path: root/configs
2015-11-25cgtqmx6eval: Add DFU supportOtavio Salvador
Add MMC and SPI DFU support. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-25cgtqmx6eval: Add SPL supportOtavio Salvador
Congatec has several MX6 boards based on quad, dual, dual-lite and solo. Add SPL support so that all the variants can be supported Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-19sandbox: Enable USB keyboardSimon Glass
Enable the USB keyboard on sandbox, now that we have a suitable emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: Enable console recording and silent consoleSimon Glass
Allow console recording so that tests can use it. Also allow the console output to be suppressed, to reduce test output 'noise'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: add a sandbox timer and basic testThomas Chou
Add a sandbox timer which get time from host os and a basic test. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19rockchip: Turn on CONFIG_DEBUG_UART_NS16550 in defconfigsAriel D'Alessandro
No UART driver was specified in defconfig, thus DEBUG_UART_ALTERA_JTAGUART was incorrectly selected by default since commit 220e8021af96741bd7149ca9895e1f0c8a38d0bb added a new Altera UART driver. Signed-off-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-18powerpc/83xx: add support for kmtegr1 boardValentin Longchamp
This board uses the same CPU (8309) as VECT1. The memory however is different since it has NAND Flash, the NOR Flash partitioning is different and of course the FPGAs as well. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com>
2015-11-18powerpc/83xx: add support for kmtepr2 boardChristoph Dietrich
This board is similar to TUXX1, but it has differend FPGAs. Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com> Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18board: ti: beagle_x15: Rename to indicate support for TI am57xx evmsKipisz, Steven
BeagleBoard X15 (http://beagleboard.org/x15) support in u-boot does actually support two different platform configuration offered by TI. In addition to BeagleBoard X15, it also supports the TMDXEVM5728 (or more commonly known as AM5728-evm). Information about the TI AM57xx EVM can be found here http://www.ti.com/tool/tmdxevm5728 The EVM configuration is 1-1 compatible with BeagleBoard X15 with the additional support for mPCIe, mSATA, LCD, touchscreen, Camera, push button and TI's wlink8 offering. Hence, we rename the beagle_x15 directory to am57xx to support TI EVMs that use the AM57xx processor. By doing this we have common code reuse. This sets the stage to have a common u-boot image solution for multiple TI EVMs such as that already done for am335x and am437x. This sets the stage for upcoming multiple TI EVMs that share the same code base. NOTE: Commit eae7ae185335 ("am437x: Add am57xx_evm_defconfig using CONFIG_DM") introduced DT support for beagle_x15 under am57xx_evm platform name. However, this ignored the potential confusion arising for users as a result. To prevent this, existing beagle_x15_defconfig is renamed as am57xx_evm_nodt_defconfig to denote that this is the "non device tree" configuration for the same platform. We still retain am57xx-beagle-x15.dts at this point, since we just require the common minimum dts. As a result of this change, users should expect changes in build procedures('make am57xx_evm_nodt_defconfig' instead of 'make beagle_x15_defconfig'). Hopefully, this would be a one-time change. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Schuyler Patton <spatton@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-11-17Merge git://git.denx.de/u-boot-marvellTom Rini
2015-11-17arm: kirkwood: ib62x0: make use of defconfigLuka Perkov
Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: kirkwood: Move configuration of some commands to _defconfig filesQuentin Armitage
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING and USB commands, and HUSH_PARSER into the _defconfig file, rather than the include/configs/*plug.h files. This avoids compiler warnings of duplicate definitions if the option is selected in the .config, but also defined in the include/configs/*plug.h file. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-18board: axs10x switch serial port and Ethernet to driver modelAlexey Brodkin
With this change Synopsys DesignWare SDP board is switched to driver model for both serial port (serial_dw) and Ethernet (Designware GMAC). This simplifies include/configs/axs101.h and allows for reuse of Linux's Device Tree description. For simplicity Linux's .dts files are not blindly copied but only very few extracts of them are really used (those that are supported in U-Boot at the moment). Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-13Merge branch 'series1_v2' of git://git.denx.de/u-boot-sparcTom Rini
