While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
- Set CONFIG_SYS_CACHELINE_SIZE to ARCH_DMA_MINALIGN as that should be
good enough.
- Make <asm/io.h> include <asm/types.h> like other arches do
- Enable many many more drivers in sandbox_defconfig so that we can get
more build-time testing on this platform.
Use i2c cadence DM driver for all zynqmp targets except ZCU102
because I2C muxes and PCA953x are not supported in the tree yet.
Enable missing GPIO options.
Support ZynqMP zc1751 with DC cards.
Support natively revB board. Till now support for revB was done via
zcu102 defconfig where device-tree was changed to revB.
This patch is adding direct defconfig for RevB.
Add new board support.
DM drivers need more malloc space for early DM models allocation.
Use 4k instead of 1k.
There are mini configurations which need to be fit to OCM that's why
these options shouldn't be enabled by default.
Add missing DT nodes and enable USB.
Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
The Orange Pi One SBC, is a stripped down version of the popular
Orange Pi PC. The one is a H3 based SBC, with 512M of RAM,
micro-sd slot, 1 host usb, 1 otg usb, hdmi and 100Mbit ethernet.
The dts is identical to the dts submitted to the upstream kernel.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after
its Kconfig conversion it has ended up missing on some recently
added boards.
Simply select it for ARCH_SUNXI, so that we get it on all
sunxi boards for both a consistent user experience and simpler
defconfig files.
DLDO3 is used to provide Port-D power and PD is used for the
usb-hub / sata-5v enable pins. The 2.5V comes from the schematic
and matches the factory image fex file.
The dts changes are the minimal changes needed for u-boot to
pick-up the usb host controllers. The upstream kernel does not
(yet) have usb host support.
This is the value used in the fex file of the manufacturer images,
and also the DCDC1 default. Sometimes lower values are used to save
battery power, but that does not apply to a SBC.
On all Pis so far, the VC FW provides a short stub to set up the ARM CPU
before entering the kernel (a/k/a U-Boot for us). This feature is not
currently supported by the VC FW when booting in 64-bit mode. However,
this feature will likely appear in the near future, and this U-Boot port
assumes that such a feature is in place. Without that feature, or a
temporary workaround described below, U-Boot will not boot.
Once the VC FW does provide the ARM stub, u-boot.bin built for rpi_3 can
be used drectly as kernel7.img, in the same way as any other RPi port. The
following config.txt is required:
# Fix mini UART input frequency, and setup/enable up the UART.
# Without this option, U-Boot will not boot, even if you don't care
# about the serial console. This option will always be required for
# all RPi3 use-cases, unless the PL011 UART is used, which is not
# yet supported by rpi_3* builds of U-Boot.
enable_uart=1
# Boot in AArch64 (64-bit) mode.
# It is possible that a future VC FW will remove the need for this
# option, instead auto-setting 32-/64-bit mode based on the "kernel"
# filename present on the SD card.
arm_control=0x200
Prior to the VC FW providing the ARM boot stub, you can use the following
steps to build an equivalent stub into the U-Boot binary:
git clone https://github.com/swarren/rpi-3-aarch64-demo.git \
../rpi-3-aarch64-demo
(cd ../rpi-3-aarch64-demo && ./build.sh)
Build U-Boot for rpi_3 in the usual way
cat ../rpi-3-aarch64-demo/armstub64.bin u-boot.bin > u-boot.bin.stubbed
Use u-boot.bin.stubbed as kernel7.img on the Pi SD card.
In this case, the following additional entries are required in config.txt:
# Tell the FW to load the kernel image at address 0, the reset vector.
kernel_old=1
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
"buildman" tool revealed that USB_GADGET was enabled by mistake for this
board in process of moving that option to Kconfig. Remove it to bring
things back to correct state.
CONFIG_SPI_FLASH_BAR was deleted from socfpga_common.h
and placed in socfpga_*_defconfig because it is Kconfig symbol.
