path: root/configs
2018-09-28configs: sama5d3_xplained: add onewire and eeprom driversEugen Hristev
SAMA5D3 SoC can have extra clip boards (PDAs) connected, which have an EEPROM memory for identification. A special GPIO can be used to read this memory over 1wire protocol. Enabling one wire and eeprom drivers for this memory. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28configs: sama5d2_xplained: add onewire and eeprom driversEugen Hristev
SAMA5D2 SoC can have extra clip boards (PDAs) connected, which have an EEPROM memory for identification. A special GPIO can be used to read this memory over 1wire protocol. Enabling one wire and eeprom drivers for this memory. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28configs: sandbox: add onewire w1 and sandbox eepromEugen Hristev
To be able to test Dallas onewire protocol and one wire eeproms driver and subsystem, add in sandbox defconfig the drivers' config. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28video_osd: Add osd sandbox driver and testsMario Six
Add sandbox driver and tests for the new OSD uclass. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-27powerpc: dts: Enable device tree support for T2080QDSJagdish Gediya
Add device tree for T2080QDS board and enable CONFIG_OF_CONTROL so that device tree can be compiled. Update board README for device tree usage. Signed-off-by: Jagdish Gediya <jagdish.gediya@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27arm: ls1021atwr: enable DM support for sataPeng Ma
Enable related configs to support sata DM feature. Signed-off-by: Peng Ma <peng.ma@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27arm64: ls1043aqds: enable DM support for sataPeng Ma
2018-09-27Enable CONFIG_BLK and CONFIG_DM_MMC to KconfigYinbo Zhu
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27Merge tag 'xilinx-for-v2018.11' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx changes for v2018.11 - Handle BOARD_LATE_INIT via Kconfig SPL: - Enable GZIP for all partitions types(not only for kernel) ZynqMP: - Rearrange pmufw version handling - Support newer PMUFW with improved fpga load sequence Zynq: - Cleanup config file - Simplify zybo config by enabling option via Kconfig net: - Fix gems max-speed property reading - Enable support for fixed-link phys
2018-09-26Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-09-26 A lot of goodness in this release. We're *very* close to running the UEFI Shell and SCT natively. The only missing piece are HII protocols. - FAT write support (needed for SCT) - improved FAT directory support (needed for SCT) - RTC support with QEMU -M virt - Sandbox support (run UEFI binaries in Linux - yay) - Proper UTF-16 support - EFI_UNICODE_COLLATION_PROTOCOL support (for UEFI Shell) - EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL support (for UEFI Shell) - Fix window size determination - Fix Tegra by explicitly unmapping RAM - Clean up handle entanglement - Lots of generic code cleanup [trini: Fixup merge conflict in include/configs/qemu-arm.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-26arm: zynq: zybo: migrate CONFIG_DISPLAY to defconfigLuis Araneda
Only add CONFIG_DISPLAY to defconfig because CONFIG_I2C_EDID is automatically selected by CONFIG_DISPLAY Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-26arm64: zynqmp: Handle CONFIG_BOARD_LATE_INIT via KconfigMichal Simek
Disable BOARD_LATE_INIT via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-25configs: am335x_evm: enable OF_BOARD_SETUPSekhar Nori
Enable CONFIG_OF_BOARD_SETUP as it is needed for Beaglebone black to overwrite the Ethernet phy address present in DT in case the phy latches on to a different address. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-25configs: sama5d27_som1_ek: Add defconfig for ENV/boot from uSDCodrin Ciubotariu
This adds a defconfig for sama5d27_som1_ek board to get environment from uSD. The defconfig is made from sama5d27_som1_ek_mmc_defconfig, with 'bootcmd' and 'bootargs' changed to kernel, device-tree and rootfs from uSD. The environment is expected to be found in uSD's FAT partition. Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@microchip.com>
2018-09-25configs: sama5d27_som1_ek: Set CONFIG_BOOTARGS using KconfigCodrin Ciubotariu
CONFIG_BOOTARGS can be set using Kconfig, so we no longer need it in the config files. Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@microchip.com>
2018-09-25configs: sama5d2_xplained: Add defconfig for ENV/boot from eMMCCodrin Ciubotariu