2015-11-13x86: qemu: Convert to use driver model ethBin Meng
Move to driver model for ETH (e1000) on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model usbBin Meng
Move to driver model for USB on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model pciBin Meng
Move to driver model for pci on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13sparc: leon3: Add debug_uart support to LEON3 serial driver.Francois Retief
Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-13sparc: Kconfig: Move the CMD_AMBAPP command to KconfigFrancois Retief
Add an initr function in the board_r.c file for the AMBA Plug&Play command. Add a Kconfig entry for the ambapp command and remove all CONFIG_CMD_AMBAPP defines from the board configuration headers. Add a Kconfig entry to display the AMBA Plug&Play information on startup. This option is off by default. Remove relevent define from board configuration headers. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-13sparc: Update GRSIM board with memory settings for TSIM evalFrancois Retief
Update the GRSIM board with the memory settings for the evaluation version of TSIM. This free version of TSIM is used for testing. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-12hrcon: Add support for the DH variantDirk Eibach
hrcon DH(dual head) has two video outputs per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12mpc83xx: Add strider boardDirk Eibach
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> [trini: Drop setting CONFIG_SYS_GENERIC_BOARD, this is always true now] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12sunxi: cubietruck: Enable the USB OTG controllerMaxime Ripard
The Cubietruck has a mini-USB connector that can be used to power up the board and as an OTG connector. Since we have already some USB host-only ports right beside this one, enable it in gadget mode Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-12sunxi: A13-Olinuxino: Enable the USB OTG controllerMaxime Ripard
The A13-Olinuxino has a mini-USB connector that can be used to power up the board and as an OTG connector. Since we have already some USB host-only ports right beside this one, enable it in gadget mode Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-11-12board/BuR/kwb: use bootvx(...) (with bootline feature) instead go(...)Hannes Petermaier
Since we don't have for sure a valid IP-setup during board_late_init(...) because it maybe allready stored in environment or not, we cannot form a proper vxWorks bootline at this place. So we move to the way, forming the bootline just before executing/launching vxWorks. To do this we use the bootvx command instead go. We only have to form the "othbootargs" environment variable, the rest is done pretty good by the "bootvx" commannd. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-12Merge branch 'next' of git://git.denx.de/u-boot-blackfinTom Rini
2015-11-12nios2: rename board nios2-generic to 3c120_devboardThomas Chou
Rename board nios2-generic to 3c120_devboard. Since nios2 is converted to driver model and device tree control of u-boot, the nios2-generic board directory is removed. We can rename the board back to a real board name. Now the boards maintained in u-boot mainline are the same as Linux kernel, namely 3c120 and 10m50. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2015-11-12nios2: add 10m50 devboard supportThomas Chou
Add 10m50 devboard support. It is based on the Golden Hardware Reference Design (GHRD), available at, http://rocketboards.org/foswiki/view/Documentation/ AlteraMAX1010M50RevCDevelopmentKitLinuxSetup Though we supported only one nios2-generic board in the past. Now, with the removal of the nios2-generic board dir, adding new nios2 boards to u-boot is easier than before. It should be helpful to add those boards supported in Linux mainline. There are only two such nios2 boards, the 3c120 devboard and 10m50 devboard. The nios2-generic is actually 3c120, and should restore the name. The 10m50 is this one. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
2015-11-12nios2: use cfi flash driver modelThomas Chou
Use cfi flash driver model. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-11-06nios2: enable setexpr command in defconfigThomas Chou
Enable setexpr command in defconfig because it is really useful as suggested by Marek. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-11-05Merge git://git.denx.de/u-boot-samsungTom Rini
2015-11-04Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2015-11-04mpc85xx: Add support for the Varisys Cyrus boardAndy Fleming
