path: root/configs
2015-05-05Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2015-05-05Merge git://git.denx.de/u-boot-marvellTom Rini
2015-05-05arm: mvebu: Add Armada A38x DB-88F6820-GP board supportStefan Roese
This patch adds support for the Marvell DB-88F6820-GP Armada A38x evaluation board. Supported peripherals are: - UART - Ethernet (mvneta) - I2C - SPI (including SPI NOR flash) Please note that this board support right now only supports the main U-Boot. Without the bin_hdr integration (DDR training etc). This will be added in a few days / weeks to complete this board port. But till then this U-Boot version can be run on the target via the original Marvell U-Boot via this command: tftpboot 4000000 db-88f6820-gp/u-boot.bin;go 4000000 Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-05-04Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2015-05-04powerpc/mpc85xx: Add board support for ucp1020Oleksandr G Zhadan
New QorIQ p1020 based board support from Arcturus Networks Inc. http://www.arcturusnetworks.com/products/ucp1020/ Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com> Signed-off-by: Oleksandr G Zhadan <oleks@arcturusnetworks.com> [York Sun: remove patman tags from commit message] Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-04powerpc/t4240qds: Update RCW, defconfig and maintainerShaohui Xie
1. board/freescale/t4qds/t4_rcw.cfg 1.8GHz support is requested as default frequency, so update the rcw. 2. remove un-used configs configs/T4160QDS_SPIFLASH_defconfig configs/T4240QDS_SPIFLASH_defconfig SPI boot is not available on T4QDS, so the configs should be removed. 3. board/freescale/t4qds/MAINTAINERS Updated MAINTAINERS accordingly. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> [York Sun: revise subject] Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-04powerpc/t1023rdb: Add T1023 RDB board supportShengzhou Liu
T1023RDB is a Freescale Reference Design Board that hosts the T1023 SoC. T1023RDB board Overview ----------------------- - T1023 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - Memory: 2GB Micron MT40A512M8HX unbuffered 32-bit fixed DDR4 without ECC - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - one 1G RGMII port on-board(RTL8211F PHY) - one 1G SGMII port on-board(RTL8211F PHY) - one 2.5G SGMII port on-board(AQR105 PHY) - PCIe: Two Mini-PCIe connectors on-board. - SerDes: 4 lanes up to 10.3125GHz - NOR: 128MB S29GL01GS110TFIV10 Spansion NOR Flash - NAND: 512MB S34MS04G200BFI000 Spansion NAND Flash - eSPI: 64MB S25FL512SAGMFI010 Spansion SPI flash. - USB: one Type-A USB 2.0 port with internal PHY - eSDHC: support SD/MMC card and eMMC on-board - 256Kbit M24256 I2C EEPROM - RTC: Real-time clock DS1339 on I2C bus - UART: one serial port on-board with RJ45 connector - Debugging: JTAG/COP for T1023 debugging As well updated T1024RDB to add T1023RDB. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: fix defconfig files] Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-04powerpc/t4rdb: Add SD boot support for T4240RDB boardChunhe Lan
This patch adds SD boot support for T4240RDB board. SPL framework is used. PBL initializes the internal RAM and copies SPL to it. Then SPL initializes DDR using SPD and copies u-boot from SD card to DDR, finally SPL transfers control to u-boot. Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> [York Sun: Fix T4240RDB_SDCARD_defcofig] Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-04mpc85xx/T4240EMU: Remove T4240EMU boardYork Sun
T4240 SoC has been available for a long time. Emulator support is no longer needed. Signed-off-by: York Sun <yorksun@freescale.com>
2015-05-04sunxi: Move all boards to the driver-modelHans de Goede
Now that we've everything prepared for it remove the DM settings from the defconfig(s) and simply always set them for sunxi. This makes all sunxi boards allways use the driver model for gpios and ethernet, and allows us to move over more bits to the driver-model without the need to introduce #ifdef-ery for boards which are not yet using DM. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: axp: Move axp gpio code to a separate axpi-gpio driverHans de Goede