This adds a defconfig for sama5d2_xplained board to get environment from eMMC. The defconfig is made from sama5d2_xplained_mmc_defconfig, with 'bootcmd' and 'bootargs' changed to kernel, device-tree and rootfs from eMMC. The environment is expected to be found in eMMC's FAT partition. Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@microchip.com>
2018-09-25configs: stm32mp15: Enable USB relative flagsPatrice Chotard
Enable config USB relative flags in order to enable USB EHCI, DWC2 gadget, download and mass_storage support. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-09-23efi_selftest: test qemu-arm(64)_defconfigHeinrich Schuchardt
We should run the EFI selftest on both a 32bit and a 64bit ARM platform on Travis to catch possible errors. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23efi: sandbox: Enable selftest commandSimon Glass
Enable this for sandbox since it almost passes now. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23efi_loader: unset CONFIG_EFI_UNICODE_CAPITALIZATIONHeinrich Schuchardt
Unset CONFIG_EFI_UNICODE_CAPITALIZATION on boards with tough size restrictions. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-09-23mips: Add Gardena Smart-Gateway board supportStefan Roese
The Gardena Smart-Gateway boards have a MT7688 SoC with 128 MiB of RAM and 8 MiB of flash (SPI NOR) and additional 128MiB SPI NAND storage. This patch also includes 2 targets. One is the target that can be programmed into the SPI NOR flash and a 2nd target "xxx-ram" is added to support loading and booting via an already running U-Boot version. This allows easy development and testing without the need to flash the image each time. Signed-off-by: Stefan Roese <sr@denx.de> [fixed and regenerated defconfig files] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-23mips: Add LinkIt Smart 7688 supportStefan Roese
The LinkIt Smart 7688 modules have a MT7688 SoC with 128 MiB of RAM and 32 MiB of flash (SPI NOR). This patch also includes 2 targets. One is the target that can be programmed into the SPI NOR flash and a 2nd target "xxx-ram" is added to support loading and booting via an already running U-Boot version. This allows easy development and testing without the need to flash the image each time. Signed-off-by: Stefan Roese <sr@denx.de> [fixed and regenerated defconfig files] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-09-22bcm968380gerg: enable pinctrlPhilippe Reynes
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2018-09-19Merge git://git.denx.de/u-boot-imxTom Rini
- changes in pico-* boards - fix imx6ull pinmux
2018-09-19board: turris_mox: Fixup U-Boot's device tree if PCIe connectedMarek BehĂșn
If PCIe Mox module is connected we want to have PCIe node enabled in U-Boot's device tree. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-09-19board: turris_mox: Enable PCI in defconfigMarek BehĂșn
Enable the pci-aardvark driver in defconfig for Turris Mox and also enable the pci command. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-09-18pico-imx7d: Add a new defconfig with PICO-Hobbit selectedOtavio Salvador
This adds a new defconfig which pre-selects the PICO-Hobbit baseboard allowing a completely non-interactive boot process. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-18pico-imx6ul: Add a new defconfig with PICO-Pi selectedOtavio Salvador
This adds a new defconfig which pre-selects the PICO-Pi baseboard allowing a completely non-interactive boot process. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-18Merge branch 'master' of git://git.denx.de/u-boot into masterStefano Babic
2018-09-15arm: socfpga: stratix10: Add CONFIG_OF_EMBEDDalon Westergreen
The dtb should be embedded in the u-boot-spl image so that the CONFIG_SPL_TARGET of spl/u-boot-spl.hex includes it. This also affects the main u-boot image, so adjust CONFIG_SPL_FS_LOAD_PAYLOAD_NAME to u-boot.img which now also includes the dtb. Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
2018-09-14Revert "ARM: da850evm_direct_nor_defconfig: Enable DM_SERIAL"Tom Rini
This commit is breaking several variants of da850, so: This reverts commit 5f389201dece76b484443773dce2525dc205f5a1. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-14pico-imx6ul: Add Falcon mode supportOtavio Salvador
Falcon mode boots the kernel directly from SPL, without loading the full U-Boot. As pico-imx6ul does not have a GPIO for selecting Falcon versus normal mode, enter in Falcon mode when the customer selects the CONFIG_SPL_OS_BOOT option in menuconfig. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-14pico-imx6ul: Add new pico-hobbit configOtavio Salvador
The new config skips the boot menu which asks which board is in use. This is useful to allow direct booting of image without user iteration. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-14pico-imx6ul: Add bootmenu to choose the baseboardOtavio Salvador
