CONFIG_SCSI
This port adds support for:
1) Serial
2) eMMC
3) USB
It has been tested with ARM TRUSTED FIRMWARE running u-boot as the
BL33 executable [see board's README]
eMMC has been tested for reading and booting the loader and linux
kernels as well as saving the u-boot environment.
USB has been tested with ASIX networking adapter and SanDisk 7.4GB
drive.
PSCI has been tested via the reset call (PSCI executes from DDR)
The firwmare upgrade process has been tested via TFTP and USB FAT
filesystem containing the fastboot.bin image in one of the partitions.
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
Include K2G ICE to OF_LIST so it can be used for runtime board
detection.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Enable various config options to allow U-boot at runtime to select the
proper dtb to use from the list of dtb's within the FIT image.
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000
and CMPC885 which are respectively based on MPC866 and MPC885 processors.
This patch adds support for the first board.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
On startup the SL50 board halt at U-Boot prompt. Use CONFIG_AUTOBOOT_KEYED
to enable autoboot for this board and define the <SPACE> key to get the
U-Boot prompt.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
AVR32 is gone. It's already more than two years for no support in Buildroot,
even longer there is no support in GCC (last version is heavily patched 4.2.4).
Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully).
There is no good point to keep this support in U-Boot either.
The Odroid C2 comes with several expansion options such as an RTC module.
As these expansions are not considered in the Linux device tree they have
to be enabled via device tree overlays.
CHIP and CHIP Pro devices have options of DIP addon boards some of which need
overlays from the beginning so it makes sense to enable device tree overlays.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
96boards CE devices such as the DragonBoard and Hikey devices have numerous
mezzanine options some of which need overlays from the beginning so it makes
TI am33xx devices such as the BeagleBone devices have numerous cape options such
as screens some of which need overlays from the beginning so it makes sense to
enable evice tree overlays.
Raspberry Pi has numerous HAT and other HW expansion options such as screens and
cameras some of which need overlays from the beginning so it makes sense to
Implement spl_start_uboot to let Falcon mode work.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Acked-by: Heiko Schocher <hs@denx.de>
Fastmap significantly reduces flash scan time, enable it by default.
There was for long time no activity in the 4xx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in 4xx,
so remove it.
Use random ethaddr by default in case no ethaddr is set.
Enable DFU and USB mass storage support for the DENX MA5D4 SoM.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
ARC HS Development Kit board is a new low-cost
development platform sporting ARC HS38 in real silicon
with nice set of features such as:
* Quad-core ARC HS38 with 512 kB L2 cache and running @1GHz
* 4Gb of DDR (we use only lowest 1Gb out of it now)
* Lots of DesigWare peripherals
* Different connectivity modules:
- Synopsys HAPS HT3
- Arduino-compatible connector
- MikroBUS
This initial commit supports the following peripherals:
* UART (DW 8250)
* Ethernet (DW GMAC)
* SD/MMC (DW Mobile Storage)
* USB 1.1 & 2.0
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
With eb5ba3aefdf0 "i2c: Drop use of CONFIG_I2C_HARD" in place we
cannot use I2C EEPROM any longer so we're dropping all references to
both EEPROM and I2C which was only used for EEPROM.
Those could be easily used on USB flash drives or on SD/MMC cards.
There's no reason to keep data cache disabled in axs101
board any longer, enabling it.
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support"
taurus board comes not up anymore. Fix it.
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
smartweb board comes not up anymore. Fix it.
The CONFIG_DEFAULT_FDT_FILE expects just the file not a full path
as that might vary depending on the variant of Linux distro you
might be using.
Cc: Martin Donnelly <martin.donnelly@ge.com>
Cc: Fabio Estevam <festevam@gmail.com>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
The ti816x SoC revision of the ethernet IP block is handled by the
"davinci_emac" driver, rather than the "cpsw" driver as done by later
members of the family. Enable the relevant plumbing.
Signed-off-by: Sriramakrishnan <srk@ti.com>
Signed-off-by: Vitaly Wool <vitaly.wool@konsulko.com>
include/configs/imx6qdl_icore_rqs.h
include/configs/imx6ul_geam.h
include/configs/imx6ul_isiot.h
corvus board comes not up anymore. Fix it.
Xilinx changes for v2017.07
ZynqMP:
- config cleanup
- SD LS mode support
- psu_init* cleanup
- unmap OCM
- Support for SMC
Zynq:
- add ddrc to Kconfig
- add topic-miamilite board support
The commit "fb82fe385173 configs: Resync defconfigs" resynced all config
files. This exposed two latent issues with the Gen3 boards in that we
had not been setting CONFIG_DEFAULT_FDT_FILE correctly and had not been
setting CONFIG_CMD_MMC. Fix both of these.
Fixes: fb82fe385173 ("configs: Resync defconfigs")
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
The topic-miamilite SoM contains a Zynq xc7z010 SoC, 1GB DDR3L RAM,
64MB dual-parallel QSPI NOR flash and clock sources.
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Move the only use of CONFIG_SF_DUAL_FLASH to defconfig. This makes the
associated topic_miamiplus.h header obsolete, so remove that as well.
Remove the CONFIG_DM_I2C_COMPAT config.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
There was for long time no activity in the mpx5xxx area.
turned out, nobody is interested anymore in mpc5xxx,
so remove it.
Adds CONFIG_SPL_USB_GADGET_SUPPORT and CONFIG_SPL_USBETH_SUPPORT.
Removes CONFIG_SPL_NAND_SUPPORT, CONFIG_SPL_MTD_SUPPORT, and CONFIG_SPL_YMODEM_SUPPORT
to free up space to fit in RAM.
Signed-off-by: Michael Welling <mwelling@ieee.org>
NanoPi NEO2 is designed and developed by FriendlyElec
using the Allwinner 64-bit H5 SOC.
NanoPi Neo2 key features
- Allwinner H5, Quad-core 64-bit Cortex-A53
- 512MB DDR3 RAM
- microSD slot
- 10/100/1000M Ethernet
- Serial Debug Port
- 5V 2A DC MicroUSB power-supply
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com>
Orangepi Win/WinPlus is an open-source single-board computer
using the Allwinner A64 SOC.
A64 Orangepi Win/WinPlus has
- A64 Quad-core Cortex-A53 64bit
- 1GB(Win)/2GB(Win Plus) DDR3 SDRAM
- Debug TTL UART
- Four USB 2.0
- HDMI
- LCD
- Audio and MIC
- Wifi + BT
- IR receiver
- 5V DC power supply
Orangepi Zero Plus 2 is an open-source single-board computer
using the Allwinner h5 SOC.
H5 Orangepi Zero Plus 2 has
- Quad-core Cortex-A53
- 512MB DDR3
- micrSD slot and 8GB eMMC
- Debug TTL UART
- HDMI
- Wifi + BT
- OTG+power supply
Whistler is an ancient Tegra 2 reference board. I may have been the only
person who ever used it with upstream software, and I've just recycled
the board hardware. Hence, it makes sense to remove support from software.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Enable DHCP command by default. Update maintainer info.
Signed-off-by: York Sun <york.sun@nxp.com>
Enable DHCP command by default. Move environmental variable location
to before U-Boot image. Enlarge reserved mem for malloc. Update
maintainer.
Enable DHCP command to make TFTP easier.
Enable DDR interactive debug by default.