Move the axp-gpio code out of the drivers/power/axp*.c code, and into a new separate axpi-gpio driver. This change drops supports for the gpio3 pin on the axp209, as that requires special handling, and no boards are using it. Besides cleaning things up by moving the code to a separate driver, as a bonus this change also adds support for the (non vusb) gpio pins on the axp221 and the gpio pins on the axp152. The new axp-gpio driver gets its own Kconfig option, and is only enabled on boards which need it. Besides that it only gets enabled in the regular u-boot build and not for the SPL as we never need it in the SPL. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Add Ippo_q8h_v1_2_a33_1024x600 defconfigHans de Goede
Add a defconfig for generic 7" tablets using the Ippo q8h v1.2 pcb, with an A33 SoC (the pcb can take an A23 or an A33), and a 1024x600 LCD. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Add softwinner astar mid756 A33 tablet board defconfigVishnu Patekar
The Astar MID756 is a 7" tablet using the A33 SoC with a 800x480 LCD screen, 512M RAM, 8G ROM and integrated sdio wifi. Also see: http://linux-sunxi.org/Softwinner_astar-rda Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: s/sun8i/sun8i_a23/Hans de Goede
This is a preparation patch for adding A33 support, which will have a mach name of sun8i-a33. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-30x86: Enable multi-core init for Minnowboard MAXSimon Glass
Enable the CPU uclass and Simple Firmware interface for Minnowbaord MAX. This enables multi-core support in Linux. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-29x86: Kconfig: Remove deprecated CONFIG_SYS_EXTRA_OPTIONSBin Meng
Currently all x86 boards still use CONFIG_SYS_EXTRA_OPTIONS to define the text base address. Since it is deprecated, just remove it and use CONFIG_SYS_TEXT_BASE directly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: Kconfig: Divide the target selection to vendor/modelBin Meng
Let arch/x86/Kconfig prompt board vendor first, then select the board model under that vendor. This way arch/x86/Kconfig only needs concern board vendor and leave the supported target list to board/<vendor>/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: queensbay: Implement PIRQ routingBin Meng
Implement Intel Queensbay platform-specific PIRQ routing support. The chipset PIRQ routing setup is called in the arch_misc_init(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29x86: minnowmax: Remove CONFIG_VIDEO_X86 in the defconfigBin Meng
CONFIG_VIDEO_X86 has been replaced by CONFIG_VIDEO_VESA. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-04-29ARM: zynq: rename CONFIG_ZYNQ to CONFIG_ARCH_ZYNQMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-29zynq: Add Zynq PicoZed board supportNathan Rossi
The PicoZed is a System-on-Module board which is marketed as part of the ZedBoard/MicroZed/etc. collection. It includes a Zynq-7000 processor. This patch adds support that covers all the variants of the PicoZed including the SKUs with Z7010/Z7020 and Z7015/Z7030 Zynq chips. This patch set however only covers support for the System-on-Module and does not cover any extra components that are available on carrier boards (except those that are fanned out of the module itself). More information on this board, its variants and available carrier boards is available at: http://zedboard.org/product/picozed Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-04-27mx6cuboxi: Prepare for multi SoC supportFabio Estevam
Cubox-i and Hummingboard support several MX6 SoCs: mx6solo, mx6dual-lite, mx6dual and mx6quad. Use IOMUX_PADS() macro in order to prepare for the multi-SoC support. Also pass 'MX6QDL' in the defconfig to indicate it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-04-23armv8/ls2085ardb: Enable NAND SPL supportScott Wood
Enable NAND boot support using SPL framework. To boot from NAND, either use DIP switches on board, or "qixis_reset nand" command. Details of forming NAND image can be found in README. Signed-off-by: Scott Wood <scottwood@freescale.com> [York Sun: Remove +S from defconfig after commit 252ed872] Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23armv8/ls2085aqds: NAND boot supportScott Wood
