path: root/configs
2016-02-02imx: mx6sxsabreauto: Add support for mx6sx SABREAUTO boardYe Li
Initial version for mx6sx SABREAUTO board support with features: PMIC, QSPI, NAND flash, SD/MMC, USB, Ethernet, I2C, IO Expander. Signed-off-by: Ye Li <ye.li@nxp.com>
2016-02-02Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-02-02board: atmel: sama5d2_xplained: add SPL supportWenyou Yang
The sama5d2 Xplained SPL supports the boot medias: spi flash and SD Card. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-01board: Enable ethernet, tftpboot support to pic32mzdask board.Purna Chandra Mandal
This adds ethernet, TFTP support for PIC32MZ[DA] Starter Kit. Also custom environment variables/scripts are added to help boot from network. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
2016-02-01board: add SDHCI support for PIC32MZDASK board.Purna Chandra Mandal
Enable MMC, SDHCI, FAT_FS support for PIC32MZ[DA] StarterKit. Also add custom scripts, rules to boot Linux from microSD card. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
2016-02-01board: Add Microchip PIC32MZ[DA]-Starter-Kit board.Purna Chandra Mandal
This adds support for Microchip PIC32MZ[DA] StarterKit board based on a PIC32MZ[DA] family of microcontroller. Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-01-30video: sandbox: Enable truetype fonts for sandboxSimon Glass
Enable this feature so that truetype fonts can be used on the sandbox console. Update the tests to select the normal/rotated console when needed. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-30video kconfig console_normalSimon Glass
Signed-off-by: Simon Glass <sjg@chromium.org> [agust: rebased on current master] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-27Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-01-27Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-01-27armv8/ls1043aqds: add QSPI boot supportQianyu Gong
Enable the U-Boot Driver Model(DM) to use the Freescale QSPI driver. Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: add QSPI support in SD bootGong Qianyu
QSPI and IFC are pin-multiplexed on LS1043A. So we use ls1043aqds_sdcard_ifc_defconfig to support IFC in SD boot and ls1043aqds_sdcard_qspi_defconfig to support QSPI in SD boot. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: add DSPI supportGong Qianyu
Enable three DSPI flash memories on board. Commands: => sf probe 1:0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB => sf probe 1:1 SF: Detected SST25WF040B with page size 256 Bytes, erase size 4 KiB, total 512 KiB => sf probe 1:2 SF: Detected EN25S64 with page size 256 Bytes, erase size 64 KiB, total 8 MiB Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: Add lpuart supportWenbin Song
Add lpuart support using the driver model. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27armv8/ls1043aqds: Spilt off board device treeWenbin Song
Move new /chosen node out of the board device tree. Signed-off-by: Wenbin Song <wenbin.song@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27ppc: xilinx-ppc440-generic: Wire LL_TEMAC driverRicardo Ribalda Delgado
If the xparameters file contains a LL_TEMAC definition compile its driver and the net commands. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx-ppc4xx: Port to DM serialRicardo Ribalda Delgado
xilinx_uartlite has been ported to DM, this patch makes the xilinx-ppc405-generic and the xilinx-ppc440-generic boards use the new DM driver. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Fix defconfig for zyboMichal Simek
Change possition of SPI_FLASH to by align with savedefconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Move FLASH_BAR to KconfigMichal Simek
Clean up config and use Kconfig more. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Enable SPI_FLASH for zc770 xm013 platformMichal Simek
Enable SPI flash. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Define sys prompt for all Zynq boardsSiva Durga Prasad Paladugu
Define CONFIG_SYS_PROMPT for all Zynq boards It was removed by: "kconfig: add config option for shell prompt" (sha1: 181bd9dc61d2da88b78f1c1138a685dae39354d6) Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable HUSH via KconfigMichal Simek
Cleanup board file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move CONFIG_NETCONSOLE to KconfigMichal Simek
2016-01-27microblaze: Remove CONFIG_FIT from board fileMichal Simek
And enable it via defconfig by default. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Move eth configuration to KconfigMichal Simek
Cleanup board specific file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable axi emac via KconfigMichal Simek
Enable driver by default for all platforms. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: emaclite: Move emaclite to KconfigMichal Simek
Add PHYLIB and MII dependencies and enable it by default for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: emaclite: Move driver to DMMichal Simek