Currently the baseboards do not offer a way to autodetect which one is in use, so we ask the user if no value has been set. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-14pico-imx6ul: Sync defconfig with new changesOtavio Salvador
Due the changes in previous commits, we need to resync the defconfig to reduce noise in next commits. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-14pico-imx6ul: Add bmode supportFabio Estevam
The 'bmode' command is helpful for switching the boot media. In the case of pico-imx6ul there are two possible boot media: eMMC or USB. To boot from eMMC: => bmode emmc To boot from USB (via Serial Download Protocol): => bmode usb Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-14pico-imx6ul: Add fastboot supportFabio Estevam
fastboot tool is a convenient way to flash the eMMC, so add support for it. Examples of usages: On the pico-imx6ul U-Boot prompt: => fastboot 0 On the Linux PC connected via USB: 1. Retrieving the U-Boot version $ sudo fastboot getvar bootloader-version -i 0x0525 bootloader-version: U-Boot 2018.07-rc2-00130-g0881835-dirty finished. total time: 0.000s 2. Resetting the board $ sudo fastboot reboot -i 0x0525 (this causes the pico-imx6ul to reboot) Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-14pico-imx6ul: Convert to SPLFabio Estevam
There are two versions of imx6ul pico SOMs: one with 256MB and another one with 512MB of RAM. Convert to SPL so that both versions can be supported. This patch doesn't rework the clock initialization to avoid changing the behavior in this same patch, so it will be cleaned up in future. Currently only the 256MB is tested/supported. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-14pico-imx6ul: Convert to distro configFabio Estevam
Instead of keeping a custom environment, use a more generic approach by switching to distro config. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-09-11Configs: am3517_evm: Remove TWL4030 referenceAdam Ford
This SOM and kit do not nor have they ever had a twl4030 PMIC. This patch removes the references to it. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: omap3_logic: Enable DM_PMIC and DM_REGULATORAdam Ford
Enabling DM_PMIC, DM_REGULATOR_FIXED, and DM_REGULATOR_GPIO gives us the ability to better monitor voltages and enable hardware through the device tree. The TL4030 (TPS65950) is not yet migrated to DM, so this patch only enables the fixed and GPIO controlled regulators. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: da850evm_direct_nor_defconfig: Enable DM_SERIALAdam Ford
With DM enabled, this patch enables DM_SERIAL and removes the NS16550 initialization from da850_lowlevel since the driver will take care of that itself. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: davinci: omapl138_lcdk: Enable DM_MMCAdam Ford
With DM_MMC now available, this patch enables DM_MMC for the omapl138_lcdk in U-Boot and keeps the older style for SPL. Signed-off-by: Peter Howard <phoward@gme.net.au> Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: davinci: da850evm: Support DM_MMCAdam Ford
With the updated driver available to support DM_MMC, this patch enables DM_MMC for da850evm. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: omap3_logic: Enable PinctrlAdam Ford
The simple pinctrl driver currently available works with the omap3. Enabling this will use the device tree to automatically set the pin-muxing for various drivers. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: omap3_logic_defconfig: Convert to DM_SPLAdam Ford
The OF_CONTROL and OF_PLATDATA are not really useful without DM. This patch supports DM_SPL, but it requires manual references both Serial and MMC. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: configs: Add da850evm_nand to boot from NANDAdam Ford
The DA850-EVM supports booting from NAND when used with the UI expander board. da850evm_nand will create an ais file that can be burned to NAND and booted while storing the env in NAND along with some partitions tables for storing kernel, dtb and rootfs in NAND. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11ARM: da850evm_direct_nor: Enable CONFIG_BLKAdam Ford
At least for now, CONFIG_BLK is working, but this variant of the da850evm doesn't need/support SPL so it's OK to enable it here. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-11Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2018-09-11configs: am65x_evm_a53: Add initial supportLokesh Vutla
Add initial defconfig support for AM65x that runs on A53. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
