Now that we have the Kconfig based CPU type selection,
use this to fill the IMX_CONFIG automatically
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
This is the first patch to remove the
CONFIG_SYS_EXTRA_OPTIONS.
This patch implements CPU type selection from Kconfig.
Further Kconfig stuff is added later.
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies)
accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards.
Prior to that commit, those boards defined CONFIG_LIB_RAND, but not
CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have
touched them, but in fact it ripped CONFIG_LIB_RAND off from all the
header files, which caused undefined reference to srand and rand.
CONFIG_LIB_RAND=y must be revived for such boards.
BTW, this commit indeed makes it better, but even with this fix,
three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not
build due to region 'ram' overflowed error. This was cause by
commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs)
because CMD_NET selects NET, and NET selects REGEX. Eventually,
some boards were newly enabled with CONFIG_REGEX, increasing the
memory footprint. A patch is expected to fix the build error.
Move this over to Kconfig and tidy up.
We plan to enable device tree in SPL by default. Before doing this,
explicitly disable it for all boards.
Enable the EC and keyboard, using the SPI bus.
The EC driver requires a particular format and a deactivation delay. Also
U-Boot does not support interrupts.
For now, adjust the device tree to comply. At some point we should tidy
this up to support interrupts and make tegra and exynos use the same setup.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Signed-off-by: Soeren Moch <smoch@web.de>
This patch moves the following config options to Kconfig:
CONFIG_AUTOBOOT_KEYED
CONFIG_AUTOBOOT_PROMPT
CONFIG_AUTOBOOT_DELAY_STR
CONFIG_AUTOBOOT_STOP_STR
AUTOBOOT_KEYED_CTRLC
[trini: Drop ip04 and pm9263 configs/ additions, those boards previously
set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over
all boards that did change. Make digsy_mtc_* string include seconds to
match others and not warn. ]
Most of the drivers available for Vybrid are not yet converted
to OF model to use device tree model, only few drivers
like SPI and GPIO drivers use device trees.
Add separate defconfig for who needs to use device tree model.
Later this can be integrated to single defconfig.
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Select CONFIG_CMD_NET and CONFIG_CMD_SETEXPR by default rather then
needing to have this in every sunxi defconfig file.
This also fixes the Merrii_A80_Optimus defconfig no longer building.
Cc: Maxin B. John <maxin.john@enea.com>
Reported-by: Maxin B. John <maxin.john@enea.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Add and use a proper dts for the ga10h a33 based tablet, as
submitted upstream.
Rename the Astar_MID756 to Et_q8_v1_6 to match the kernel dts name.
Copy over all the latest dts changes from mripard/sunxi/dt-for-4.2 ,
this gives us a proper dtsi file for the A33 rather then abusing
sun8i-a23.dtsi for this.
And this replaces our minimal (dummy) sun7i-a20-mk808c and
sun8i-a33-astar-mid756 dts files with proper ones.
The Mele A1000G-quad and the Mele M9 have the same PCB, sofar we've been
using the same defconfig (and dts on the kernel side) for both models.
Unfortunately this does not work for the otg controller, on the M9 this
is routed to a micro-usb connector on the outside, while as on the
A1000G-quad it is connected to an usb to sata bridge.
This commit adds a new defconfig for the Mele-A1000G-quad to allow using
different otg controller settings on the 2 boards.
Support QEMU PIRQ routing via device tree on both i440fx and q35
platforms. With this commit, Linux booting on QEMU from U-Boot
has working ATA/SATA, USB and ethernet.
Although the two qemu-x86 targets (i440fx and q35) share a lot in
common, they still have something that cannot easily handled in one
single device tree). Split to create two dedicated device tree files
and make the i440fx be the default build target.
Intel Quark SoC has the same interrupt routing mechanism as the
Queensbay platform, only the difference is that PCI devices'
INTA/B/C/D are harcoded and cannot be changed freely.
It turns out that QEMU x86 emulated graphic card has a built-in
option ROM which can be run perfectly with native mode by U-Boot.
CONFIG_FRAMEBUFFER_SET_VESA_MODE and CONFIG_FRAMEBUFFER_VESA_MODE
are not x86-specific, so move them to drivers/video/Kconfig and
make them depend on VIDEO_VESA driver. Some cosmetic fixes are
applied to the Kconfig help text as well.
QEMU is much easier for us test booting U-Boot as a coreboot payload
than having a real board like chromebook_link.
Now that we have QEMU support, make it the default vendor in the
'make menuconfig' screen.
This commit introduces the initial U-Boot support for QEMU x86 targets.
U-Boot can boot from coreboot as a payload, or directly without coreboot.
Merged in patch 'x86: qemu: Add CMD_NET to qemu-x86_defconfig
https://patchwork.ozlabs.org/patch/479745/
Fixup include/configs/unipher.h to not set CONFIG_LIB_RAND
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Commit 76ec988b062e (net: Remove all calls to net_random_ethaddr())
accidentally deleted CONFIG_TARGET_BCT_BRETTL2=y, and since then
bct-brettl2 would not build.
Since commit a26cd04920dc (arch: Make board selection choices
optional), Kconfig actually allows such a .config file in which no
board is selected, but the build never succeeds.
Since commit 92ac52082140 (net: Remove all references to
CONFIG_ETHADDR and friends), the ethernet device on UniPhier boards
is not working because of the incorrect (all-zero) MAC address.
Enable CONFIG_NET_RANDOM_ETHADDR to generate the random one.
One disadvantage of commit a26cd04920dc (arch: Make board selection
choices optional) is that Kconfig could create such an insane
.config file that no board is selected.
As PH1-Pro4 is the main stream of UniPhier SoC family, rip off the
"optional" again in favor of PH1-Pro4 as the default SoC.
add support for imx6dl based aristainetos2 board
U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: WDOG
Board: aristaitenos2
Watchdog enabled
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Display: lg4573 (480x800)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Prior to this commit, ZC702 and ZC706 shared the same configuration
and were built as follows:
ZC702: make zynq_zc70x_defconfig && make
ZC706: make zynq_zc70x_defconfig && make DEVICE_TREE=zynq-zc706
This commit introduces separate configuration for them, which makes
the next commit much easier.
Going forward, the recommended build commands are:
ZC702: make zynq_zc702_defconfig && make
ZC706: make zynq_zc706_defconfig && make
Although the old work flow is still supported, CONFIG_TARGET_ZC70X
has been marked as deprecated. If used, the warning message is
shown to prompt users to switch to the new scheme.
This commit allows users to enable/disable the Freescale NFC
controller found in systems like Vybrid (VF610), MPC5125, MCF54418
or Kinetis K70 via Kconfig with more detailed help docs.
Signed-off-by: Stefan Agner <stefan@agner.ch>
[scottwood: updated vf610twr_nand_defconfig]
Currently we need to build one U-boot image for each of the wandboard
variants: quad, dual-lite and solo.
By switching to SPL we can support all these variants with a single binary,
which is very convenient.
Based on the work from Richard Hu.
Tested kernel booting on the three boards.
Signed-off-by: Richard Hu <hakahu@gmail.com>
Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Enable the new env unit tests on sandbox.
Make all unit tests selectable as a menu of test suites instead of just
sitting in the top-level menu individually.
