path: root/configs
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-26ARM: da850evm: Fix TI boot scripts for MMCAdam Ford
The da850evm include environment/ti/mmc.h and places DEFAULT_MMC_TI_ARGS, defined int that file, in CONFIG_EXTRA_ENV_SETTINGS. This has been broken for some time since neither CMD_PART nor CMD_UUID are available, so manually changing the environmental variables was always required before booting from MMC. With this patch, these scripts should work again, and by default they point to mmc 0, partition 2, and the dtb file exists in a /boot directory on partition 2. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-26ARM: da850evm: Fix broken SPI FlashAdam Ford
A previous patch converted a bunch of settings for CONFIG_SF_DEFAULT but it broke the SPI Flash which now prevents booting. This patch now correctly sets CONFIG_SF_DEFAULT_SPEED=30000000 to match what it was before the conversion. Fixes: 14453fbfadc2 ("Convert CONFIG_SF_DEFAULT_* to Kconfig") Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-26configs: Add configs for AM65x High Security EVMAndrew F. Davis
Add new defconfig files for the AM65x High Security EVM. This defconfigs are the same as for the non-secure part, except for: CONFIG_TI_SECURE_DEVICE option set to 'y' CONFIG_FIT_IMAGE_POST_PROCESS option set to 'y' CONFIG_SPL_FIT_IMAGE_POST_PROCESS option set to 'y' Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Andreas Dannenberg <dannenberg@ti.com>
2019-04-26Merge git://git.denx.de/u-boot-marvellTom Rini
- Add DM based generic watchdog start and reset implementation and remove all ad-hoc implementations (Stefan) - Move mv_sdhci to DM (Pierre) - Misc turris_omnia updates (Pierre) - Change openrd targets to correctly build again (size changes and fixes to the dts targets) and bring it back into Travis builds (Stefan) - Add Kirkwood db-88f6281-bp board (Chris)
2019-04-26Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2019-04-26watchdog: at91sam9_wdt: Remove now superfluous wdt start and resetStefan Roese
With the new generic function, the scattered other functions are now removed to be replaced by the generic one. The new version also enables the configuration of the watchdog timeout via the DT "timeout-sec" property (if enabled via CONFIG_OF_CONTROL). The watchdog servicing is enabled via CONFIG_WATCHDOG. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-04-26arm: mvebu: turris_omnia: Use thumb instructions in SPL to save spaceStefan Roese
With the latest changes to the drivers (SPI_FLASH_SPANSION etc), Travis reports that the SPL image is too big. Let's use the thumb instructions in SPL to save some space and make the image fit again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Baruch Siach <baruch@tkos.co.il> Cc: Marek Behun <marek.behun@nic.cz> Reviewed-by: Marek BehĂșn <marek.behun@nic.cz>
2019-04-26ARM: kirkwood: enable CONFIG_DM_USB on db-88f6281-bpChris Packham
Switch to the driver model for USB on the db-88f6281-bp board. CONFIG_BLK can't be enabled yet because mvebu_mmc.c needs converting. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-26ARM: kirkwood: add db-88f6281-bp boardChris Packham
This is Marvell's Kirkwood development board. It has the following features - 512M DDR2 - 2 PCI connectors - 1 x1 PCI-e interface - 1 Gigabit Ethernet Port - 2 SATA Ports - USB 2.0 Interface - SDIO - 128M NAND Flash - 16M SPI Flash It can be strapped to boot from SPI or NAND so there are two defconfigs (one per boot media). Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-26arm: mvebu: turris_omnia: use MMC driver modelPierre Bourdon
Enable DM_MMC for compliance with the driver model migration. Signed-off-by: Pierre Bourdon <delroth@gmail.com> Cc: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-25colibri_imx6: use UUID for rootfsIgor Opaniuk
1. Replace usage of "/dev/mmcblk*p*" with a proper UUID of rootfs partition. This fixes the issue, when MMC controllers are probed in a different order in U-boot and Linux kernel. 2. Fix legacy USB command (both sdboot and usbboot can be used now). Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25warp7: Switch to DM USBPierre-Jean Texier
