path: root/configs
2014-08-24nios2: remove obsolete PCI5441 and PK1C20 boardsThomas Chou
2014-08-21powerpc: mpc8xx: remove FLAGADM board supportMasahiro Yamada
This board has been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove GEN860T, GEN806T_SC board supportMasahiro Yamada
These boards have been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove SXNI855T board supportMasahiro Yamada
2014-08-21powerpc: mpc8xx: remove svm_sc8xx boardMasahiro Yamada
2014-08-21powerpc: mpc8xx: remove stxxtc board supportMasahiro Yamada
2014-08-21omap: remove omap5912osk board supportMasahiro Yamada
Emails to the board maintainer "Rishi Bhattacharya <rishi@ti.com>" have been bouncing. Tom suggested to remove this board. Remove also omap1510_udc.c because this is the last board to enable it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Tom Rini <trini@ti.com>
