Migrate the base and sub-options to Kconfig. Note that we only enable
this in the base sandbox config now.
Cc: Alexey Brodkin <alexey.brodkin@gmail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Is this driver still used anywhere? It's fishy that it's only enabled
in sandbox anymore.
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
Distro default configuration contains also dhcp and pxe setting which
can't working without enabling CONFIG_NET.
EFI is not required that's why it is not enabled.
This converts CONFIG_NAND_MXS to Kconfig.
The motivation for moving MX28 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
The motivation for moving MX23 selection to Kconfig is to be able
selected in U-Boot.
CONFIG_MXC_GPIO
Since CONFIG_PHY_SMSC was already in Kconfig, move this from
header file to defconfig
Since CONFIG_MXC_UART is already in Kconfig, move this from
the header to imx6q_logic_defconfig
Reviewed-by: Stefano Babic <sbabic@denx.de>
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
These are declared in Kconfig, but some #defines have crept in.
CONFIG_FPGA
CONFIG_FPGA_ALTERA
CONFIG_FPGA_CYCLON2
CONFIG_FPGA_SOCFPGA
CONFIG_FPGA_XILINX
CONFIG_FPGA_ZYNQMPPL
fastboot tool is a convenient way to flash the eMMC, so
add support for it.
Examples of usages:
On the mx6sabresd:
=> fastboot 0
On the Linux PC connected via USB:
$ sudo fastboot getvar bootloader-version -i 0x0525
bootloader-version: U-Boot 2018.01-00550-g7517cfe
finished. total time: 0.000s
$ sudo fastboot reboot -i 0x0525
(this causes the mx6sabresd to reboot)
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Select CONFIG_CMD_USB_MASS_STORAGE so that the 'ums' can be used.
Enable UHS and HS200 for mx7dsabresd.
Read Speed improvement:
Kingston SD10VG2/16GB SDHC 3.0 card
22.2MB/s -> 73.7MB/s
eMMC5.0 MTFC8GACAEAM:
68MB/s -> 87MB/s
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
The initial implementation of mx6memcal reset the CPU after
running the memory calibration procedure because the generic
board has no information about which boot devices are available.
Now that we have SDP support in SPL, use it to allow a full
U-Boot to be uploaded (i.e. to use "mtest").
Signed-off-by: Eric Nelson <eric@nelint.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
This patch just changes the order of configuration items in
mx6memcal_defconfig to match the Kconfig layout, making it easier
to track changes made using menuconfig.
Validate the time at startup:
- in case rtc error add to kernel command line RTC_ERROR
- clamp date to 1-Jan-2036
Signed-off-by: Nandor Han <nandor.han@ge.com>
Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Modify configuration to support FIT. Set variable `confidx' from VPD,
in order to load the correct device tree. Modify/simplify U-Boot
environment to support loading FIT image.
Signed-off-by: Ian Ray <ian.ray@ge.com>
Modify b450v3, b650v3 and b850v3 defconfigs to enable the network devices
found in these products.
Enable nand on mmc defconfig, so-that preparing nand
for writing/updating bootimage, Linux becomes easy.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
i.CoreM6 1.5 is an another i.CoreM6 QDL cpu modules which can be connected
to EDIMM starter kit design with eMMC and MIPI-CSI interfaces suitable for
Android and video capture application.
notable features:
CPU NXP i.MX6 S/DL/D/Q, Up to 4 x Cortex-A9@800MHz
Memory Up to 2 GB DDR3-1066
Video Interfaces Up to 1 Parallel Up to 2 LVDS HDMI 1.4
port 8 bit CSI INPUT MIPI-CSI INPUT
1 x 10/100 Ethernet interface, 2 x USB, 1 x PCIe, 1 x I2S etc
This patch adds support for Quad/Dual and DualLite/Solo SOM's on
MIPI starter kit with boot from SD and eMMC.
When functions return an error it propagates up the stack to the point
where it is reported. Often the error code provides enough information
about the root cause of the error that this is obvious what went wrong.
