path: root/configs
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-04rockchip: Add support for MiQi rk3288 boardJernej Skrabec
MiQi is rk3288 based development board with 1 or 2 GB SDRAM, 16 GB eMMC, micro SD card interface, 4 USB 2.0 ports, HDMI, gigabit Ethernet and expansion ports. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Eddie Cai <eddie.cai.linux@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-04defconfig: puma-rk3399: add defconfig for the RK3399-Q7 (Puma)Philipp Tomsich
This commit adds the baseline defconfig for the RK3399-Q7 (Puma) SoM (under the name 'puma-rk3399_defconfig') featuring the Rockchip RK3399 in a Qseven compatible module. This subsumes the following changes: * defconfig: rk3399: migrate CONFIG_SPL_LIBCOMMON_SUPPORT/CONFIG_SPL_LIBGENERIC_SUPPORT * defconfig: rk3399-puma: add CONFIG_MMC_DW_ROCKCHIP * defconfig: rk3399-puma: disable CONFIG_SPL_OF_PLATDATA * defconfig: rk3399-puma: don't USE_TINY_PRINTF * defconfig: rk3399-puma: set up CONFIG_SYS_BOARD for the RK3399-Q7 * defconfig: rk3399-puma: enable the multi-image loading via CONFIG_SPL_FIT * defconfig: rk3399-puma: SPL should be able to boot from MMC/SD card * defconfig: rk3399-puma: enable GMAC support * defconfig: rk3399-puma: enable support for SPI and Winbond SPI flash * defconfig: rk3399-puma: enable SPI as a boot-source in SPL * defconfig: rk3399-puma: disallow non-FIT images from being loaded * defconfig: rk3399-puma: rename to puma-rk3399 * rockchip: config: rk3399: update defconfigs and rk3399_common For the RK3399-Q7, we want a default boot-order of SPI -> MMC -> uSD. This both follows how the BootROM probes devices and is a sane default for customers in device-personalisation (e.g. it allows for quick and easy factory programming of unpersonalised devices using an SD card) and field usage (with customer devices expected to have their firmware either in SPI or MMC). However, when probing multiple interfaces (according to the result from the board_boot_order function), we need to ensure that only valid FIT images are considered and disable the fallback to assuming that a raw (binary-only) U-Boot image is loaded (to avoid hangs/crashes from jumping to random content loaded from devices that are probed, but don't contain valid image content). By disabling the SPL_RAW_IMAGE_SUPPORT and SPL_LEGACY_IMAGE_SUPPORT options, we ensure that raw images (indistinguishable from random data) are not considered for booting. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org> Drop CONFIG_DEBUG_UART_BOARD_INIT: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-04rockchip: rk3188: Add Radxa Rock boardHeiko Stübner
The Rock is a RK3188 based single board computer by Radxa. Currently it still relies on the proprietary DDR init and cannot use the generic SPL, but at least is able to boot a linux kernel and system up to a regular login prompt. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fix sort order in defconfig, enable CONFIG_SPL_TINY_MEMSET: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-04Merge git://git.denx.de/u-boot-tegraTom Rini
2017-04-04Merge git://www.denx.de/git/u-boot-marvellTom Rini
This includes Marvell mvpp2 patches with the ethernet support for the ARMv8 Armada 7k/8k platforms. The ethernet patches are all acked by Joe and he is okay with me pushing them via the Marvell tree.
