trini: Make Kconfig SPL_xxx entires only show if SPL, so that we don't
get Kconfig errors on platforms without SPL, ie sandbox (without SPL).
CONFIG_LZMA
CONFIG_CMD_IRQ
CONFIG_CMD_JFFS2
CONFIG_CMD_IOLOOP
CONFIG_CMD_IMMAP
Also move this command out of the cmd/ directory since it is
PowerPC-specific.
CONFIG_CMD_IDE
CONFIG_CMD_HDMIDETECT
Note that we cannot do 'default y if VIDEO' because this option is only
enabled for a small subset of mx6 boards. Also this command is is not a
great implementation (it doesn't use driver model).
CONFIG_CMD_HD44760
Also drop CONFIG_CMD_HD44780 which appears to be a typo.
CONFIG_CMD_HASH
[trini: Rework slightly, enable on some boards again]
CONFIG_CMD_GSC
CONFIG_CMD_FUSE
CONFIG_CMD_FPGA_LOADBP
CONFIG_CMD_FPGA_LOADFS
CONFIG_CMD_FPGA_LOADMK
CONFIG_CMD_FPGA_LOADP
CONFIG_CMD_FPGAD
CONFIG_CMD_FDC
CONFIG_CMD_ETHSW
Also enable it for sandbox to increase build coverage.
CONFIG_CMD_ERRATA
CONFIG_CMD_ENV_FLAGS
CONFIG_CMD_ENV_CALLBACK
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
CONFIG_CMD_EECONFIG
CONFIG_CMD_ECCTEST
This subsystem has not been converted to driver model, there is only one
driver and only one board that uses it. Drop it and its CONFIG option.
Also drop the rtc4543 RTC driver since it uses TWS.
CONFIG_DS4510
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support
using hardware acceleration.") created entries for CONFIG_SHA1,
CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL.
However, no defconfig has migrated to it. Complete the move by first
adding additional logic to various Kconfig files to select this when
required and then use the moveconfig tool. In many cases we can select
these because they are required to implement other drivers. We also
correct how we include the various hashing algorithms in SPL.
This commit was generated as follows (after Kconfig additions):
[1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL
[2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL
Note:
We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously
because there is dependency between them.
Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Cc: Naveen Burmi <NaveenBurmi@freescale.com>
Cc: Po Liu <po.liu@freescale.com>
Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Priyanka Jain <Priyanka.Jain@freescale.com>
Cc: Shaohui Xie <Shaohui.Xie@freescale.com>
Cc: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Chander Kashyap <k.chander@samsung.com>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Feng Li <feng.li_2@nxp.com>
Cc: Alison Wang <alison.wang@freescale.com>
Cc: Sumit Garg <sumit.garg@nxp.com>
Cc: Mingkai Hu <Mingkai.Hu@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
We rename CONFIG_FIT_DISABLE_SHA256 to CONFIG_FIT_ENABLE_SHA256_SUPPORT which
is enabled by default and now a positive option. Convert the handful of boards
that were disabling it before to save space.
Cc: Lukasz Dalek <luk0104@gmail.com>
CONFIG_SPL_BOARD_INIT
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
[trini: Update the Kconfig logic]
Support Andestech AE3xx platform: serial, timer device tree flow.
Signed-off-by: rick <rick@andestech.com>
Support AG101P timer device tree flow.
Support AG101P serial device tree flow.
Add minor ifdeffery and default board config for the Salvator-XS board
with R8A7796 M3 SoC.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Rename the salvator-x_defconfig to r8a7795_salvator-x_defconfig in
preparation for the r8a7796 support on salvator-x board.
Add support for the EHCI USB.
Add support for the AVB ethernet on the Salvator-X board.
Add support for the SD card slots on the Salvator-X board.
Set default device tree file in the salvator-x_defconfig
and use it in the environment.
Move these two Kconfig symbols to the salvator-x_defconfig.
The Salvator-X can have both H3 and M3 CPU on it, drop the
select R8A7795 to allow both configurations.
Add config and defconfig for the Arria10 and update socfpga_common.h.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
mx7dsabresd_secure_defconfig was not updated after moving to DM.
Switch to use DM USB.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Enable more DM drivers. The imx I2C/MMC DM drivers needs DM_GPIO
enabled. The 74x164 drivers needs SOFT_SPI and DM_GPIO enabled.
So needs to enable them together.
Add basic dts for i.MX7D-SDB board.
Now that mx6sabresd_spl_defconfig can be used to boot all
mx6sabresd variants, the non-SPL targets can be safely removed.
Signed-off-by: Fabio Estevam <fabio.estvam@nxp.com>
Currently only MX6Q/QP sabresd boards are supported in SPL.
In order to also support MX6DL we need to convert to using
IOMUX_PADS and SETUP_IOMUX_PADS macros.
Other than that move the <asm/arch/mx6-ddr.h> header inclusion to the
SPL code block in order to avoid build error.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
SPL FIT is able to pick the suitable fdt file for u-boot,
so add that function through board_fit_config_name_match.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Set fdt_file env variable during board_late_init
