The bounce buffer is used by a few drivers (most of the MMC drivers)
to overcome limitations in their respective DMA implementation.
This moves the configuration to Kconfig and makes it user-selectable
(even though it will be a required feature to make those drivers
work): the expected usage is for drivers depending on this to 'select'
it unconditionally from their respective Kconfig (see follow-up
patches).
This commit includes a full migration using moveconfig.py to ensure
that each commit compiles. To ensure bisectability we update
dependencies of various drivers to now select BOUNCE_BUFFER when needed.
[trini: Squash all patches to ensure bisectability]
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion]
Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion]
Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
Add TFA boot flow for more boards
Add TFA boot defconfig for ls1088a and ls2088a.
Add dts fixup for PCIe endpoint and root complex.
The am335x_evm_defconfig supports all am335x_boneblack variants. Remove
the redundant am335x_boneblack_defconfig.
Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
On this board SPI is only used to configure the SoC driving the LC TFT
display which is not used in U-Boot. Hence remove SPI support.
Signed-off-by: Felix Brack <fb@ltec.ch>
am43xx_evm_ethboot_defconfig is not being actively used and has not been
moved to DM or DT. Also, ethboot cannot be tested on AM43xx EVM as such
due EVM limitations. Therefore delete it.
Signed-off-by: Vignesh R <vigneshr@ti.com>
These defconfigs don't seem be actively used any more, and have not been
moved to adapt DM or DT. Therefore delete them.
Enable DM_SPI and DM_SPI_FLASH for actively used defconfigs for
am335x_evm.
bananapi r2 can be booted from sd-card and emmc
saving the environment have to choose the storage
from which the device has booted
also the offset is set to 1MB to make sure env is written
to block "user data area" between uboot and first partition
https://www.fw-web.de/dokuwiki/lib/exe/fetch.php?cache=&media=bpi-r2:boot-structure.png
Signed-off-by: Frank Wunderlich <frank-w@public-files.de>
- MIPS: mscc: various enhancements for Luton and Ocelot platforms
- MIPS: mscc: added support for Jaguar2 platform
- MIPS: optimised SPL linker script
- MIPS: bcm6368: fix restart flow issues
- MIPS: fixed CONFIG_OF_EMBED warnings for all MIPS boards
- MIPS: mt7688: small fixes and enhancements
- mmc: compile-out write support if disabled
update TFABOOT defconfig for SD boot on below NXP chasis2
and chasis3 platforms:
ls1043a, ls1046a, ls1088a and ls2088a.
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
TFABOOT support includes:
- ls2088aqds_tfa_defconfig to be loaded by trusted firmware
- environment address and size changes for TFABOOT
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com>
- ls2088ardb_tfa_defconfig to be loaded by trusted firmware
- define BOOTCOMMAND for TFABOOT
- remove EL3 specific erratas for TFABOOT
- ls1088aqds_tfa_defconfig to be loaded by trusted firmware
- MC address changes for TFABOOT
- ifc chip select changes for TFABOOT
- ls1088ardb_tfa_defconfig to be loaded by trusted firmware
With the new SPI NOR framework in v4.19, we need to adapt the MTD parts
so that the kernel cmdline parameter "mtdparts=" uses the correct naming
for the devices.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Fix the Kconfig warning to not use CONFIG_OF_EMBED in defconfigs.
Based on https://patchwork.ozlabs.org/patch/1019791/
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Add board support and configuration for Jaguar2 SOC family.
The detection of the board type in this family is based on the phy ids.
Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Thes patch change the luton base device tree to use the newly added
SPI bitbang driver.
It also updates the "mscc_luton_defconfig" to use the new driver.
Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
There is no real difference between the generic variant and
the custom variant except that the generic variant is more
optimised. This also saves 24 Bytes in the SPL binary.
Tested-by: Ezequiel Garcia <ezequiel@collabora.com>
This enables the use of the MSCC serial GPIO driver to control the
LEDs on the MSCC VCoreIII 'ocelot' pcb123 and pcb120.
LEDs on the MSCC VCoreIII 'luton' SoC.
As we are moving to multi-dtb and board detection, remove static board
config options, and introduce board probing instead.
Luton: This add single-binary support for the two MSCC luton-based
reference boards - pcb090 and pcb091. The SoC chip ID is used to
determine the board type.
Ocelot: This add single-binary support for the two MSCC ocelot-based
reference boards - pcb120 and pcb123. The PHY ids on specific ports
are used to determine the board type.
Building with CONFIG_OF_EMBED generates build warnings, as it should
only be used for debugging purposes.
Remove CONFIG_OF_EMBED from all stm32 config files which are using
this flag.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
This adds device tree and the DM_MMC driver for the AM335x IGEP based
boards.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
This adds device tree and the DM_MMC driver for the SL50 board.
This adds device tree for OMAP3 IGEP based boards and the DM_MMC driver.
To save more space, switch to simple malloc here.
Enable TI_COMMON_CMD_OPTIONS and remove similar options
from the defconfig.
The USB support for this board was never really tested, in fact, the
presence of these options are more a copy & paste error from the
Beagleboard than a feature that really was used. As doesn't work, remove
for now. If someone at some point want to add this support he'll need to
migrate the board to use CONFIG_DM_USB instead.
The IGEP0032 board was never officially pushed upstream and actually I
don't have access to this hardware, unless someone with the hardware
wants to start working on this doesn't makes sense have this defconfig
here. So remove it.
Convert HiSilicon HI6220 MMC driver based on DWMMC IP to driver
model.
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
[trini: Enable this on poplar]
This patch replace OF_EMBED with OF_SEPARATE of defconfig files of
MediaTek boards because now OF_EMBED is only used for debugging purpose.
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Enable ethernet related configs to mt7629_rfb_defconfig.
Add default IP addresses.
Enable noncached memory region required by ethernet driver.
Signed-off-by: Mark Lee <Mark-MC.Lee@mediatek.com>
Enable ethernet related configs to mt7623n_bpir2_defconfig.
It enables fastboot support on Poplar board by using DWC2 OTG gadget
driver.
Enable CONFIG_SPL_YMODEM_SUPPORT to support UART boot
Signed-off-by: Yan Liu <yan-liu@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Add a test for the bootcount uclass, which uses the RTC bootcount backend
(i.e. drivers/bootcount/rtc.c is implictly also tested).
Chris Spencer reports that when enabling ext4 read support without
also enabling write support the following error is seen:
fs/fs.c:198:12: error: 'ext4_write_file' undeclared here (not in a
function); did you mean 'ext4_read_file'?
.write = ext4_write_file,
Fix this problem by moving these options to Kconfig.
Reported-by: Chris Spencer <spencercw@gmail.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
There is no need to compile and include this code if it is not used.
CONFIG_USB_GADGET can be used for the purpose.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
The SPL option for USB gadget should be named after the option for u-boot
(CONFIG_USB_GADGET)
The current defconfig build generates a u-boot.imx file that is too large
for the available space on a eMMC/SD card. Installing this file overwrites
the u-boot environment. So disable the unused FIT support to reduce the
size of the u-boot binary.
Signed-off-by: Soeren Moch <smoch@web.de>
Enable watchdog and bootcounter support on the M53Menlo board.
Safe some space by not selecting CMD_NFS and CMD_LOADS/B.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