Signed-off-by: Denis Bakhvalov <dendibakh@gmail.com>
Reported-by: Denis Bakhvalov <dendibakh@gmail.com>
Enable MUSB host and USB storage support for Microchip
PIC32MZ[DA] Starter Kit.
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
LS2080A is the primary SoC, and LS2085A is a personality with AIOP
and DPAA DDR. The RDB and QDS boards support both personality. By
detecting the SVR at runtime, a single image per board can support
both SoCs. It gives users flexibility to swtich SoC without the need
to reprogram the board.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Enable FLASH_BAR for these targets to be in sync with all zynq boards.
Simplify board config file.
This option enable adding new platform suport just by adding defconfig
and DTS file which will target generic configuration for SoC.
Make no sense to extend Kconfig just create a pointer between DTS and
configuration file.
This patch adds basic support for the Marvell A375 eval board. Tested
are the following interfaces:
- I2C
- SPI
- SPI NOR
- Ethernet (mvpp2), port 0 & 1
Currently the A375 SerDes and DDR3 init code is not intergrated. So
the SPL U-Boot is not fully functional.
Right now, this A375 mainline U-Boot can only be used by chainloading
it via the original Marvell U-Boot. This can be done via this
command:
=> tftpboot 00800000 a375/u-boot-dtb.bin;go 00800000
Cc: Luka Perkov <luka.perkov@sartura.hr>
Enable FIT image support, EXT4 support and generic FS support.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
This commit add support for 96Boards Dragonboard410C.
It is board based on APQ8016 Qualcomm SoC, complying with
96boards specification.
Features (present out of the box):
- 4x Cortex A53 (ARMv8)
- 2x USB Host port
- 1x USB Device port
- 4x LEDs
- 1x HDMI connector
- 1x uSD connector
- 3x buttons (Power, Vol+, Vol-/Reset)
- WIFI, Bluetooth with integrated antenna
- 8GiB eMMC
U-Boot boots chained with fastboot in 64-bit mode.
For detailed build instructions see readme.txt in board directory.
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
This patch adds emulated spmi bus controller with part of
pm8916 pmic on it to sandbox and tests validating SPMI uclass.
Move CONFIG_USB_ULPI* from headers to defconfigs for boards that use it.
Also - add CONFIG_USB where necesarry - all boards use it,
but some are not defining it explicitly.
Affected boards:
colibri_t20, harmony, mcx, mt_ventoux, twister,
zynq_(picozed, zc702, zc706, zed, zybo)
Selecting CONFIG_OF_LIBFDT allows running recent mainline kernels.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
The Raspberry Pi 3 contains a BCM2837 SoC. The BCM2837 is a BCM2836 with
the CPU complex swapped out for a quad-core ARMv8. This can operate in 32-
or 64-bit mode. 32-bit mode is the current default selected by the
VideoCore firmware on the Raspberry Pi 3. This patch adds a 32-bit port of
U-Boot for the Raspberry Pi 3.
>From U-Boot's perspective, the only delta between the RPi 2 and RPi 3 is a
change in usage of the SoC UARTs. On all previous Pis, the PL011 was the
only UART in use. The Raspberry Pi 3 adds a Bluetooth module which uses a
UART to connect to the SoC. By default, the PL011 is used for this purpose
since it has larger FIFOs than the other "mini" UART. However, this can
be configured via the VideoCore firmware's config.txt file. This patch
hard-codes use of the mini UART in the RPi 3 port. If your system uses the
PL011 UART for the console even on the RPi 3, please use the RPi 2 U-Boot
port instead. A future change might determine which UART to use at
run-time, thus allowing the RPi 2 and RPi 3 (32-bit) ports to be squashed
together.