This commit switches to DM USB for warp7 and warp7_bl33 defconfigs. Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io> Signed-off-by: Joris Offouga <offougajoris@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-04-25warp7: Switch to DM SerialPierre-Jean Texier
This commit switches to DM SERIAL for warp7 and warp7_bl33 defconfigs. Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io> Signed-off-by: Joris Offouga <offougajoris@gmail.com> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-04-25imx: Add variscite DART-6UL Evaluation KitParthiban Nallathambi
Port for the DART-6UL Evaluation Kit SBC. Based on the variscite DART-6UL iMX6ULL SoM. CPU: Freescale i.MX6ULL rev1.1 900 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C) at 43C Reset cause: POR Model: Variscite DART-6UL Evaluation Kit Board: Variscite DART-6UL Evaluation Kit DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial@02020000 Out: serial@02020000 Err: serial@02020000 Net: FEC0 Working: - Eth0 - i2c - MMC/SD - eMMC - USB host - UART 1 Note: LCDIF porting needs DM_VIDEO https://lists.denx.de/pipermail/u-boot/2019-April/365506.html Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
2019-04-25pico-imx7d: Convert DM MMCJoris Offouga
This patch enable convert DM MMC for imx7d-pico board and variant. Before the DM conversion only usdhc3 was enabled and therefore it appeared as MMC 0 to u-boot. After enabling MMC DM though usdhc3 defaults to MMC 2, which left unattended would drive changes to existing pico-pi bootscripts and environment variables that rely on mmc 0. Setup the alias of mmc0 and usdhc3 so that existing pico-imx7d boot code will work unmodified. When converting to DM_MMC it is necessary that SPL initializes eMMC by itself, so move the original eMMC initialization from U-Boot proper to SPL. Signed-off-by: Joris Offouga <offougajoris@gmail.com> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-04-25pico-imx7d: defconfig Enable DM gpio pinctrl and pinctrl_imx7Joris Offouga
This patch is necessary for convert this board to dm driver model DM GPIO requires gpio_request() to be called explicitly before doing any gpio operation Signed-off-by: Joris Offouga <offougajoris@gmail.com>
2019-04-25pico-imx7d: defconfig: Add DT file hooksJoris Offouga
This patch adds DT file hooks for Pico i.MX7D SOM and variant boards Signed-off-by: Joris Offouga <offougajoris@gmail.com>
2019-04-25colibri-imx6ull: migrate fec to using driver modelMarcel Ziswiler
Migrate Ethernet FEC to using driver model. Drop PHY_MICREL_KSZ90X1 which slipped in from Apalis iMX6. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25colibri-imx6ull: migrate usb to using driver modelMarcel Ziswiler
Migrate USB to using driver model. Add USBH_PEN GPIO regulator. While at it also add alias e.g. as required for UMS. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25colibri-imx6ull: migrate mmc to using driver modelMarcel Ziswiler
Migrate MMC to using driver model. Migrate USDHC to using pinctrl. While at it also add GPIO1_IO03__OSC32K_32K_OUT pin muxing. While at it also update copyright period. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25colibri-imx6ull: migrate pinctrl and regulators to dtb/dmMarcel Ziswiler
Migrate pinctrl and regulators to device tree resp. driver model: Ethernet, NAND and UART. Drop BOARD_EARLY_INIT_F as it is anyway no longer used. Enable CMD_DM, CMD_MTD, CMD_REGULATOR and DM_REGULATOR_FIXED. While at it also update copyright period. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25colibri-imx6ull: configuration clean-upMarcel Ziswiler
Drop disabling SPL_SYS_THUMB_BUILD as we anyway do not use SPL. Enbale CRC32 verify, USB SDP and EFI loader support. Drop CMD_GPT and disabling RANDOM_UUID. Do savedefconfig which drops USB_FUNCTION_SDP. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
2019-04-25imx: support i.MX8QM MEK boardPeng Fan
