- H6 Beelink GS1 board (Clément)
- Olimex A64-Teres-I board (Jonas)
- sunxi build fix for CONFIG_CMD_PXE|DHCP (Ondrej)
- Change include order (Jagan)
- EPHY clock changes (Jagan)
- EMAC enablement on Cubietruck Plus, BPI-M3 (Chen-Yu Tsai)
The Bananapi M3 has an RTL8211E PHY connected to the EMAC using
RGMII. The PHY is powered by DCDC1 through SW @ 3.3V.
The board is designed to use 3.3V with RGMII, instead of the standard
reduced voltage of 2.5V we see everywhere. DLDO3, which provides the
I/O voltages, is raised to match.
This patch enables the EMAC and Realtek PHY drivers in the defconfig.
The device tree file already has the EMAC enabled.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
The Cubietruck Plus has an RTL8211E PHY connected to the EMAC using
RGMII. The PHY is powered by DLDO4 @ 3.3V, while the I/O pins are
powered by DLDO3 @ 2.5V.
Olimex A64-Teres-I board is a mainboard (the only one so far)
for Olimex Teres-I DIY laptop kit.
Key features:
- Allwinner A64 Cortex-A53
- Mali-400MP2 GPU
- AXP803 PMIC
- 2GB DDR3 RAM
- MicroSD Slot
- 16GB eMMC Flash
- eDP LCD display
- HDMI
- USB Host
- Battery management
- 5V DC power supply
- Certified Open Source Hardware (OSHW)
Works:
- i2C
- MMC/SD
- PWM backlight
Known broken:
- Internal keyboard (seems to be because the keyboard firmware loads a
bootloader first, and then disconnects bootloader and connect real
keyboard). External ones connected to the USB port work fine.
This patch enables support for the A64-Teres-I board to u-boot,
including enabling screen backlight (lacking from Linux device-tree).
Linux commit details about the sun50i-a64-teres-i.dts sync:
"arm64: dts: allwinner: a64: Rename uart0_pins_a label to uart0_pb_pins"
(sha1: d91ebb95b96c8840932dc3a10c9f243712555467)
Cosmetic warnings regarding whitespace and placement of SPDX notice for
dts file was ignored.
config and .dtsi file are adapted from pinebook files.
Tested-by: Jonas Smedegaard <dr@jones.dk>
Signed-off-by: Jonas Smedegaard <dr@jones.dk>
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
[jagan: move board entry in MAINTAINERS file at proper position]
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Add a version of samus which supports booting from TPL to SPL and then
to U-Boot. This allows TPL to select from an A or B SPL to support
verified boot with field upgrade.
This is again too small, so increase it slightly.
- RZ/A1 addition.
- Old board removal.
- Assorted stratix10 fixes.
- DDR driver DM migration.
Add board code and DTs for Renesas RZ/A1 SoC-based GR-Peach,
which is a cheap development platform with RZ/A1H SoC. The
DTs are imported from Linux 5.0.11, commit d5a2675b207d .
Currently supported are UART, ethernet and RPC SPI. The board
can be booted from RPC SPI by writing the u-boot.bin binary
to the beginning of the SPI NOR, e.g. using the "sf" command.
The board can also be booted via JTAG by setting text base to
0x20020000, loading u-boot.bin there via JTAG and executing it
from that address.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Chris Brandt <chris.brandt@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Last change to this board was done in 2016, it uses non-DM USB
with no prospects of ever being converted to DM USB, drop it.
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Convert Stratix 10 SDRAM driver to device model.
Get rid of call to socfpga_per_reset() and use reset
framework.
SPL is changed from calling function in SDRAM driver
directly to just probing UCLASS_RAM.
Move sdram_s10.h from arch to driver/ddr/altera directory.
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
The DA850 EVM has one USB 1.1 OHCI Host controller. With the
host controller now support DM_USB, this patch enables
the respective functions for the da850evm.