However in some cases the error may be hard to trace. For example if a
driver uses several devices to perform an operation, it may not be
obvious which one failed.
Add a log_ret() macro to help with this. This can be used to wrap any
error-return value. The logging system will then output a log record when
the original error is generated, making it easy to trace the call stack
of the error.
This macro can significantly impact code size, so its use is controlled
by a Kconfig option, which is enabled for sandbox.
After moving some USB gadget configs (USB_FUNCTIONS_*) to Kconfig it
turned out that following *_defconfig entries for RockChip are not
needed.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
This commit moves USB_FUNCTION_THOR config to Kconfig.
Acked-by: Michal Simek <michal.simek@xilinx.com>
Xilinx changes for v2018.03
- Several Kconfig fixes (also moving configs to defconfigs)
- Some DTS updates
- ZynqMP psu rework based on Zynq concept
- Add low level initialization for zc770 and zcu102
- Add support for Zynq zc770 x16 nand configuration
- Add mini nand/emmc ZynqMP targets
- Some arasan nand changes
CONFIG_SYS_OMAP24_I2C_SLAVE
CONFIG_SYS_OMAP24_I2C_SPEED
Reviewed-by: Paul Kocialkowski <contact@paulk.fr>
CONFIG_SYS_DV_CLKMODE
CONFIG_SYS_DA850_PLL0_POSTDIV
CONFIG_SYS_DA850_PLL0_PLLDIV1
CONFIG_SYS_DA850_PLL0_PLLDIV2
CONFIG_SYS_DA850_PLL0_PLLDIV3
CONFIG_SYS_DA850_PLL0_PLLDIV4
CONFIG_SYS_DA850_PLL0_PLLDIV5
CONFIG_SYS_DA850_PLL0_PLLDIV6
CONFIG_SYS_DA850_PLL0_PLLDIV7
CONFIG_SYS_DA850_PLL1_POSTDIV
CONFIG_SYS_DA850_PLL1_PLLDIV1
CONFIG_SYS_DA850_PLL1_PLLDIV2
CONFIG_SYS_DA850_PLL1_PLLDIV3
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
This patch moved ethernet PHY configs of ZynqMP boards
to respective defconfig.
Signed-off-by: Vipul Kumar <vipulk@xilinx.com>
This patch moved ethernet PHY configs of Microblaze board to
This patch moved ethernet PHY configs of Zynq boards
This patch adds new target which is called as mini configuration
with only emmc functionality and other required basic features enabled.
This will be used to run in system with small footprint and needs
emmc support.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
with only nand functionality and other required basic features enabled.
nand support.
BOOTCOMMAND is composed with distro_bootcmd but this variable is not
present. Enabling distro defaults setting is fixing it.
It will cleanup generic config and enable option to change it for every
board.
There are two reasons for doing this change.
There is still !DM driver for xilinx soft gpio IP and especially it is
saving some space for memory constrained boards like cse (almost ~400B).
There is no reason to enable BLK by default for all boards which is just
increasing memory footprint for memory contrained boards like cse.
zc770s are also saving some space.
Ethernet cable is not connected for xm011 that's why disable all
ethernet related configurations.
Wire debug console which is useful for early debugging.
It is good to see this string to make sure that u-boot which runs on the
board is the same which should run there.
These are defined, but not referenced at all.
zc770-xm011 is x8 width configuration. This FMC card has also x16
variant which requires different ps7_init configuration. This patch adds
it.
This patch adds support for the PDU001 board.
Signed-off-by: Felix Brack <fb@ltec.ch>
The bcm283x family of SoCs have a GPIO controller that also acts as
pinctrl controller.
This patch introduces a new pinctrl driver that can actually properly mux
devices into their device tree defined pin states and is now the primary
owner of the gpio device. The previous GPIO driver gets moved into a
subdevice of the pinctrl driver, bound to the same OF node.
That way whenever a device asks for pinctrl support, it gets it
automatically from the pinctrl driver and GPIO support is still available
in the normal command line phase.
Add gmac config support for rk3229 evb.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
