Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_ARCH_MISC_INIT
CONFIG_BOARD_EARLY_INIT_F
CONFIG_ARCH_EARLY_INIT_R
This patch enables the MMC support for the SDHCI controller on the
Armada 7k db-88f7040 and the Armada 8k db-88f8040 board.
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Kostya Porotchkin <kostap@marvell.com>
Cc: Wilson Ding <dingwei@marvell.com>
Cc: Victor Gu <xigu@marvell.com>
Cc: Hua Jing <jinghua@marvell.com>
Cc: Terry Zhou <bjzhou@marvell.com>
Cc: Hanna Hawa <hannah@marvell.com>
Cc: Haim Boot <hayim@marvell.com>
Armada 3700 db-88f3720 board.
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Rename CONFIG_IMX31_PHYCORE_EET to CONFIG_TARGET_IMX31_PHYCORE_EET and
make this a distinct config target.
This defconfig does not support SPL. If you use this, the basic
SoC initialization must be done in firmware that runs before U-Boot.
(Generally, ARM Trusted Firmware is expected to do this job).
We may want to run different firmware before running U-Boot. For
example, ARM Trusted Firmware runs before U-Boot, making U-Boot
a non-secure world boot loader. In this case, the SoC might be
initialized there, which enables us to skip SPL entirely.
This commit removes "select SPL" to make it configurable. This
also enables the Multi SoC support for the UniPhier ARMv8 SoCs.
(CONFIG_ARCH_UNIPHIER_V8_MULTI) Thanks to the driver model and
Device Tree, the U-Boot proper part is now written in a generic way.
The board/SoC parameters reside in DT. The Multi SoC support
increases the memory footprint a bit, but the U-Boot proper does
not have strict memory constraint. This will mitigate the per-SoC
(sometimes per-board) defconfig burden.
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
Signed-off-by: Jagan Teki <jagan@openedev.com>
When falcon mode support was added, it was right around when SPL_OS_BOOT
was migrated to Kconfig. So first we must move the enablement to the
defconfig file. Next, it turned off EXT support rather than add the
information to allow for falcon mode from EXT. Add this information so
that the board compiles after 5d28b930f237.
Fixes: d96796ca23b2 ("mx6sabresd: Add Falcon mode support")
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Use the generic "distro" boot framework to enable automatic DHCP boot.
MMC and USB are not yet implemented, so this is the only boot option.
The fdt and kernel addresses are adopted from downstream; ramdisk and
scriptaddr addresses were chosen arbitrarily.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Reviewed-by: Alexander Graf <agraf@suse.de>
We have long had available optimized versions of the memset and memcpy
functions that are borrowed from the Linux kernel. We should use these
in normal conditions as the speed wins in many workflows outweigh the
relatively minor size increase. However, we have a number of places
where we're simply too close to size limits in SPL and must be able to
make the size vs performance trade-off in those cases.
Cc: Philippe Reynes <tremyfr@yahoo.fr>
Cc: Eric Jarrige <eric.jarrige@armadeus.org>
Cc: Magnus Lilja <lilja.magnus@gmail.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Chander Kashyap <k.chander@samsung.com>
Cc: Akshay Saraswat <akshay.s@samsung.com>
Cc: Stefan Roese <sr@denx.de>
Enable PPA for ls1043ardb NOR boot and ls1046ardb QSPI boot.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Without a prompt in Kconfig, SECURE_BOOT cannot be selected by
defconfig. The option was dropped unintentionally when defconfig
files were cleaned up. Three targets were impacted
ls1043ardb_SECURE_BOOT, ls2080ardb_SECURE_BOOT,
ls2080aqds_SECURE_BOOT.
Signed-off-by: York Sun <york.sun@nxp.com>
Enable driver model for eSDHC on ls1012a rdb and qds boards.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Enables driver model flag CONFIG_DM_USB for LS1012A platform
in defconfigs.
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
The patch enables PCIe in ls2080a defconfigs and
removes unused PCIe related macro defines.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
The patch enables PCIe and E1000 in ls1046a related defconfigs.
The patch enables PCIe and E1000 in ls1043a defconfigs and
The patch enables PCIe and E1000 in ls1012a defconfigs and
The patch enables PCIe in ls1021a defconfigs and
Enable DT to support Driver Model.
Commit bb5930d5c97f ("exynos: video: Convert several boards to driver
model for video") converted the Exynos Chromebooks machines to use DM
for video, but this breaks backward compatibility with the stdout env
var since now stdout is expected to be "vidconsole" instead of "lcd".
This causes display to not work when updating u-boot on these boards
if the old stdout env var is used. Since these are consumer devices,
there's no easy way to have a serial console so users may be confused
thinking that u-boot failed to boot, or in the best case will need to
update the stdout env var blindly to make the display to work again.