The size of the SPL for the am335x_evm is constrained. There is no need
to have advanced SPL FIT features, so keep the SPL FIT support tiny.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
- mscc: small fixes, enhance network support for Serval, Luton and Ocelot
- mt7620: rename arch to more generic name mtmips
- mips: pass initrd addresses via DT as physical addresses
CONFIG_SUPPORT_EMMC_BOOT
As requested by Michal Simek <michal.simek@xilinx.com>, these boards
have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated:
xilinx_zynqmp_zc1275_revB
xilinx_zynqmp_zc1751_xm018_dc4
xilinx_zynqmp_zc1751_xm019_dc5
xilinx_zynqmp_zcu100_revC
xilinx_zynqmp_zcu102_rev1_0
xilinx_zynqmp_zcu102_revA
xilinx_zynqmp_zcu102_revB
xilinx_zynqmp_zcu104_revA
xilinx_zynqmp_zcu104_revC
xilinx_zynqmp_zcu106_revA
xilinx_zynqmp_zcu111_revA
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Acked-by: Patrick Delaunay <patrick.delaunay@st.com>
Acked-by: Ramon Fried <ramon.fried@gmail.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
- Fix in kwbimage (return code checking) (Young Xiao)
- Misc updates to Turris Omnia (Marek)
Currently mach-mt7620 contains only support for mt7628. To avoid confusion,
rename mach-mt7620 to mach-mtmips, which means MediaTek MIPS platforms.
MT7620 and MT7628 should be distinguished by SOC_MT7620 and SOC_MT7628
because they do not share the same lowlevel codes.
Dependencies of four drivers are changed to SOC_MT7628 as these drivers
are only used by MT7628.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Update default config to use network driver for Serval SoCs.
Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
- Various btrfs fixes
- Various TI platform fixes
- Other fixes (cross build, taurus update, Kconfig help text)
Add am335x-pocketbeagle to CONFIG_OF_LIST in am335x_evm_defconfig.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
- at91sam9g20-taurus.dts: use labels
- cleanup taurus port to compile clean with
current mainline again. SPL has no serial
output anymore, so it fits into SRAM.
This options will be enabled by default by CZ.NIC shipped U-Boot. Enable
them in defconfig.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Add support for the gpio command and driver for the I2C connected
pca9538 controller, to be able to determine if SFP module is present in
the Turris Omnia router.
This driver is required for Turris Omnia to read ethernet addresses.
Move the dependency from turris_omnia_defconfig to Kconfig.
Enable AHCI, SCSI and SATA for compliance with the driver model
migration.
Add XHCI_HOST and XHCI_MVEBU to defconfig, so that user's can by default
boot from USB on Turris Omnia.
Improvements and new features:
- improved SPI driver for better read throughput
- refactors initialisation of debug UART init
- restructures header file paths
- adds pinctrl improvements
Adds Kever as a co-custodian.
Porting to DM and i.MX8
- warp7 to DM
- kp_imx53 to DM
- Warnings in DT
- MX8QM support
- colibri-imx6ull to DM
- imx7d-pico to DM
- ocotp for MX8
Use board_debug_uart_init() for UART iomux init instead of
do it in board_init_f, and move the function to soc file so
that we can find all the soc/board setting in soc file and
use a common board file.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[Fixed whitespace error:]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Enable debug uart for kylin board in defconfig.
Add initial support for Orangepi RK3399 board.
Specification
- Rockchip RK3399
- 2GB/4GB DDR3
- 16GB eMMC
- SD card slot
- RTL8211E 1Gbps
- AP6356S WiFI/BT
- HDMI In/Out, DP, MIPI DSI/CSI
- Mini PCIe
- Sensors, Keys etc
- DC12V-2A and DC5V-2A
Commit details about Linux DTS sync:
"arm64: dts: rockchip: Add support for the Orange Pi RK3399"
(sha1: d3e71487a790979057c0fdbf32f85033639c16e6)
Over the last quarter, a part of our production has used NOR flash
from Gigadevice in addition to the Winbond parts that we typically
source. This requires the SPI_FLASH_GIGADEVICE config to be set.
Enable SPI_FLASH_GIGADEVICE in the board's default defconfig.
Reviewed-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
The da850evm include environment/ti/mmc.h and places
DEFAULT_MMC_TI_ARGS, defined int that file, in
CONFIG_EXTRA_ENV_SETTINGS. This has been broken for some time
since neither CMD_PART nor CMD_UUID are available, so manually
changing the environmental variables was always required before
booting from MMC. With this patch, these scripts should work
again, and by default they point to mmc 0, partition 2, and
the dtb file exists in a /boot directory on partition 2.