Move driver to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27microblaze: Enable PHYLIB via KconfigMichal Simek
Cleanup board configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Enable uart16550 DM by defaultMichal Simek
Microblaze is uses uartlite or uart16550 as console drivers. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-27serial: uartlite: Move driver to DMMichal Simek
Enable SPL DM too. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-27ppc: ppc405: ppc405-generic_flash_defconfigRicardo Ribalda Delgado
Remove redundant defconfig file. Boot via flash can be configured via Kconfig. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: ppc440: ppc440-generic_flash_defconfigRicardo Ribalda Delgado
2016-01-27xilinx-ppc440: Remove support for v5fx30tevalRicardo Ribalda Delgado
It is just a specialized version of xilinx-ppc440 Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx-ppc405: Remove support for fx12mmRicardo Ribalda Delgado
It is just a specialized version of the xilinx-ppc405 Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx-ppc440: Remove support for ml507Ricardo Ribalda Delgado
ml507 is just a specialized version of the xilinx-ppc440-generic Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27arm: mvebu: Add support for the Armada XP theadorable boardStefan Roese
This patch adds support for the Armada XP (MV78260) based theadorable board. Its equipped with onboard DDR3, UART, ethernet, I2C, SPI NOR, LCD and SATA (SSD) interfaces / devices. Two defconfigs are added: theadorable_defconfig: The production U-Boot version with a stripped down drivers and feature list. This removes networking, USB and PCI support. theadorable_debug_defconfig: The debugging / testing U-Boot version with full support for all drivers. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-26Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2016-01-26sunxi: Bananapro: Set LDO4 to 2.5VHans de Goede
According to the Bananapro schematic VDD25-SATA either comes from a dedicated WL2003E25-5 LTO, or it is connected to LDO4 via a 0 Ohm resistor. In practice it seems that LDO4 is used, so enable it and set it to 2.5V. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-01-26sunxi: h8_homlet_v2: Drop LDO settings from defconfigChen-Yu Tsai
The LDO settings in this defconfig are either wrong (ALDOs must not be 0) or the same as Kconfig defaults. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-01-26sunxi: Add suport for A83T based Banana-pi M3 BoardVishnu Patekar
Add dts and defconfig for Banana-pi M3 board. It has 2G LPDDR3, UART, ethernet, USB, HDMI, USB Sata, MIPI DSI, mic, AP6212 Wifi, etc on it. It is paired with AXP813 PMIC which is almost same as AXP818. Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com> [hdegoede@redhat.com: rename to Sinovoip_BPI_M3_defconfig/sun8i-a83t-sinovoip-bpi-m3.dts] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-01-26Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2016-01-26video: add CONFIG_I2C_EDID and disable CONFIG_DISPLAY by defaultAnatolij Gustschin
Enabling CONFIG_DISPLAY breaks building for some architectures (microblaze-generic), so we disable CONFIG_DISPLAY in Kconfig by default and enable this option in defconfigs. CONFIG_DISPLAY depends on CONFIG_I2C_EDID, so add and enable it in defconfigs, too. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-24x86: Set up a shared syscon numbering schemaSimon Glass
Each system controller can have a number to identify it. It can then be accessed using syscon_get_by_driver_data(). Put this in a shared header file and update the only current user. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: chromebook_link: Enable the syscon uclassSimon Glass
We will use a system controller to model the Intel Management Engine. Enable this for link. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: ivybridge: Use the I2C driver to perform SMbus initSimon Glass
Move the init code into the I2C driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: Enable DM_USB for link and pantherSimon Glass
Move these two boards to use driver model for USB. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-24x86: ivybridge: Use common CPU init codeSimon Glass
The existing ivybridge code predates the normal multi-core CPU init, and it is not used. Remove it and add CPU nodes to the device tree so that all four CPUs are set up. Also enable the 'cpu' command. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-21rockchip: Add support for Raxda Rock 2Simon Glass
This board includes an RK3288 SoC on a SOM. It can be mounted on a base-board which provides a wide range of peripherals. So far this is verified to boot to a prompt from a microSD card. The serial console works as well as HDMI. Thanks to Tom Cubie for sending me a board. Signed-off-by: Simon Glass <sjg@chromium.org>