2017-04-04Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-04-01apalis-tk1: disable external clock loopback on SDMMC3Marcel Ziswiler
Actually make use of that shiny new CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2017-04-01arm: tegra: initial support for apalis tk1Marcel Ziswiler
This patch adds board support for the Toradex Apalis TK1 a computer on module which can be used on different carrier boards. The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec. Furthermore, there is a Kinetis MK20DN512 companion micro controller for analogue, CAN and resistive touch functionality. For the sake of ease of use we do not distinguish between different carrier boards for now as the base module features are deemed sufficient enough for regular booting. The following functionality is working so far: - eMMC boot, environment storage and Toradex factory config block - Gigabit Ethernet - MMC/SD cards (both MMC1 as well as SD1 slot) - USB client/host (dual role OTG port as client e.g. for DFU/UMS or host, other two ports as host) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2017-03-29arm64: mvebu: Enable CONFIG_PHY_MARVELL in Armada7k/8k-DB defconfigStefan Roese
The Marvell PHY support is needed espescially for the A7040-DB with the SGMII port (port 2). As without the marvell PHY driver configuration for SGMII, ethernet won't work. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Stefan Chulski <stefanc@marvell.com> Cc: Kostya Porotchkin <kostap@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-03-29arm64: mvebu: armada-7k/8k: Enable MVPP2 ethernet driverStefan Roese
Since we've now integrated the A7k/8k support in the mvpp2 ethernet driver, lets enable the support for both Marvell developments boards. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-03-29arc: use timer driver for ARC boardsVlad Zakharov
This commit replaces legacy timer code with usage of arc timer driver. It removes arch/arc/lib/time.c file and selects CONFIG_CLK, CONFIG_TIMER and CONFIG_ARC_TIMER options for all ARC boards by default. Therefore we remove CONFIG_CLK option from less common axs101 and axs103 defconfigs. Also it removes legacy CONFIG_SYS_TIMER_RATE config symbol from axs10x.h, tb100.h and nsim.h configs files as it is no longer required. Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-29arc: dts: separate single axs10x.dts fileVlad Zakharov
We want to use the same device tree blobs in both Linux and U-Boot for ARC boards. Earlier device tree sources in U-Boot were very simplified and hadn't been updated for quite a long period of time. So this commit is the first step on the road to unified device tree blobs. First of all we re-organize device tree sources for AXS10X boards. As AXS101 and AXS103 boards consist of AXS10X motherboard and AXC001 and AXC003 cpu tiles respectively we add corresponding device tree source files: axs10x_mb.dtsi for motherboard, axc001.dtsi and axc003.dtsi for cpu tiles and axs101.dts and axs103.dts to represent actual boards. Also we delete axs10x.dts as it is no longer used. One more important change - we add timer device to ARC skeleton device tree sources as both ARC700 and ARCHS cores contain such timer. We add core_clk nodes to abilis_tb100, nsim, axc001 and axc003 device tree sources as it is referenced via phandle from timer node in common skeleton.dtsi file. Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-29arm: mvebu: Add gdsys ControlCenter-Compact boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Marvell Armada 38x SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2 x GbE - Xilinx Kintex-7 FPGA connected via PCIe - mSATA - USB3 host - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Mario Six <mario.six@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-29arm64: a37xx: Remove DM_I2C_COMPAT from the board configKonstantin Porotchkin
Remove DM_I2C_COMPAT from the board configurations for Armada 37xx platform boards for supressing the buid tim warning. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-29arm64: mvebu: Add default config for ESPRESSOBin boardKonstantin Porotchkin
Add initial default configuration for Marvell ESPRESSOBin community board based on Aramda-3720 SoC Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-29arm64: a37xx: Enable bubt command support on A3720-DBKonstantin Porotchkin
Enable mvebu bubt command support on A3720 DB Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-29arm64: mvebu: Rename the db-88f3720 to armada-37xx platformKonstantin Porotchkin
Modify the file names and deifinitions relater to Marvell db-77f3720 board support. Convert these names to more generic armada-37xx platform for future addition of more boards based on the same SoC family. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Igal Liberman <igall@marvell.com> Cc: Nadav Haklai <nadavh@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-29arm64: mvebu: Add default configuraton for MACCHIATOBin boardKonstantin Porotchkin
Add default configuration for MACHHIATOBin community board based on Aramda-8040 SoC. Change-Id: Ic6b562065c0929ec338492452f765115c15a6188 Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2017-03-29mmc: pci: Add CONFIG_MMC_PCIFelipe Balbi
We don't want pci_mmc to compile every time x86 compiles, only when there's a platform that needs it. For that reason, we're adding a new CONFIG_MMC_PCI which platforms can choose to enable. Suggested-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-03-28fsl-layerscape/ls104xardb: enable PPA support for eMMC/SD and NAND bootHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-28board: freescale: ls2080a/ls2088a: Enable PPASantan Kumar
Enable PPA on LS2080A, LS2088A boards: -LS2080ARDB, LS2080AQDS -LS2088ARDB, LS2088AQDS Signed-off-by: Santan Kumar <santan.kumar@nxp.com> Signed-off-by: Abhimanyu Saini <abhimanyu.saini@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-26net: sunxi: Enable eeprom on OLinuXino Lime boardsoliver@schinagl.nl
This patch enables the I2C EEPROM to be probed for a MAC address on the OLinuXino Lime1 and Lime2 boards. Other boards surely qualify as well but were not tested yet. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
2017-03-24Merge git://git.denx.de/u-boot-arcTom Rini
This replaces legacy arch/arc/lib/timer.c implementation and allows us to describe ARC Timers in Device Tree. Among other things that way we may properly inherit Timer's clock from CPU's clock s they really run synchronously.