There's a CONFIG_VIDCONSOLE_AS_LCD config option to workaround this,
so enable it in the Chromebooks' default configuration files to allow
users to change their stdout env var before the workaround is removed.
Suggested-by: Simon Glass <sjg@chromium.org>
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Once upon a time u-boot didn't support building with two usb host
controller types, these days it does. Enable XHCI in addition to the
existing EHCI support so user can plug usb devices in all available
ports regardless of the controller type.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Enable the CONFIG_DM_PMIC and CONFIG_DM_PMIC_MAX8998.
s5pc210_universal board is using max8998 pmic.
To use the i2c/pmic driver model, enable these configurations.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
- Enable eMMC driver for LD11/LD20 SoCs
- Refactoring of SoC init code
- Bug fix of pinctrl driver
Add usb support for mx6sllevk board.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Move symbol to Kconfig to cleanup configuration file.
Enable SDMA (Single Operation DMA) for LD11, but not for LD20.
The SDMA does not work for LD20 boards because they are generally
equipped with more memory than fits in the 32 bit physical address
space supported by the SDMA.
Newer OrangePi Zero boards all come with 16 Mib SPI flash soldered, from
which the board can actually boot from.
Enable the SPL support for the SPI controller and SPI flash to allow
putting the SPL, the DT and U-Boot proper into there. This will let
a board boot without an SD card inserted.
The flash chip can be written with a version of the sunxi-fel tool.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Tested-by: Priit Laes <plaes@plaes.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
Orange Pi Zero is a board designed by Xunlong. It has an Allwinner H2+
SoC (similar to H3, which shares the same SoC ID), 256MB/512MB RAM,
Allwinner XR819 SDIO Wi-Fi, a MicroUSB port which is used to power the
board (also capable of OTG), a USB Type-A socket and a MicroSD slot.
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
SPL partition size depends on sector size and we want kernel to use
the same layout, so let U-Boot modify FDT accordingly.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Enable SPL MMC support in order to allow to build a single u-boot image
that is able to boot from MMC and NAND devices.
Signed-off-by: Fabien Parent <fparent@baylibre.com>
The MACH_TYPE for IGEP0032 was never officially used and has been
removed from upstream, so we must not use it. In order to remove this
we need to rework the status LED logic.
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
This commit enables ethernet MAC address randomization on the rock2. It
removes the error at startup 'ethernet@ff290000 address not set'.
Signed-off-by: Romain Perier <romain.perier@collabora.com>
This is the only RK3399 device without DHCP. Enable it so that we
can use a common BOOT_TARGET_DEVICES setting. It is likely useful to be
able to use USB networking, at least. Full networking can be enabled when
a suitable platform needs it.
Enable the various configuration option required to get the ethernet
interface up and running on Radxa Rock2 and Firefly.
RK3288 using the dwc2 USB host controller, enable it and other usb host
funtion like storage and ether.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Added rockchip: tag:
Xilinx changes for v2017.03
- ATF handoff
- DT syncups
- gem: Use wait_for_bit(), add simple clk support
- Simple clk driver for ZynqMP
- Other small changes
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
This commit was created as follows:
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
CONFIG_EXYNOS_DWMMC (renamed to CONFIG_MMC_DW_EXYNOS)
CONFIG_HIKEY_DWMMC (renamed to CONFIG_MMC_DW_K3)
CONFIG_SOCFPGA_DWMMC (renamed to CONFIG_MMC_DW_SOCFPGA)
The "HIKEY" is a board name, so it is not suitable for the MMC
controller name. I am following the name used in Linux.
This commit was generated as follows:
[1] Rename the config options with the following command:
s/CONFIG_EXYNOS_DWMMC/CONFIG_MMC_DW_EXYNOS/g
s/CONFIG_HIKEY_DWMMC/CONFIG_MMC_DW_K3/g
s/CONFIG_SOCFPGA_DWMMC/CONFIG_MMC_DW_SOCFPGA/g
[3] Create the entries in drivers/mmc/Kconfig
(with default y for EXYNOS and SOCFPGA)
[4] Run the following:
tools/moveconfig.py -y -r HEAD MMC_DW_EXYNOS MMC_DW_K3 MMC_DW_SOCFPGA
[6] Clean-up doc/README.socfpga by hand
[1] Rename the option with the following command:
-type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g'
[2] create the entry for MMC_DW in drivers/mmc/Kconfig
(the prompt and help were copied from Linux)
[3] run "tools/moveconfig.py -y MMC_DW"
[4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry
[5] Clean-up doc/README.socfpga by hand
I am trying to make all DesignWare-based driver options prefixed
with CONFIG_MMC_DW_.
find . -name .git -prune -o -type f -print | \
xargs sed -i -e 's/ROCKCHIP_DWMMC/MMC_DW_ROCKCHIP/g'
