The EFI loader is for most use cases not necessary so disable it
by default.
(cherry picked from commit df9aa4068201394a9b2d7c30fbf34a815467c2d2)
Enable default boot command.
FIT image support is used by the upcoming Toradex Easy Installer
and also can be useful for more advanced boot scenarios.
Enable the display driver on Apalis T30. Unfortunately the PWM pin
muxing wasn't any good neither which made that display stay dark.
(cherry picked from commit 2da21c1d130fa11a5bd9876c8e72fa0d57585106)
On popular request enable the display driver on Colibri T30. A few
notes about some things encountered during porting: While analogue VGA
(e.g. via the on-carrier RAMDAC) worked just fine from the beginning
the EDT display flickered like crazy which turned out to be a pin
muxing issue. Unfortunately the PWM pin muxing wasn't any good neither
which made that display stay dark. Enjoy.
(cherry picked from commit 201cc6d4e4c8213fbd103e74b0f2f2ca591edf54)
Migrate Colibri T20 to U-Boot 2016.11.
(cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
Device tree overlays might prove useful in the future, enable it
by default on all our modules.
Migrate Apalis/Colibri T30 to U-Boot 2016.11.
(cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
Use default CONFIG_OF_SEPARATE configuration which appends the device
tree at the end of the U-Boot binary.
by default.
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
The CAAM driver of the downstream i.MX 7 Linux kernel seems not to
work well when booting in non-secure:
caam 30900000.caam: Entropy delay = 3200
caam 30900000.caam: failed to acquire DECO 0
caam 30900000.caam: Entropy delay = 3600
caam: probe of 30900000.caam failed with error -11
Unable to handle kernel NULL pointer dereference at virtual address 00000004
Default booting in secure mode. If non-secure is preferred (e.g.
required for virtualization on a mainline kernel) one can use
setenv bootm_boot_mode nonsec
Introduce USB Gadget config option. This allows to combine Makefile
entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Ravi Babu <ravibabu@ti.com>
(cherry picked from commit e94793c844a40606252f2e3f6428063e057b3fd2)
All modules use the common g_dnl_bind_fixup implementaton which
calculates the PID according to product id (read from the config
block) plus offset of 0x4000. In case there is no config block
support (e.g. SPL) or in case the config block is not readable,
fall back to a generic product id (product id 0, which can be
interpreted as "Unknown Module").
Actually make use of that shiny new CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK.
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
This adds board support for the Toradex module family Colibri iMX6.
The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both
with a version for commercial and industrial temperature range.
(cherry picked from commit a02d517b0182f83771565eba1329fb323674ec58)
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
(cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
Add serial platform data to board file.
Enable driver model for PXA serial driver.
(cherry picked from commit 136179bec19f4bc84227cba138214ea392a723ea)
With em humble DM and Kconfig migraters U-Boot binary size keeps
increasing. Drop a bunch of less needed stuff to save another precious
20+ KB.
(cherry picked from commit fc127d184aea293ec415dd66e3282dba0b66c5f3)
Migrate the PXA serial driver to be configured via Kconfig.
(cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
Deactivate CONFIG_DISPLAY_BOARDINFO in favour of
CONFIG_DISPLAY_BOARDINFO_LATE which also displays on the LCD.
(cherry picked from commit b05d6806cd6a95d46c22036a684a09501fdb2264)
Defconfigs should remain the same except CONFIG_SYS_EXTRA_OPTIONS.
Drop NAND specific defconfig as flash type is runtime detected.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Reviewed-by: Javier Martinez Canillas <javier@samsung.com>
As a single U-Boot binary can now run on various board modifications,
drop CONFIG_DISPLAY_BOARDINFO as it prints flash memory information
too early to give us chance to easily detect it. Also saves few bytes
as a bonus.
Tested-by: Javier Martinez Canillas <javier@samsung.com>
Enable the Ethernet device in DT, provide board-specific configuration,
and enable the driver in Kconfig.
Enable ROCKCHIP_SPL_BACK_TO_BROM and disable CONFIG_SPL_MMC_SUPPORT
to save memory in order to enable add source code for dram capacity
auto-detect.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
The Cubieboard4 is an A80 SoC based development board from Cubietech.