2017-03-24arc: use timer driver for ARC boardsVlad Zakharov
2017-03-24arc: dts: separate single axs10x.dts fileVlad Zakharov
2017-03-23arm: mvebu: Add gdsys ControlCenter-Compact boardDirk Eibach
2017-03-23arm64: a37xx: Remove DM_I2C_COMPAT from the board configKonstantin Porotchkin
2017-03-23arm64: mvebu: Add default config for ESPRESSOBin boardKonstantin Porotchkin
2017-03-23arm64: a37xx: Enable bubt command support on A3720-DBKonstantin Porotchkin
2017-03-23arm64: mvebu: Rename the db-88f3720 to armada-37xx platformKonstantin Porotchkin
2017-03-23arm64: mvebu: Add default configuraton for MACCHIATOBin boardKonstantin Porotchkin
2017-03-21Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2017-03-21mmc: pci: Add CONFIG_MMC_PCIFelipe Balbi
2017-03-21configs: am43xx_evm: Enable SPL_DMLokesh Vutla
Enable SPL_DM on all AM43xx based platforms Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-21configs: dra7xx_evm: Enable SPL_DMLokesh Vutla
Enable SPL_DM on all DRA7 based platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-03-21configs: am57xx_evm: Enable SPL_DMLokesh Vutla
Enable SPL_DM on all AM57xx based platforms. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-03-20board: ns2: Add support for Broadcom Northstar 2Jon Mason
Add support for the Broadcom Northstar2 SoC and SVK (bcm958712k). The BCM5871X is a series of quad-core 64-bit 2GHz ARMv8 Cortex-A57 processors targeting a broad range of networking applications. Signed-off-by: Jon Mason <jon.mason@broadcom.com>
2017-03-19Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/bk4r1_defconfig configs/colibri_vf_defconfig configs/pcm052_defconfig include/configs/colibri_vf.h include/configs/pcm052.h
2017-03-19imx: ventana: add EMMC configurationTim Harvey
Prepare for boards with EMMC instead of NAND flash Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2017-03-19ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-03-19colibri_imx7: use device-tree for MTD partitionsStefan Agner
Use device-tree fixup to communicate the MTD partitions to the kernel. Remove mtdparts from the kernel command line. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-03-19toradex apalis/colibri: add device tree overlay supportStefan Agner
Device tree overlays might prove useful in the future, enable it by default on all Toradex modules. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-03-19toradex apalis/colibri: use common USB product id fallbackStefan Agner
All modules use the common g_dnl_bind_fixup implementaton which calculates the PID according to product id (read from the config block) plus offset of 0x4000. In case there is no config block support (e.g. SPL) or in case the config block is not readable, fall back to a generic product id (product id 0, which can be interpreted as "Unknown Module"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-03-19arm: i.MX6UL: add Armadeus Systems OPOS6UL SoM and OPOS6ULDev carrier boardSébastien Szymanski
OPOS6UL is an i.MX6UL based SoM with 256MB RAM, 4GB eMMC and an ethernet phy. OPOS6ULDev is carrier board for the OPOS6UL. U-Boot SPL 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09) Trying to boot from MMC1 U-Boot 2017.03-rc3-00002-g5085c26 (Mar 07 2017 - 09:48:09 +0100) CPU: Freescale i.MX6UL rev1.0 528 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 40C Reset cause: POR Model: Armadeus Systems OPOS6UL SoM on OPOS6ULDev board DRAM: 256 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 Video: 800x480x18 In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-03-18spl: Convert CONFIG_SPL_ABORT_ON_RAW_IMAGE into a positive optionAndrew F. Davis
CONFIG_SPL_ABORT_ON_RAW_IMAGE causes SPL to abort and move on when it encounters RAW images, express this same functionality as a positive option enabling support for RAW images: CONFIG_SPL_RAW_IMAGE_SUPPORT Also move uses of this to defconfigs. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Rework Kconfig logic a little, move to common/spl/Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-17Merge git://git.denx.de/u-boot-rockchipTom Rini
This includes support for rk3188 from Heiko Stübner and and rk3328 from Kever Yang. Also included is SPL support for rk3399 and a fix for rk3288 to get it booting again (spl_early_init()).
2017-03-17PINCTRL: stm32f7: add pin control driverVikas Manocha
This driver uses the same pin control binding as that of linux, binding document of this patch is copied from linux. One addition done is for GPIO input and output mode configuration which was missing. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