Add i.MX8QM MEK board support. Included a basic dts, enabled SPL FIT Boot log as below: U-Boot SPL 2019.01-rc1-00029-gf002213219 (Dec 24 2018 - 10:28:30 +0800) Normal Boot Trying to boot from MMC2_2 U-Boot 2019.01-rc1-00029-gf002213219 (Dec 24 2018 - 10:28:30 +0800) CPU: NXP i.MX8QM RevB A53 at 142933 MHz Model: Freescale i.MX8QM MEK Board: iMX8QM MEK Build: SCFW 9330215b Boot: SD1 DRAM: 6 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial@5a060000 Out: serial@5a060000 Err: serial@5a060000 Net: Error: ethernet@5b040000 address not set. eth-1: ethernet@5b040000 Hit any key to stop autoboot: 0 Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-25Convert CONFIG_USB_EHCI_MX5 to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_USB_EHCI_MX5 Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-25ARM: defconfig: kp_imx53: Enable DM_USB support on HSC|DDC boardsLukasz Majewski
This commit enables the DM_USB on HSC|DDC i.MX53 based boards. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-25ARM: defconfig: Move CONFIG_FSL_ESDHC to KconfigLukasz Majewski
The CONFIG_FSL_ESDHC is now enabled and defined in Kconfig, not in include/configs/kp_imx53.h Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-25imx8qxp: mek: enable dm-spl for pmPeng Fan
with u-boot,dm-spl added for imx8qx-pm node, and SPL_SIMPLE_BUS enabled, the bind and probe code in board file could be removed. Also we need to enlarge SYS_MALLOC_F_LEN to avoid calloc fail. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-25ARM: omap3_logic: Enable UUIDAdam Ford
Instead of hardcoding the mmcroot to /dev/mmcblkX, use the UUID method. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-25ARM: imx6q_logic: Allow storing environment in FAT on eMMCAdam Ford
Some variations of the imx6q_logic board have eMMC instead of NAND. Rather than creating a separate defconfig, this patch adds the ability to read/write to eMMC (mmc 0:1) when NAND doesn't exist. Signed-off-by: Adam Ford <aford173@gmail.com>
2019-04-25imx8: mek: move HUSH_PARSER to defconfigPeng Fan
Move HUSH_PARSER to defconfig, otherwise meet " => run netboot Booting from net ... Unknown command 'if' - try 'help' Unknown command 'then' - try 'help' Unknown command 'else' - try 'help' Unknown command 'fi' - try 'help' Unknown command '0x80280000' - try 'help' Unknown command 'if' - try 'help' Unknown command 'then' - try 'help' Unknown command 'then' - try 'help' Unknown command 'else' - try 'help' Unknown command 'fi' - try 'help' Unknown command 'else' - try 'help' Unknown command 'fi' - try 'help' " Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-25imx8qxp: mek: Enable CMD_FUSEPeng Fan
Enable CMD_FUSE for i.MX8QXP MEK Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-25arm: socfpga: move vining_fpga to DM_I2CSimon Goldschmidt
All socfpga boards except for vining_fpga use DM_I2C. Enable DM_I2C for this board and set the EEPROM defines via Kconfig (enabling CONFIG_I2C_EEPROM from MISC). Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Series-changes: 2 - added (this) patch to move socfpga_vining to DM_I2C
2019-04-25arm: socfpga: imply/default common config optionsSimon Goldschmidt
This commit moves common config options used in all socfpga boards to select/imply in Kconfig. This both cleans up the defconfig files as well as makes future changes easier. Options implied/defaulted for all sub-arches: - SPL, SPL_DM, USE_TINY_PRINTF, NR_DRAM_BANKS Options implied/defaulted for implied for A10 & gen5: - FPGA_SOCFPGA, SYS_MALLOC_F_LEN, SYS_TEXT_BASE Options implied/defaulted for gen5: - SPL_STACK_R, SPL_SYS_MALLOC_SIMPLE, SPL_STACK_R_ADDR Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2019-04-25configs: socfpga: socrates: enable rtc supportSimon Goldschmidt
This enables DM_RTC and RTC_M41T62 to enable support for the rtc on the socrates board. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2019-04-24Merge tag 'pull-24apr19' of git://git.denx.de/u-boot-dmTom Rini
Various minor sandbox iumprovements Fixes for tracing with sandbox Refactoring for boot_get_fdt()
2019-04-24Merge tag 'efi-2019-07-rc1-3' of git://git.denx.de/u-boot-efiTom Rini
Pull request for UEFI sub-system for v2019.07-rc1 (3) This patch series reworks the implementation of the `bootefi` command to remove code duplication by using the LoadImage() boot service to load binaries. Missing short texts for UEFI protocols are added for display by the `efidebug dh` command. Missing parameter checks for AllocatePages() and CreateDeviceNode() are implemented. The constants for protocol GUIDs are changed to match the names in the UEFI specification.