A previous patch converted a bunch of settings for CONFIG_SF_DEFAULT
but it broke the SPI Flash which now prevents booting. This patch
now correctly sets CONFIG_SF_DEFAULT_SPEED=30000000 to match what it
was before the conversion.
Fixes: 14453fbfadc2 ("Convert CONFIG_SF_DEFAULT_* to Kconfig")
Add new defconfig files for the AM65x High Security EVM.
This defconfigs are the same as for the non-secure part, except for:
CONFIG_TI_SECURE_DEVICE option set to 'y'
CONFIG_FIT_IMAGE_POST_PROCESS option set to 'y'
CONFIG_SPL_FIT_IMAGE_POST_PROCESS option set to 'y'
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
- Add DM based generic watchdog start and reset implementation
and remove all ad-hoc implementations (Stefan)
- Move mv_sdhci to DM (Pierre)
- Misc turris_omnia updates (Pierre)
- Change openrd targets to correctly build again (size changes
and fixes to the dts targets) and bring it back into Travis
builds (Stefan)
- Add Kirkwood db-88f6281-bp board (Chris)
With the new generic function, the scattered other functions are now
removed to be replaced by the generic one. The new version also enables
the configuration of the watchdog timeout via the DT "timeout-sec"
property (if enabled via CONFIG_OF_CONTROL).
The watchdog servicing is enabled via CONFIG_WATCHDOG.
Cc: Eugen Hristev <eugen.hristev@microchip.com>
With the latest changes to the drivers (SPI_FLASH_SPANSION etc), Travis
reports that the SPL image is too big. Let's use the thumb instructions
in SPL to save some space and make the image fit again.
Cc: Baruch Siach <baruch@tkos.co.il>
Cc: Marek Behun <marek.behun@nic.cz>
Reviewed-by: Marek Behún <marek.behun@nic.cz>
Switch to the driver model for USB on the db-88f6281-bp board.
CONFIG_BLK can't be enabled yet because mvebu_mmc.c needs converting.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This is Marvell's Kirkwood development board. It has the following
features
- 512M DDR2
- 2 PCI connectors
- 1 x1 PCI-e interface
- 1 Gigabit Ethernet Port
- 2 SATA Ports
- USB 2.0 Interface
- SDIO
- 128M NAND Flash
- 16M SPI Flash
It can be strapped to boot from SPI or NAND so there are two defconfigs
(one per boot media).
Enable DM_MMC for compliance with the driver model migration.
Signed-off-by: Pierre Bourdon <delroth@gmail.com>
1. Replace usage of "/dev/mmcblk*p*" with a proper UUID of rootfs
partition. This fixes the issue, when MMC controllers are probed in
a different order in U-boot and Linux kernel.
2. Fix legacy USB command (both sdboot and usbboot can be used now).
Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
This commit switches to DM USB for warp7 and warp7_bl33 defconfigs.
Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Signed-off-by: Joris Offouga <offougajoris@gmail.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
This commit switches to DM SERIAL for warp7 and warp7_bl33 defconfigs.
Port for the DART-6UL Evaluation Kit SBC. Based on the variscite
DART-6UL iMX6ULL SoM.
CPU: Freescale i.MX6ULL rev1.1 900 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C) at 43C
Reset cause: POR
Model: Variscite DART-6UL Evaluation Kit
Board: Variscite DART-6UL Evaluation Kit
DRAM: 512 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial@02020000
Out: serial@02020000
Err: serial@02020000
Net: FEC0
Working:
- Eth0
- i2c
- MMC/SD
- eMMC
- USB host
- UART 1
Note: LCDIF porting needs DM_VIDEO
https://lists.denx.de/pipermail/u-boot/2019-April/365506.html
Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
This patch enable convert DM MMC for imx7d-pico board and variant.
Before the DM conversion only usdhc3 was enabled and therefore it appeared
as MMC 0 to u-boot. After enabling MMC DM though usdhc3 defaults to MMC 2,
which left unattended would drive changes to existing pico-pi bootscripts and
environment variables that rely on mmc 0.
Setup the alias of mmc0 and usdhc3 so that existing pico-imx7d boot code will
work unmodified.
When converting to DM_MMC it is necessary that SPL initializes eMMC
by itself, so move the original eMMC initialization from U-Boot
proper to SPL.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