This adds NAND boot support for LS2085AQDS, using SPL framework. Details of forming NAND image can be found in README. Signed-off-by: Scott Wood <scottwood@freescale.com> [York Sun: Remove +S from defconfig after commit 252ed872] Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23ARM: vf610: Initial integration for Colibri VF50/VF61Sanchayan Maity
This adds initial support for Colibri VF50/VF61 based on Freescale Vybrid SoC. - CPU clocked at 396/500 MHz - DDR3 at 396MHz - for VF50, use PLL2 as memory clock (synchronous mode) - for VF61, use PLL1 as memory clock (asynchronous mode) - Console on UART0 (Colibri UART_A) - Ethernet on FEC1 - PLL5 based RMII clocking (E.g. No external crystal) - UART_A and UART_C I/O muxing - Boot from NAND by default Tested on Colibri VF50/VF61 booting using serial loader over UART. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Stefan Agner <stefan@agner.ch>
2015-04-23davinci: add support for omapl138-lcdk boardPeter Howard
Signed-off-by: Peter Howard <phoward@gme.net.au> [trini: Add config file, update for ..._ether_addr() -> ..._ethaddr() rename] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-23armv8/ls2085ardb: Add support of LS2085ARDB platformYork Sun
The LS2085ARDB is a evaluation platform that supports LS2085A family SoCs. This patch add sbasic support for the platform. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-04-23armv8/ls2085aqds: Add support of LS2085AQDS platformYork Sun
The LS2085AQDS is an evaluatoin platform that supports the LS2085A family SoCs. This patch add basic support of the platform. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
2015-04-23ARM: integrator: split board select into AP/CP select and CM selectMasahiro Yamada
Select integrator boards by the combination of platform select (AP/CP) and core module select (CM720T, CM920T, ...). This allows us to remove CONFIG_SYS_EXTRA_OPTIONS and make Kconfig much cleaner. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
2015-04-23ARM: integrator: move board select into mach-integrator/KconfigMasahiro Yamada
The board/SoC select menu in arch/arm/Kconfig is still cluttered. Add ARCH_INTEGRATOR into arch/arm/Kconfig and move the board select under arch/arm/mach-integrator. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
2015-04-22stm32f4: Add support for stm32f429-discovery boardrev13@wp.pl
Signed-off-by: Kamil Lulko <rev13@wp.pl> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-22mx6: Add initial SPL support for HummingBoard-i2eXFabio Estevam
Add the initial SPL support for HummingBoard-i2eX, which is based on a MX6 Dual. For more information about HummingBoard, please check: http://www.solid-run.com/products/hummingboard/ Based on the work from Jon Nettleton and Rabeeh Khoury. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-21ls102xa: ddr4: Use LPUART as console output to verify DCU driverAlison Wang
On QDS board with DDR4 DIMM, LPUART is used as console output to verify DCU driver. This patch adds ls1021aqds_ddr4_nor_lpuart_defconfig for this support. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-18sandbox: exynos: Move CONFIG_SOUND_SANDBOX to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: exynos: Move CONFIG_SOUND_WM8994 to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_SOUND_MAX98095 to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_I2S_SAMSUNG to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_I2S to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_CMD_SOUND to KconfigSimon Glass
2015-04-18sandbox: exynos: Move CONFIG_SOUND to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_TPM_TIS_SANDBOX to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_SPI_FLASH_SANDBOX to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_SANDBOX_SPI to KconfigSimon Glass
2015-04-18sandbox: Move CONFIG_SYS_I2C_SANDBOX to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher<hs@denx.de>
2015-04-18sandbox: Move CONFIG_SYS_VSNPRINTF to KconfigSimon Glass
2015-04-18sandbox: Move GPIO CONFIGs to KconfigSimon Glass
Move these over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
