QEMU supports NVMe emulation. Enable the NVMe driver on QEMU x86.
CONFIG_OMAP3_SPI
[trini: Minor comment tweaks]
With the new way of doing things (i.e. the hierarchical selection of
SPL_LDSCRIPT via Kconfig) in place, this moves the SPL_LDSCRIPT setting
for the RK3368 from defconfig back into Kconfig.
With this done, there should be no lingering cases of SPL_LDSCRIPT
outside of Kconfig files.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
With the changes to split SPL/TPL for the RK3368, I apparently missed
some needed adjustments to the RK3188 Kconfig and rock_defconfig.
This fixes build-issues for the rock board after applying the RK3368
enablement (and SPL/TPL) set that resulted from TPL_SERIAL_SUPPORT,
TPL_ROCKCHIP_BACK_TO_BROM and TPL_TINY_MEMSET being separate symbols
now.
The default 1kb pre-reloc malloc pool is not enough for dm
core to enable the dm-pre-reloc device drivers.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
There is no reasonably robust way (this will be needed so early that
diagnostics will be limited) to specify the base-address of the secure
timer through the DTS for TPL and SPL. In order to allow us a cleaner
way to structure our SPL and TPL stage, we now move to a DM timer
driver.
To fully support DM timer in SPL and TPL, we need a few things cleaned
up and normalised:
- inclusion of the uclass and drivers should be an all-or-nothing
decision for each stage and under control of $(SPL_TPL_)TIMER
instead of having the two-level configuration with TIMER and
$(SPL_TPL_)TIMER_SUPPORT
- when $(SPL_TPL_)TIMER is enabled, the ARMv8 generic timer code can
not be compiled in
This normalises configuration to $(SPL_TPL_)TIMER and moves the config
options to drivers/timer/Kconfig (and cleans up the collateral damage
to some defconfigs that had SPL_TIMER_SUPPORT enabled).
Splitting the feature selection for SPL and TPL, caused a few build
failures to mpx85xx boards. This fixes the fallout by adding the
needed new option names to the respective defconfig files.
Signed-off-byL Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The RK3368-uQ7 (codenamed 'Lion') is a micro-Qseven (40mm x 70mm,
MXM-230 edge connector compatible with the Qseven specification)
form-factor system-on-module based on the octo-core Rockchip RK3368.
It is designed, supported and manufactured by Theobroma Systems.
It provides the following features:
- 8x Cortex-A53 (in 2 clusters of 4 cores each)
- (on-module) up to 4GB of DDR3 memory
- (on-module) SPI-NOR flash
- (on-module) eMMC
- Gigabit Ethernet (with an on-module KSZ9031 PHY)
- USB
- HDMI
- MIPI-DSI/single-channel LVDS (muxed on the 'LVDS-A' pin-group)
- various 'slow' interfaces (e.g. UART, SPI, I2C, I2S, ...)
The back-to-bootrom option is rather unfortunately named
CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM
instead of
CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM
To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM),
we need to rename it. At the same time, we introduce a TPL_ variant of
the option to give us finer-grained control over when it should be used.
This change is motivated by our RK3368 boot process, which returns to
the boot ROM only from the TPL stage, but not from the SPL stage.
[added fix-up for evb-rk3229_defconfig and phycore-rk3288_defconfig:]
[fixed inverted CONFIG_IS_ENABLED test for rk3288:]
include/configs/rock.h: undef
CONFIG_NAND
[trini: Sync up a few more, add imply's]
This patch brings the OMAP3 EVM to a bootable state, on master, as of
v2017.09-rc1.
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
CONFIG_CMD_TSI148
CONFIG_CMD_THOR_DOWNLOAD
CONFIG_CMD_TCA642X
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_SPL_NAND_OFS
CONFIG_CMD_SPL
Note that trats does not actually use SPL, so this option can no-longer be
set.
CONFIG_CMD_SF_TEST
CONFIG_CMD_SDRAM
CONFIG_CMD_SCSI
Also update the Makefile to use CONFIG_CMD_SCSI instead of CONFIG_SCSI to
enable the command, fixing an earlier error.
[trini: Rework to default y if SCSI, drop cl-som-am57x which did not use
CMD_SCSI for real]
CONFIG_CMD_SAVES
CONFIG_CMD_REISER
This patch converts CONFIG_CMD_REGINFO to Kconfig
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
Convert this option and enable it in sandbox. Also correct a bug which
was introduced with the block-device driver model conversion.
CONFIG_CMD_PCMCIA
CONFIG_CMD_PCI
CONFIG_CMD_PCA953X
CONFIG_CMD_ONENAND
CONFIG_CMD_MTDPARTS_SPREAD
[trini: Make this a bool not a string]
CONFIG_CMD_MMC_SPI
CONFIG_CMD_MAX6957
commit f1896c45cb2f: spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LEN
introduced independent SYS_MALLOC_F_LEN for SPL and U-Boot.
Use it on the smartweb board, as above commit broke
the smartweb board.
CONFIG_SYS_I2C_OMAP24XX
This patch enables driver model for USB in defconfigs for LS1021A
platforms.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This defconfig uses the PCIe x4 binary blobs from the congatec BIOS.
Cc: Bin Meng <bmeng.cn@gmail.com>
- Disable debug UART
- Enable more partition support
- Enable ACPI resume support
- Enable Spansion and Winbond SPI flash support
- Move VGA BIOS binary address to enable bigger U-Boot images
This patch adds the infrastructure to define different config headers
with different configurations and default environment for the baseboards
that can now be selected via Kconfig. The new configuration for the
theadorable-x86-conga-qa3-e3845 is also added. Also the new defconfig
file for this new target is added.
theadorable-x86-dfi-bt700 is also added.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
move to Kconfig:
CONFIG_BCM_SF2_ETH
CONFIG_BCM_SF2_ETH_DEFAULT_PORT
CONFIG_BCM_SF2_ETH_GMAC
Also modified defconfigs of all platforms that use these configs.
Signed-off-by: Suji Velupillai <suji.velupillai@broadcom.com>
Tested-by: Suji Velupillai <suji.velupillai@broadcom.com>
Reviewed-by: JD Zheng <jiandong.zheng@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Signed-off-by: Steve Rae <steve.rae@raedomain.com>