This board runs a P5020 or P5040 chip, and utilizes an EEPROM with similar formatting to the Freescale P5020DS. Large amounts of this code were developed by Adrian Cox <adrian at humboldt dot co dot uk> Signed-off-by: Andy Fleming <afleming@gmail.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-04ARM: zynq: Remove zc70x targetMichal Simek
Remove zc70x target which was one setting for zc702 and zc706. Currently zc702 and zc706 are separated. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2015-11-04ARM: zynqmp: Enable DM and OF bindingMichal Simek
SPI requires DM and OF that's why enable DM for ZynqMP and start to use configuration based on embedded OF. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-04arm: zynq: Support the debug UARTSimon Glass
Add support for the debug UART to assist with early debugging. Enable it for Zybo as an example. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-04arm: zynq: Use separate device tree instead of embeddedSimon Glass
Production boards should not use CONFIG_OF_EMBED. Fix this for the Zybo boards. The image to use now becomes u-boot-dtb.bin. For example, the .bif file should contain a line like: [load = 0x04000000,startup=0x04000000]/path/to/u-boot-dtb.bin instead of: [load = 0x04000000,startup=0x04000000]/path/to/u-boot.bin When device tree is enabled we need to load u-boot-dtb.img. Change the settings so that SPL does the right thing. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-04blackfin: Disable CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED in some casesTom Rini
The boards do not link for me due to exceeding their size constrains, change the config so they fit again. Cc: Sonic Zhang <sonic.adi@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2015-11-02sandbox: add ADC driverPrzemyslaw Marczak
This commit adds implementation of Sandbox ADC device emulation. The device provides: - single and multi-channel conversion - 4 channels with predefined conversion output data - 16-bit resolution Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-02exynos5-dt-types: add board detection for Odroid XU3/XU3L/XU4.Przemyslaw Marczak
This commit adds additional file with implementation of board detection code for Odroid-XU3/XU4. The detection depends on compatible found in fdt: - "samsung,exynos5" - uses Exynos5 generic code - "samsung,odroidxu3" - try detect XU3 revision There are few revisions of Odroid XU3/XU4, each can be detected by checking the value of channel 9 of built-in ADC: Rev ADC Board 0.1 0 XU3 0.1 0.2 372 XU3 0.2 | XU3L - no DISPLAYPORT 0.3 1280 XU4 0.1 The detection code depends on the ADC+10% value. Implementation of functions: - set_board_type() - read ADC and set type - get_board_rev() - returns board revision: 1..3 - get_board_type() - returns board type string Additional functions with return values of bool: - board_is_generic() - true if found compatible "samsung,exynos5" but not "samsung,odroidxu3" - board_is_odroidxu3() - true if found compatible "samsung,odroidxu3" and one of XU3 revision. - board_is_odroidxu4() - true if found compatible "samsung,odroidxu3" and XU4 revision. After I2C controller init, the get_board_type() can check if the XU3 board is a "Lite" variant, by probing chip 0x40 on I2C0 (INA231 - exists only on non-lite). This is useful for setting fdt file name at misc_init_r(). Enabled configs: - CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - CONFIG_ODROID_REV_AIN - CONFIG_REVISION_TAG - CONFIG_BOARD_TYPES Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-11-02Odroid-XU3: enable s2mps11 PMIC supportPrzemyslaw Marczak
2015-10-30x86: Select the ns16550 debug UART for minnowmax, chromebook_linkSimon Glass
At present the debug UART is not selected which causes a build error. Correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-30Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-10-29Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2015-10-29armv8/ls1043ardb: Add sd boot supportGong Qianyu
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043ardb: Add nand boot supportGong Qianyu
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/ls1043ardb: Add LS1043ARDB board supportMingkai Hu
LS1043ARDB Specification: ------------------------- Memory subsystem: * 2GByte DDR4 SDRAM (32bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card Ethernet: * XFI 10G port * QSGMII with 4x 1G ports * Two RGMII ports PCIe: * PCIe2 (Lanes C) to mini-PCIe slot * PCIe3 (Lanes D) to PCIe slot USB 3.0: two super speed USB 3.0 type A ports UART: supports two UARTs up to 115200 bps for console Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-10-29armv8: ls2085a: Add support of random MAC addressPrabhakar Kushwaha
Add support of setting RANDOM MAC address if env variable not available. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <yorksun@freescale.com>
