C DM Model support for P1010RDB, T1042RDB, T2080, T4240RDB,
MPC8548CDS, T1024RDB, P4080, P3041DS, P2041RDB, P2020RDB, P1020RDB,
P5040DS
- Fix reference to READM.qe_firmware
- Support 64-bit U-Boot as the payload for coreboot x86
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
i.MX for 2020.07
- imxrt: fix LCD clock, fix doc
- new board: Coral Dev
- imx8: enable Cache in SPL. SNVS, update SCFW API
- imx8MM: fix reset, 8MQ quand and QuadLite, CPU speed grading
- MX6ULL : is_imx6ull to include i.MX6ULZ
- Net: add config to enable TXC delay
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/682033914
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- dts clean up to use -u-boot for px30, rk3399 boards
- dts sycn from upstream kernel for rk3328, rk3399
- add rockchip rng driver
- new board support: rk3328-roc-cc, rk3399-roc-pc,Nanopi M4 2GB
Coreboot is a first-stage bootloader mostly used on x86 devices as an
alternative to UEFI. Coreboot runs in 32-bit mode.
U-Boot currently supports booting from coreboot as a second-stage
bootloader, also in 32-bit mode. However it is useful to be able to run
U-Boot in 64-bit mode. To do this we can have a 32-bit SPL which switches
over the CPU and jumps to a 64-bit U-Boot proper.
Add a new 'coreboot64' board for running 64-bit U-Boot from coreboot. This
uses binman to create an image with a 32-bit SPL and a 64-bit U-Boot.
This allows running 64-bit EFI images on x86, for example, without needing
a native U-Boot port for a board.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Enable the DM PCIe driver in P1010RDB defconfigs.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Add device tree for P1010RDB boards and enable CONFIG_OF_CONTROL
so that device tree can be compiled.
This enables DM_I2C and DM_RTC in T1042D4RDB defconfigs,
except T1042D4RDB SECURE_BOOT defconfig
Signed-off-by: Biwen Li <biwen.li@nxp.com>
This enables DM_I2C in T2080 defconfigs
This enable DM_I2C in T4240RDB defconfigs
This enables DM_I2C in MPC8548CDS defconfigs
Enable DM_I2C and DM_RTC in P1010RDB defconfigs,
except P1010RDB SECBOOT defconfigs.
This enables DM_I2C and DM_RTC in T1024RDB defconfigs,
except T1024RDB SECURE_BOOT defconfig
This enables DM_I2C in P4080DS defconfigs,
except P4080DS SRIO_PCIE_BOOT and SECURE_BOOT defconfigs
This enables DM_I2C in P3041DS defconfigs,
except P3041DS SECURE_BOOT and SRIO_PCIE_BOOT defconfig
This enables DM_I2C in P2041RDB defconfig,
except P2041RDB SRIO_PCIE_BOOT and SECURE_BOOT defconfigs
This enables DM_I2C and DM_RTC in P2020RDB defconfigs
This enables DM_I2C and DM_RTC in P1020RDB defconfigs
This enable DM_I2C in P5040DS defconfigs,
except P5040DS SECURE_BOOT defconfigs
CONFIG_SPL_FORCE_MMC_BOOT was removed in a previous patch as its
behavior is the correct one in all cases. Remove all uses of it from
defconfigs.
This reverts commit 3201e5b444ae3a13aa31e8b5101ad38d7ff0640d and removes
CONFIG_SPL_FORCE_MMC_BOOT from the imx28_xea defconfig.
Signed-off-by: Harald Seiler <hws@denx.de>
This patch enables distro boot for the bananapi-r2, based on
a MediaTek mt7623n.
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
Add initial support for Google's Coral Dev Board based on i.MX8MQ.
https://coral.ai/products/dev-board
The Phanbell naming has been used here to match the naming convention
used in Google's U-Boot source tree:
https://coral.googlesource.com/uboot-imx/
Co-developed-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Alifer Moraes <alifer.wsdm@gmail.com>
Tested-by: Marco Franchi <marcofrk@gmail.com>
Board files should not re-implement do_reset() to work around this
function not being defined in for specific configurations. Rather,
the fix is to compile in drivers which implement this properly.
This patch enables sysreset and watchdog drivers in SPL and ties
them together to implement the same as the do_reset() hack in the
board file, except correctly in the DM/DT framework.
Cc: Flavio Suligoi <f.suligoi@asem.it>
Cc: Harald Seiler <hws@denx.de>
Cc: Igor Opaniuk <igor.opaniuk@toradex.com>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Cc: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Acked-by: Igor Opaniuk <igor.opaniuk@toradex.com>
There is no need to run with caches disabled.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Currently the following watchdog error is seen in SPL:
U-Boot SPL 2020.04-00407-g8d5d3bcf3c (Apr 20 2020 - 09:48:09 -0300)
Normal Boot
WDT: Not found!
There is no watchdog driver for i.MX8 at the moment, nor code for
configuring the watchdog in SPL, so remove the CONFIG_SPL_WATCHDOG_SUPPORT
option for now.
It is safe to run SPL with caches enabled on i.MX8, so
Acked-by: Peng Fan <peng.fan@nxp.com>
Acked-by: Oliver Graute <oliver.graute@kococonnector.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
Tested-by: Igor Opaniuk <igor.opaniuk@toradex.com>
commit b2f5da9dd068 ("rockchip: rk3399: Add Nanopi M4 board support") added
support for Nanopi M4 board with Dual-Channel 4GB LPDDR3-1866 RAM.
This patch adds another variant of NanoPi M4 board with Dual-Channel
2GB DDR3-1866 RAM.
Signed-off-by: Deepak Das <deepakdas.linux@gmail.com>
Add Firefly ROC-RK3399-PC Mezzanine board which is an
extension board on top of roc-rk3399-pc.
Will drop the separate defconfig file, once we support
the board detection at runtime.
Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
The ROC-RK3328-CC from Firefly and Libre Computer Project is a credit
card size development board based on the Rockchip RK3328 SoC, with:
- 1/2/4 GB DDR4 DRAM
- eMMC connector for optional module
- micro SD card slot
- 1 x USB 3.0 host port
- 2 x USB 2.0 host port
- 1 x USB 2.0 OTG port
- HDMI video output
- TRRS connector with audio and composite video output
- gigabit Ethernet
- consumer IR receiver
- debug UART pins
The ROC-RK3328-CC has the enable pin of the SD card power switch tied
to GPIO_0_D6. This pin also has the function SDMMC0_PWREN, which is
muxed by default. SDMMC0_PWREN is an active high signal controlled by
the MMC controller, however the switch enable is active low, and
pulled low (enabled) by default to make things work on boot.
As such, we need to mux away from SDMMC0_PWREN and use GPIO to enable
power to the card. The default GPIO state for the pin is pull-down and
input, which doesn't require extra configuration when paired with the
external pull-down and active low switch.
Deal with this by enabling regulator support in SPL, and setting
"u-boot,dm-spl" for the regulator and other device nodes needed for
muxing the pin.
The device tree file is synced from the Linux kernel next-20200324.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
