CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Disable CONFIG_ARCH_FIXUP_FDT_MEMORY to prevent U-Boot from modifying
the memory {} nodes in the DT passed to the Linux kernel. The R8A779x
DT contains multiple memory {} nodes, while U-Boot only modifies the
first one and stuffs all the memory entries into it, which is wrong.
Disabling CONFIG_ARCH_FIXUP_FDT_MEMORY is the least intrusive way to
fix the issue this close to the release, while the real fix is to
extend the fdt_fixup_memory_banks() to handle multiple memory nodes
in DT.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
This reverts commit 25877d4e4c45451c5398aec3de50e0d5befe0e9f.
This is a workaround for Raspberry Pi boot failures seen when passing on
the device tree provided by the Raspberry Pi firmware at boot. Without
CONFIG_OF_EMBED, we just get stuck at "Starting kernel ..." when we try
to boot Linux with this device tree.
Signed-off-by: Paul Barker <pbarker@toganlabs.com>
Tested-by: Jonathan Gray <jsg@jsg.id.au>
enable the ATF option and SDCard in defconfig.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Read SoM information from EEPROM and set ethaddr in late init.
Signed-off-by: Wadim Egorov <w.egorov@phytec.de>
- Pass MTDPARTS kernel arguments to kernel
- Use Kconfig CONFIG_NAND instead of CONFIG_SYS_EXTRA_OPTIONS="NAND"
- Call 'usb_stop' on kernel start
- Update Falcon mode setup to match other OMAP3 boards
- Use "uEnv.txt" as boot script instead of "boot.scr"
Add the following options to drivers/misc/Kconfig:
SYS_I2C_EEPROM_ADDR
SYS_I2C_EEPROM_BUS
SYS_EEPROM_SIZE
SYS_EEPROM_PAGE_WRITE_BITS
SYS_EEPROM_PAGE_WRITE_DELAY_MS
SYS_I2C_EEPROM_ADDR_LEN
SYS_I2C_EEPROM_ADDR_OVERFLOW
This does not migrate any boards, but provides a foundations for
those who want/need these options
[trini: Migrate uniphier]
Manually enable SYS_NAND_U_BOOT_LOCATIONS.
Set CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 and remove it from header
CONFIG_BCH
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
configs/imx6qdl_icore_mmc_defconfig
configs/imx6qdl_icore_rqs_defconfig
- add {ofnode,dev}_read_resource_byname
- provide DT probe hook to Denali NAND driver
- update clk/reset driver
- update DT
- misc cleanups
Add Falcon mode support in Engicam i.CoreM6 board.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Now the entry to the NAND driver init can be is controlled by DT;
it should not hurt to compile the driver all the time.
This imply was added when the option was moved by the moveconfig tool,
but the intention is not clear. Move it to defconfig.
Migrate to the DT-based NAND init entry.
U-Boot proper is using DM_MMC so, enable CONFIG_BLK otherwise
find_mmc_device failed to detect MMC device.
Reviewed-by: Stefano Babic <sbabic@denx.de>
Add CONFIG_MMC_SUNXI_SLOT_EXTRA=2 to use eMMC on
BPI_M3 board.
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com>
This enables NVMe driver on sandbox for build testing.
Update igep00x0 code with the following features:
- Add board and revision detection for the boards:
- IGEP0020-RF
- IGEP0020-RC
- IGEP0030-RG
- IGEP0030-RE
- Merge IGEP0020 and IGEP0030 mux tables
- Add suport to use GPIO_126, GPIO_127 and GPIO_129
- board_name and board_rev environment variables display board and
revision informations
- Move dtb name selection from code to boot script
Signed-off-by: Pau Pajuelo <ppajuel@gmail.com>
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Tested-by: Pau Pajuelo <ppajuel@gmail.com>
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Use the Atmel PIT timer driver which supports the driver model
and device tree.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
This is currently disabled, so USB keyboards are not detected in U-Boot.
Enable this option to fix that.
Tested-by: Paul Barker <pbarker@toganlabs.com>
Enable the MMC and USB DM on the board since it's the modern method
and now supported by the drivers.
The HUSH parser was disabled somewhere along the way, reenable it.
Cc: Alexandru Gagniuc <alex.g@adaptrum.com>
Commit da3b9e7fd6a1 (Move PHY_MICREL and PHY_MICREL_KSZ90X1 to Kconfig)
broke ethernet support on R8A779x Salvator-X boards by disabling the
KSZ90x1 PHY in Kconfig. Reenable it.
Adjust VGA rom address to 0xfffb0000 so that u-boot.rom image can be
built again.
Let's imply the 'pci' command to access the de facto interconnect
bus in an x86 system.
Enable Serial Download Protocol (SDP) in SPL and U-Boot. This is
useful to make use of imx_usb to download the complete U-Boot
(u-boot.img) after SPL has been downloaded. The U-Boot command
sdp allows to enumerate as SDP capable device again, e.g. to
download a Linux kernel and/or U-Boot script.
- Fix unmet direct dependencies warning
- Remove old sLD3 SoC support
- Update reset data
- Add dr_mode DT property to avoid warning
This converts CONFIG_USB_EHCI_PCI to a Kconfig option, and updates
all boards that use it.
This SoC is too old. It is difficult to maintain any longer.
since commit: b529993e0222 "spl: add hierarchical defaults for SPL_LDSCRIPT"
taurus board stopped working. Use the ldscript from
arch/arm/cpu/u-boot-spl.lds (as before this patch) fixed it.
Sysam stmark2 board is a generic and fully (hw and sw) open board, with
a mcf54415 Coldfire CPU, 128MB of DDR2, 16MB of SPI flash and SD card
as non volatile memories, and a wifi module included on-board.
The board is actually used mainly for Coldfire custodian testing activity
related to the mcf5441x Coldfire family.
For further information please see: http://sysam.it/cff_stmark2.html
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Changes in v2:
- remove CMD_REGINFO
- add board information in commit message
Now that the driver supports it, move these boards over to use driver
model fully for MMC.
Enable driver model for MMC (including BLK), SATA and USB. Note that USB
does not yet work correctly since the nodes are disabled. Hopefully this
can be resolved by the maintainer.
Update A20-OLinuXino-Lime2-eMMC_defconfig to include CONFIG_SCSI
Update pfla02 for setenv changes and PHYLIB/etc migration to Kconfig.
At present we support multiple environment drivers but there is not way to
select between them at run time. Also settings related to the position and
size of the environment area are global (i.e. apply to all locations).
Until these limitations are removed we cannot really support more than one
environment location. Adjust the location to be a choice so that only one
can be selected. By default the environment is 'nowhere', meaning that the
environment exists only in memory and cannot be saved.
Also expand the help for the 'nowhere' option and move it to the top since
it is the default.
[trini: Move all of the imply logic to default X if Y so it works again]