The mini UART has some limitations. One externally visible issue in the
BCM2837 integration is that the UART divides the SoC's "core clock" to
generate the baud rate. The core clock is typically variable, and under
control of the VideoCore firmware for thermal management reasons. If the
VC FW does modify the core clock rate, UART communication will be
corrupted since the baud rate will vary from the expected value. This was
not an issue for the PL011 UART, since it is fed by a fixed 3MHz clock. To
work around this, the VideoCore firmware can be told not to modify the SoC
core clock. However, the only way this can happen and be thermally safe is
to limit the core clock to a low/minimum frequency. This leaves
performance on the table for use-cases that don't care about a UART
console. Consequently, use of the mini UART console must be explicitly
requested by entering the following line into config.txt:
enable_uart=1
A recent version of the VC firmware is required to ensure that the mini
UART is fully and correctly initialized by the VC FW; at least
firmware.git 046effa13ebc "firmware: arm_loader: emmc clock depends on
core clock See: https://github.com/raspberrypi/firmware/issues/572".
The Pine64+ is a system based on the Allwinner A64 SoC. It is capable of
running AArch64 code and thus is the first of its kind for the sunxi target.
This patch adds a defconfig and device tree chunks for it.
Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
[agraf: Change patch description]
Acked-by: Hans de Goede <hdegoede@redhat.com>
The Cubietruck Plus uses all 3 USB controllers:
- USB OTG functions are provided by the musb USB OTG controller
- Onboard SATA is provied by a USB-SATA bridge connected to USB1
- The USB host ports on the board are provided by an HSIC USB hub
FLDO1 is set to 1.2V for HSIC.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The h8_homlet_v2 has 2 USB host ports, one connected to the OTG
controller, one connected to the EHCI/OHCI pair.
Also provide the card detect pin for MMC.
DLDO4 supplies power to the PD pins, and the AC200 Ethernet PHY /
composite video encoder.
The schematics of the h8_homlet_v2 show DCDC1 set to 3.3V. Some
Allwinner-based boards set it to 3.0V to conserve power. Since the
h8_homlet_v2 is a set-top box board with external power, there is
no such requirement.
DCDC5 is designed to supply VCC-DRAM, which is normally 1.5V for DDR3,
1.35V for DDR3L, and 1.2V for LPDDR3.
Also remove CONFIG_AXP_DCDC5_VOLT from h8_homlet_v2_defconfig.
LDO3 and LDO4 are used to power port E resp. port G, which are exposed
on gpio headers, so enable them at 2.8V as specified in the schematic.
Force master mode on the A20-OLinuXino-Lime2. This change is required
to get a reliable link at gigabit speeds.
Signed-off-by: Michael Haas <haas@computerlinguist.org>
Force master mode for 1000BASE-T operation on the
A20-Olimex-SOM-EVB.
Karsten Merker reports that this change is necessary to get a reliable
Sec_init has been called at the beginning to initialize SEC Block
(CAAM) which is used by secure boot validation later for both ls2080a
qds and rdb. 64-bit address in ESBC Header has been enabled. Secure
boot defconfigs are created for boards (NOR boot).
Signed-off-by: Saksham Jain <saksham.jain@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
zipitz2 was dropped in 49d8899ba9c26335e4a12e01c18028fc5e40c796
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
If including MX7D in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS
will not effect.So move MX7D to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to
"select MX7D" to boards using i.MX7 Dual.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
If including MX6SX in CONFIG_SYS_EXTRA_OPTIONS, CONFIG_ROM_UNIFIED_SECTIONS
will not effect.So move MX6SX to Kconfig entry from CONFIG_SYS_EXTRA_OPTIONS to
"select MX6SX" to boards using i.MX6 SoloX.
This patch add support for the CCV xPress board which is equipped
with the i.MX6UL. And provides the following interfaces:
- 128MiB DDR
- UART
- I2C
- eMMC (with booting)
- Ethernet
- USB
This patch adds two build targets. One with and one without SPL. The
non-SPL version is used for loading U-Boot via USB (imx_usb_loader).
Add the basic support for Warp7 board.
For more information about this reference design, please visit:
https://www.element14.com/community/docs/DOC-79058/l/warp-7-the-next-generation-wearable-reference-platform
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