This board has a UART port, 4 USB host ports, a USB 3.0 OTG connector,
HDMI and VGA outputs, a micro SD slot, 8G eMMC flash, 2G DRAM, a WiFi/BT
combo chip, headphone and microphone jacks, IR receiver, and GPIO headers.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
The A80 Optimus Board was launched with the Allwinner A80 SoC.
It was jointly developed by Allwinner and Merrii.
This board has a UART port, a JTAG connector, 2 USB host ports, a USB
3.0 OTG connector, an HDMI output, a micro SD slot, 16G eMMC flash,
2G DRAM, a camera sensor interface, a WiFi/BT combo chip, a headphone
jack, IR receiver, and additional GPIO headers.
[hdegoede@redhat.com: update existing Merrii_A80_Optimus_defconfig
instead of adding a new defconfig]
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support
for the the HCI0 USB host controller on the A64.
Fix up some minor 64-bit hiccups on the way.
Add the bare minimum DT bits to the A64 .dtsi and enable the controllers
and the PHY on the Pine64.
This is limited to the first USB controller at the moment, which is
connected to the lower USB socket on the Pine64 board.
[Andre: remove unneeded defines, enable OHCI, add commit message]
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Originally dram clock was set to 480MHz, but this behaves
unstable. To improve stability the clock is reduced to 384MHz
Signed-off-by: Stefan Mavrodiev <stefan.mavrodiev@gmail.com>
This was turned off by accident, re-enble.
Enable an early debug UART to debug problems when an ICE or other
debug mechanism is not available.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Move the config options from the include/configs/sama5d2_xplained.h
to configs/sama5d2_xplained_*_defconfig.
common/Kconfig
configs/dms-ba16_defconfig
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
Add NAND support for Engicam i.CoreM6 qdl board.
Boot Log:
U-Boot SPL 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43)
Trying to boot from NAND
NAND : 512 MiB
U-Boot 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43 +0530)
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 55C
Reset cause: WDOG
Model: Engicam i.CoreM6 DualLite/Solo Starter Kit
DRAM: 256 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
icorem6qdl>
Cc: Scott Wood <oss@buserror.net>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Enable imx6 pinctrl driver support for i.CoreM6.
i.CoreM6 DualLite/Solo modules are system on module solutions
manufactured by Engicam with following characteristics:
CPU NXP i.MX6 DL, 800MHz
RAM 1GB, 32, 64 bit, DDR3-800/1066
NAND SLC,512MB
Power supply Single 5V
MAX LCD RES FULLHD
and more info at
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
Add enet support for engicam icorem6 qdl starter kit.
- Add pinmux settings
- Add board_eth_init
TFTP log:
Net: FEC [PRIME]
icorem6qdl> tftpboot {fdt_addr} imx6dl-icore.dtb
Using FEC device
TFTP from server 192.168.2.96; our IP address is 192.168.2.75
Filename 'imx6dl-icore.dtb'.
Load address: 0x0
Loading: ######
1.3 MiB/s
done
Bytes transferred = 28976 (7130 hex)
CACHE: Misaligned operation at range [00000000, 00007130]
icorem6qdl>
Boot Log for i.CoreM6 DualLite/Solo Starter Kit:
U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46)
Trying to boot from MMC1
U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530)
CPU: Industrial temperature grade (-40C to 105C) at 31C
Reset cause: POR
DRAM: 256 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
switch to partitions #0, OK
mmc0 is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6741808 bytes read in 341 ms (18.9 MiB/s)
Booting from mmc ...
reading imx6dl-icore.dtb
30600 bytes read in 19 ms (1.5 MiB/s)
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800a787
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
Boot Log for i.CoreM6 Quad/Dual Starter Kit:
CPU: Freescale i.MX6Q rev1.2 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 28C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
No ethernet found.
icorem6qdl>
Acked-by: Peng Fan <peng.fan@nxp.com>
- Add DEFAULT_FDT_FILE kconfig entry
- Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs
Add defconfig file to use plugin code.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_USB_KEYBOARD
[trini: Fixup MPC86* configs]
