The config option AM33XX is used in several boards and should be
defined as a stand-alone option for this SOC. We break this out
from target boards that use this SoC and common headers then enable
AM33XX on in all the boards that used these targets to eliminate any
functional change with this patch.
This is similar to what has already been done in
9de852642cae ("arm: Kconfig: Add support for AM43xx SoC specific Kconfig")
and is done for the same reasons.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
include/configs/dra7xx_evm.h
Enable USB driver model for Toradex Colibri Vybrid modules.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Commit ce02a71c2374 "tegra: dts: Sync tegra20 device tree files with
Linux" enabled the ULPI USB port on Ventana, but made no attempt to ensure
that U-Boot code could handle this. In practice, various code is missing,
and various configuration options are not enabled, which causes U-Boot to
hang when attempting to initialize this USB port. This patch enables ULPI
PHY support on Ventana, and adds the required pinmux setup for the port to
operate. Note that Ventana is so similar to Seaboard that this change is
made in the Seaboard board file, which is shared with Ventana.
Seaboard also has the ULPI USB port wired up in hardware, although to an
internal port that often doesn't have anything attached to it. However,
the DT nodes for the USB controller and PHY had different status property
values, so the port was not initialized by U-Boot. Fix this inconsistency,
and enable the ULPI port, just like in the Linux kernel DT. This likewise
requires enabling ULPI support in the Seaboard defconfig.
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This patch adds basic support for the Marvell Armada 7K DB-88F7040
development board. Supported are the following interfaces:
- UART
- SPI (incl. SPI NOR)
- I2C
- USB
- SATA / AHCI
Support for other interfaces will follow.
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Neta Zur Hershkovits <neta@marvell.com>
Cc: Kostya Porotchkin <kostap@marvell.com>
Cc: Omri Itach <omrii@marvell.com>
Cc: Igal Liberman <igall@marvell.com>
Cc: Haim Boot <hayim@marvell.com>
Cc: Hanna Hawa <hannah@marvell.com>
This patch adds basic support for the Marvell Armada 3700 DB-88F3720
- UART
- I2C
- Ethernet
Cc: Wilson Ding <dingwei@marvell.com>
Cc: Victor Gu <xigu@marvell.com>
Cc: Hua Jing <jinghua@marvell.com>
Cc: Terry Zhou <bjzhou@marvell.com>
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
trini: Drop local memset() from
examples/standalone/mem_to_mem_idma2intr.c
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
It should be EMMC_BOOT instead of CONFIG_EMMC_BOOT.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Gong Qianyu <Qianyu.Gong@nxp.com>
Update amcore board to use dm serial driver.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Changes for v2:
- None
Enable the NAND interface on this board.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This board is a plug in card for Marvell's switch system development
kits. Form-factor aside it is similar to the DB-88F6820-GP with the
following differences.
- TCLK is 200MHz
- SPI1 is used
- No SATA
- No MMC
- NAND flash
As I repeated in the ML, I am unhappy with config entries with bare
defaults. Kick them out of arch/arm/mach-uniphier/Kconfig.
Currently, CONFIG_SPL_SERIAL_SUPPORT is not user-configurable
(build fails without it), but it should be fixed later anyway,
so I am moving CONFIG_SPL_SERIAL_SUPPORT to defconfigs.
This patch enable fixed regulator driver for rk3399 evb.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
This patch to enable configs for usb module
- xhci
- ehci
- usb storage
- usb net
Signed-off-by: MengDongyang <daniel.meng@rock-chips.com>
Squashed in patch to move to Kconfig:
https://patchwork.ozlabs.org/patch/672543/
This patch enable rk3399 pinctrl driver and gpio driver which is sub-node
of pinctrl.
Moved FSL_QSPI/SPI/SPI-FLASH configs from include/configs
into respective used defconfigs.
- CONFIG_FSL_QSPI
- CONFIG_SPI_FLASH
- CONFIG_SPI_FLASH_BAR
- CONFIG_SPI_FLASH_STMICRO
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Remove unnecessary board specific config file for DC4
board.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Acked-by: Jagan Teki <jteki@openedev.com>
Move CONFIG_AHCI to defconfig.
Add PL bitstream dowload support for ZynqMP
Bitstream will be validated by uboot and loaded
to PL by invoking an smc instruction to ATF which route this request to
PMU FW which will take care of loading it to PL
Pandaboard is growing again, disable EXT2/3/4 support in SPL save more
space.
This patch introduces support for building U-Boot to run on the MIPS
Boston development board. This is a board built around an FPGA & an
Intel EG20T Platform Controller Hub, used largely as part of the
development of new CPUs and their software support. It is essentially
the successor to the older MIPS Malta board.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
MIPSfpga is an FPGA based dev platform.
In a nutshell, its a microAptiv cpu core with lots of Xilinx IP blocks
The FPGA dev board used is the Nexys4DDR board by Digilent.
For more information, check the Readme file in board/imgtec/xilfpga
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Convert CONFIG_MIP405T from SYS_EXTRA_OPTIONS to a real config
There are two boards, MIP405 and MIP405T that have a few differences.
Start by checking for CONFIG_TARGET_MIP405. Then introduce
CONFIG_TARGET_MIP405T and use that not CONFIG_MIP405T. Next, convert
also convert the usage of CONFIG_ISO_STRING to be based on Kconfig.
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
[trini: Update configs, add some default to sunxi Kconfig]
This reverts commit 90c08d9e08c7a108ab904f3bbdeb558081757892.
I took a closer look at this after the commit was applied, and found
CONFIG_SYS_MALLOC_F_LEN=0x2000 was too much. 8KB memory for SPL is
actually too big for some boards. Perhaps 0x800 is enough, but the
situation varies board by board.
Let's postpone our decision until we come up with a better idea.
Based on A13-OLinuXino, enable DFU and UMS support.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Now all UniPhier SoCs support a pinctrl driver. Select (SPL_)PINCTRL
since it is mandatory even for base use.
Sinlinx SinA33 has a USB OTG port, but VBUS is controlled manually from
a jumper pad.
Enable OTG in gadget mode, as well as the download gadget and related
functions.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Sinlinx SinA33 has 1 USB host port. Enable EHCI_HCD support for it.
Also enable USB mass storage support so we can access USB sticks.
Sinlinx SinA33 uses PB4 for mmc0 card detect.
The NanoPi NEO is a simple h3 board with 512MB RAM, ethernet, one usb
and one usb OTG connector.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Convert CONFIG_SPL_YMODEM_SUPPORT to Kconfig
Move this option to Kconfig and tidy up existing uses.