2019-04-24Merge tag 'u-boot-stm32-mcu-20190423' of https://github.com/pchotard/u-bootTom Rini
STM32 MCUs update: - DT rework and alignment with DT kernel v4.20 - mmc: arm_pl180_mmci: Synchronize compatible with kernel v4.20 - mmc: stm32_sdmmc2: Synchronize properties with kernel v4.20 - configs: update for F746/769 boards
2019-04-24Merge tag 'u-boot-amlogic-20190423' of git://git.denx.de/u-boot-amlogicTom Rini
- Add support for Amlogic p200 & p201 Reference Designs - Add Amlogic SoC information display - Add support for the Libretech-AC AML-S805X-AC board - Add Amlogic AXG reset compatible - Add I2C support for Amlogic AXG - Fix AXG PIN and BANK pinctrl definitions - Fix regmap_read_poll_timeout warning about sandbox_timer_add_offset - Add initial support for Amlogic G12A SoC and U200 board - Enable PHY_REALTEK for selected boards - Fix Khadas VIM2 README
2019-04-23sandbox: Move pre-console buffer out of the way of tracingSimon Glass
These two buffers currently conflict if tracing is enabled. Move the pre-console buffer and update the documentation. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-04-23poplar: enable Ethernet driver supportShawn Guo
The 'phy' reset of gmac device in kernel device tree is not generic enough for u-boot to use, so we need to overwrite the 'resets' property as needed. With this device tree fixup and poplar_defconfig changes, Ethernet starts working on Poplar board. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-04-23bcm963158: enable led supportPhilippe Reynes
Enable the led support in the configuration of the board bcm963158. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-04-23bcm968580xref: enable led supportPhilippe Reynes
Enable the led support in the configuration of the board bcm968580xref. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-04-23configs: stm32f746-disco: Enable SPI_FLASH_MACRONIXPatrice Chotard
This config file is shared between stm32f746-disco and stm32f769-disco. These 2 boards doesn't embed the same qspi flash (Micron n25q128a on f746-disco, Macronix mx66l51235l on f769-disco). To be able to use Macronix mx66l51235l on F769-disco, flags SPI_FLASH_MACRONIX must be enabled. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-04-23configs: stm32f746-disco: enable CONFIG_DISTRO_DEFAULTSPatrice Chotard
Allows to boot linux distribution Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2019-04-23board: amlogic: enable PHY_REALTEK for selected boardsNeil Armstrong
When using the generic PHY on boards using an RGMII Realtek PHY, gigabit speed is not always reliable. This patch enables the Realtek PHY driver for such boards. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-23boards: meson: add g12a u200Jerome Brunet
The Amlogic U200 board is based on the Amlogic S905D2 SoC from the Amlogic G12A SoC family. The board has the following specifications : - Amlogic S905D2 ARM Cortex-A53 quad-core SoC - XGB DDR4 SDRAM - 10/100 Ethernet (Internal PHY) - 1 x USB 3.0 Host - eMMC - SDcard - Infrared receiver - SDIO WiFi Module - MIPI DSI Connector - Audio HAT Connector - PCI-E M.2 Connector Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-23efi_loader: disable EFI_LOADER on vexpress_ca15_tc2 and ca9x4Heinrich Schuchardt
vexpress_ca15_tc2_defconfig and vexpress_ca9x4_defconfig do not provide device trees (as $fdtcontroladdr) as needed to pass our Travis CI tests. As we are on the move to requiring block devices to be based on the driver model these boards either will have to be converted to use device trees or will be kicked out of U-Boot. So let's disable CONFIG_EFI_LOADER on these boards until the device tree issue is resolved. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
